SALOME_ResourcesCatalog_Parser.hxx
23// SALOME ResourcesCatalog : implementation of catalog resources parsing (SALOME_ModuleCatalog.idl)
24// File : SALOME_ResourcesCatalog_Parser.hxx
25// Author : Estelle Deville
26// Module : SALOME
27//$Header$
28//
29#ifndef SALOME_RESOURCES_CATALOG_PARSER
30#define SALOME_RESOURCES_CATALOG_PARSER
31
33
34#include <string>
35#include <vector>
36#include <list>
37#include <map>
38#include <iostream>
39
40#ifdef WIN32
41#pragma warning(disable:4251) // Warning DLL Interface ...
42#endif
43
45
47
49
51
53{
54public:
55 const std::string msg;
56
57 ResourcesException(const std::string m) : msg(m) {}
58};
59
61 {
62
63 public:
64 std::string _Name;
65 unsigned int _nbOfNodes;
66 unsigned int _nbOfProcPerNode;
67 unsigned int _CPUFreqMHz;
68 unsigned int _memInMB;
69 static unsigned int _nbOfProcWanted;
70 static unsigned int _nbOfNodesWanted;
71 static unsigned int _nbOfProcPerNodeWanted;
72 static unsigned int _CPUFreqMHzWanted;
73 static unsigned int _memInMBWanted;
74
75 public:
77 ResourceDataToSort(const std::string& name,
78 unsigned int nbOfNodes,
79 unsigned int nbOfProcPerNode,
80 unsigned int CPUFreqMHz,
81 unsigned int memInMB);
82 bool operator< (const ResourceDataToSort& other) const;
83 void Print() const;
84
85 private:
86 unsigned int GetNumberOfPoints() const;
87 };
88
90{
91public:
93 virtual ~ParserResourcesType();
94
95 std::string getAccessProtocolTypeStr() const;
96 std::string getResourceTypeStr() const;
97 std::string getBatchTypeStr() const;
98 std::string getMpiImplTypeStr() const;
99 std::string getClusterInternalProtocolStr() const;
100 std::string getCanLaunchBatchJobsStr() const;
101 std::string getCanRunContainersStr() const;
102
103 void setAccessProtocolTypeStr(const std::string & protocolTypeStr);
104 void setResourceTypeStr(const std::string & resourceTypeStr);
105 void setBatchTypeStr(const std::string & batchTypeStr);
106 void setMpiImplTypeStr(const std::string & mpiImplTypeStr);
107 void setClusterInternalProtocolStr(const std::string & internalProtocolTypeStr);
108 void setCanLaunchBatchJobsStr(const std::string & canLaunchBatchJobsStr);
109 void setCanRunContainersStr(const std::string & canRunContainersStr);
110 std::string dump(char sep) const;
111
113 std::string Name;
114 std::string HostName;
120 std::string UserName;
121 std::string AppliPath;
122 std::vector<std::string> ComponentsList;
123 std::vector<std::string> ModulesList;
124 std::string OS;
125 std::string batchQueue;
126 std::string userCommands;
127 std::string use;
128 std::list<ParserResourcesType> ClusterMembersList;
129 unsigned int nbOfProc;
132 std::string working_directory;
133
134protected:
135
136 static std::string protocolToString(AccessProtocolType protocol);
137 static AccessProtocolType stringToProtocol(const std::string & protocolStr);
138
139 RESOURCESMANAGER_EXPORT friend std::ostream & operator<<(std::ostream &os,
140 const ParserResourcesType &rt);
141
142};
143
144typedef std::map<std::string, ParserResourcesType> MapOfParserResourcesType;
145typedef std::map<std::string, ParserResourcesType>::iterator MapOfParserResourcesType_it;
146
147#endif //SALOME_RESOURCES_CATALOG_PARSER
