launcher_proxy.Job Class Reference
def saveJob (self, result_dir)
def wait (self, sleep_delay=10)
def verify (self)
def getResults (self)
def relaunch (self, script="")
def launch (job_params)
def reloadJob (result_dir)
Data Fields
 job_id
This class makes an easier access to SalomeLauncher.
It adds an automatic save of the job's parameters after the launch. The save
is done into the result directory of the job. It is then possible to reload
the job from that file. It also provides a waiting loop for the job to finish.
This proxy also hides the calls to the naming service in order to get the
instance of SalomeLauncher.
◆ getResults()
def launcher_proxy.Job.getResults (   self)
 Copy the result files from remote working_directory
    to the local result_directory.
References Engines::JobDescription.job_id, and launcher_proxy.Job.job_id.
◆ launch()
def launcher_proxy.Job.launch (   job_params)
 Create, submit and dump a new job to result_dir.
◆ relaunch()
def launcher_proxy.Job.relaunch (   self,
  script = ""
◆ reloadJob()
def launcher_proxy.Job.reloadJob (   result_dir)
 Create a new job from a job dumped in result_dir.
◆ saveJob()
def launcher_proxy.Job.saveJob (   self,
  result_dir
◆ verify()
def launcher_proxy.Job.verify (   self)
 Get the return code of the solver if the job is finished.
    If the job is not finished (submission error or another state),
    return an empty string.
◆ wait()
def launcher_proxy.Job.wait (   self,
  sleep_delay = 10
 Wait for the end of the job
◆ job_id
