dsccalcium.PyDSCComponent Class Reference
The SALOME base class for all DSC components implemented in python (interface Engines::Superv_Component). More...
Inheritance diagram for dsccalcium.PyDSCComponent:
def __init__ (self, orb, poa, contID, containerName, instanceName, interfaceName)
def init_service (self, service)
def get_provides_port (self, name, error)
def connect_uses_port (self, name, port)
def connect_provides_port (self, name)
def disconnect_provides_port (self, name, message)
def disconnect_uses_port (self, name, port, message)
def get_port_properties (self, name)
def setInputFileToService (self, service_name, Salome_file_name)
def checkInputFilesToService (self, service_name)
def getInputFileToService (self, service_name, Salome_file_name)
def setOutputFileToService (self, service_name, Salome_file_name)
def getOutputFileToService (self, service_name, Salome_file_name)
def checkOutputFilesToService (self, service_name)
def beginService (self, service_name)
Data Fields
 proxy
Static Public Attributes
dictionary enums
   A Python DSC component is implemented by a Python class that has
   the name of the component and is located in a python module that has the
   name of the component.
   You must derive it and implement init_service and those methods
   that are services of the component.
◆ __init__()
def dsccalcium.PyDSCComponent.__init__ (   self,
  orb,
  poa,
  contID,
  containerName,
  instanceName,
  interfaceName
◆ beginService()
def dsccalcium.PyDSCComponent.beginService (   self,
  service_name
◆ checkInputFilesToService()
def dsccalcium.PyDSCComponent.checkInputFilesToService (   self,
  service_name
◆ checkOutputFilesToService()
def dsccalcium.PyDSCComponent.checkOutputFilesToService (   self,
  service_name
◆ connect_provides_port()
def dsccalcium.PyDSCComponent.connect_provides_port (   self,
  name
◆ connect_uses_port()
def dsccalcium.PyDSCComponent.connect_uses_port (   self,
  name,
  port
◆ disconnect_provides_port()
def dsccalcium.PyDSCComponent.disconnect_provides_port (   self,
  name,
  message
◆ disconnect_uses_port()
def dsccalcium.PyDSCComponent.disconnect_uses_port (   self,
  name,
  port,
  message
◆ get_port_properties()
def dsccalcium.PyDSCComponent.get_port_properties (   self,
  name
◆ get_provides_port()
def dsccalcium.PyDSCComponent.get_provides_port (   self,
  name,
  error
◆ getInputFileToService()
def dsccalcium.PyDSCComponent.getInputFileToService (   self,
  service_name,
  Salome_file_name
◆ getOutputFileToService()
def dsccalcium.PyDSCComponent.getOutputFileToService (   self,
  service_name,
  Salome_file_name
◆ init_service()
def dsccalcium.PyDSCComponent.init_service (   self,
  service
◆ setInputFileToService()
def dsccalcium.PyDSCComponent.setInputFileToService (   self,
  service_name,
  Salome_file_name
◆ setOutputFileToService()
def dsccalcium.PyDSCComponent.setOutputFileToService (   self,
  service_name,
  Salome_file_name
◆ enums
dictionary dsccalcium.PyDSCComponent.enums
Initial value:
= {Engines.DSC.RemovingConnection:calcium.DSC.RemovingConnection,
Engines.DSC.AddingConnection:calcium.DSC.AddingConnection,
Engines.DSC.ApplicationError:calcium.DSC.ApplicationError,
◆ proxy