std::ostream & operator<<(std::ostream &os, const std::pair< T, U > &p)
Definition: DisplayPair.hxx:35
#define RESOURCESMANAGER_EXPORT
Definition: ResourcesManager_Defs.hxx:33
std::map< std::string, ParserResourcesType > MapOfParserResourcesType
Definition: SALOME_ResourcesCatalog_Parser.hxx:144
std::map< std::string, ParserResourcesType >::iterator MapOfParserResourcesType_it
Definition: SALOME_ResourcesCatalog_Parser.hxx:145
ResourceType
Definition: SALOME_ResourcesCatalog_Parser.hxx:46
@ single_machine
@ cluster
BatchType
Definition: SALOME_ResourcesCatalog_Parser.hxx:48
@ oar
@ ccc
@ coorm
@ ll
@ pbs
@ sge
@ none
@ slurm
@ vishnu
@ lsf
MpiImplType
Definition: SALOME_ResourcesCatalog_Parser.hxx:50
@ prun
@ ompi
@ lam
@ mpich2
@ mpich1
@ nompi
@ openmpi
@ slurmmpi
AccessProtocolType
Definition: SALOME_ResourcesCatalog_Parser.hxx:44
@ pbsdsh
@ ssh
@ srun
@ rsh
@ blaunch
@ rsync
@ sh
Definition: SALOME_ResourcesCatalog_Parser.hxx:90
Definition: SALOME_ResourcesCatalog_Parser.hxx:114
Definition: SALOME_ResourcesCatalog_Parser.hxx:121
ResourceType type
Definition: SALOME_ResourcesCatalog_Parser.hxx:117
MpiImplType mpi
Definition: SALOME_ResourcesCatalog_Parser.hxx:119
std::list< ParserResourcesType > ClusterMembersList
Definition: SALOME_ResourcesCatalog_Parser.hxx:128
std::vector< std::string > ComponentsList
Definition: SALOME_ResourcesCatalog_Parser.hxx:122
Definition: SALOME_ResourcesCatalog_Parser.hxx:129
std::string use
Definition: SALOME_ResourcesCatalog_Parser.hxx:127
bool can_run_containers
Definition: SALOME_ResourcesCatalog_Parser.hxx:131
Definition: SALOME_ResourcesCatalog_Parser.hxx:132
Definition: SALOME_ResourcesCatalog_Parser.hxx:125
AccessProtocolType Protocol
Definition: SALOME_ResourcesCatalog_Parser.hxx:115
BatchType Batch
Definition: SALOME_ResourcesCatalog_Parser.hxx:118
std::string OS
Definition: SALOME_ResourcesCatalog_Parser.hxx:124
ResourceDataToSort DataForSort
Definition: SALOME_ResourcesCatalog_Parser.hxx:112
std::string Name
Definition: SALOME_ResourcesCatalog_Parser.hxx:113
Definition: SALOME_ResourcesCatalog_Parser.hxx:126
bool can_launch_batch_jobs
Definition: SALOME_ResourcesCatalog_Parser.hxx:130
std::vector< std::string > ModulesList
Definition: SALOME_ResourcesCatalog_Parser.hxx:123
AccessProtocolType ClusterInternalProtocol
Definition: SALOME_ResourcesCatalog_Parser.hxx:116
Definition: SALOME_ResourcesCatalog_Parser.hxx:120
Definition: SALOME_ResourcesCatalog_Parser.hxx:61
Definition: SALOME_ResourcesCatalog_Parser.hxx:66
Definition: SALOME_ResourcesCatalog_Parser.hxx:71
Definition: SALOME_ResourcesCatalog_Parser.hxx:69
Definition: SALOME_ResourcesCatalog_Parser.hxx:72
Definition: SALOME_ResourcesCatalog_Parser.hxx:73
std::string _Name
Definition: SALOME_ResourcesCatalog_Parser.hxx:64
Definition: SALOME_ResourcesCatalog_Parser.hxx:67
Definition: SALOME_ResourcesCatalog_Parser.hxx:65
Definition: SALOME_ResourcesCatalog_Parser.hxx:68
Definition: SALOME_ResourcesCatalog_Parser.hxx:70
Definition: SALOME_ResourcesCatalog_Parser.hxx:53
Definition: SALOME_ResourcesCatalog_Parser.hxx:57
Definition: SALOME_ResourcesCatalog_Parser.hxx:55
string msg
Definition: TestMinimalExample.py:168
string name
Definition: pythfilter.py:56
def dump(filename)
Definition: pythfilter.py:368
