ReceiverFactory Class Reference
This class internally builds a receiver associated with the sender given. More...
#include <ReceiverFactory.hxx>
static double * getValue (SALOME::SenderDouble_ptr sender, long &size)
 This method performs the transfert of double array with the remote SenderDouble given. More...
static int * getValue (SALOME::SenderInt_ptr sender, long &size)
 This method performs the transfert of int array with the remote SenderInt given. More...
static double * getValueOneShot (SALOME::SenderDouble_ptr sender, long &size)
 This method performs the transfert with the remote SenderDouble given. More...
static int * getValueOneShot (SALOME::SenderInt_ptr sender, long &size)
 This method performs the transfert with the remote SenderInt given. More...
It also performs transfert completely and clean up the objects. This is the only class used client side of an array.
◆ getValue() [1/2]
double * ReceiverFactory::getValue ( SALOME::SenderDouble_ptr  sender,
long &  size
If it fails with this SenderDouble it tries with an another protocol (CORBA by default).
References SALOME::CORBA_, getValueOneShot(), MESSAGE, and TestKernelHelpers::ret.
Referenced by MatrixClient::getValue().
◆ getValue() [2/2]
int * ReceiverFactory::getValue ( SALOME::SenderInt_ptr  sender,
long &  size
If it fails with this SenderInt it tries with an another protocol (CORBA by default).
◆ getValueOneShot() [1/2]
double * ReceiverFactory::getValueOneShot ( SALOME::SenderDouble_ptr  sender,
long &  size
staticprivate
If it fails an exception is thrown.
Referenced by getValue().
◆ getValueOneShot() [2/2]
int * ReceiverFactory::getValueOneShot ( SALOME::SenderInt_ptr  sender,
long &  size
staticprivate
