base_port.hxx
23// File : base_port.hxx
24// Author : Eric Fayolle (EDF), André RIBES (EDF)
25// Module : KERNEL
26//
27#ifndef _PORT_HXX_
28#define _PORT_HXX_
30#include "PortProperties_i.hxx"
31/*
32 * This class is base class for all DSC_User provides and uses port.
33 * It provides a default property object for the port.
34 */
36{
37public :
38 base_port();
39 virtual ~base_port();
40
46 virtual Ports::PortProperties_ptr get_port_properties();
47
48protected :
50};
51
52#endif
53
This class implements the interface Ports::PortProperties.
Definition: PortProperties_i.hxx:40
Definition: base_port.hxx:36
This is used to get the property object of the port.
Definition: base_port.cxx:42
PortProperties_i * default_properties
Definition: base_port.hxx:49
Definition: base_port.cxx:32
base_port()
Definition: base_port.cxx:27
