test_swig_launcher.TestCompo Class Reference
Inheritance diagram for test_swig_launcher.TestCompo:
def setUpClass (cls)
def verifyFile (self, path, content)
def create_JobParameters (self)
def test_salome_py_job (self)
 test of python_salome job More...
def test_command (self)
 test of command job type More...
def test_yacs (self)
 test of yacs job type More...
def test_yacsopt (self)
 test of yacs job type using "--init_port" driver option More...
def test_command_pre (self)
 test of command job type with pre_command More...
def test_command_salome (self)
 test of command salome job type More...
def test_maximum_duration_management_0 (self)
Data Fields
 test_dir
 suffix
 ressources
◆ create_JobParameters()
◆ setUpClass()
def test_swig_launcher.TestCompo.setUpClass (   cls)
◆ test_command()
◆ test_command_pre()
◆ test_command_salome()
◆ test_maximum_duration_management_0()
def test_swig_launcher.TestCompo.test_maximum_duration_management_0 (   self)
[EDF30356] : Check correct conversion of format DD-HH:MM into second before sending it to libbatch
◆ test_salome_py_job()
◆ test_yacs()
◆ test_yacsopt()
◆ verifyFile()
◆ ressources
◆ suffix
◆ test_dir
test_swig_launcher.TestCompo.test_dir
