ReceiverFactory.hxx
23#ifndef _RECEIVERFACTORY_HXX_
24#define _RECEIVERFACTORY_HXX_
27
28#include <SALOMEconfig.h>
29#include CORBA_SERVER_HEADER(SALOME_Comm)
31
37{
38public:
39 static double *getValue(SALOME::SenderDouble_ptr sender,long &size);
40 static int *getValue(SALOME::SenderInt_ptr sender,long &size);
41private:
42 static double *getValueOneShot(SALOME::SenderDouble_ptr sender,long &size);
43 static int *getValueOneShot(SALOME::SenderInt_ptr sender,long &size);
44};
45
46#include <memory>
47
49{
50public:
51 SeqByteReceiver(SALOME::SenderByte_ptr sender);
52 char *data(unsigned long& size);
54private:
55 void fetchOneShot(unsigned long size);
56 void fetchByChunks(unsigned long size);
57private:
58 static constexpr unsigned long CHUNK_SIZE = 2000000000;
59 std::unique_ptr<char[]> _data_for_split_case;
60 std::unique_ptr<SALOME::vectorOfByte> _data_one_shot;
61 SALOME::SenderByte_var _obj;
62};
63
64#endif
65
#define COMMUNICATION_EXPORT
Definition: SALOME_Communication.hxx:37
This class internally builds a receiver associated with the sender given.
Definition: ReceiverFactory.hxx:37
Definition: ReceiverFactory.hxx:49
Definition: ReceiverFactory.hxx:61
std::unique_ptr< SALOME::vectorOfByte > _data_one_shot
Definition: ReceiverFactory.hxx:60
std::unique_ptr< char[]> _data_for_split_case
Definition: ReceiverFactory.hxx:59
