extension_utilities.py File Reference
namespace  SalomeOnDemandTK
namespace  SalomeOnDemandTK.extension_utilities
def SalomeOnDemandTK.extension_utilities.create_salomexd (name, descr='', depends_on=None, author='', components=None)
def SalomeOnDemandTK.extension_utilities.read_salomexd (file_path)
def SalomeOnDemandTK.extension_utilities.value_from_salomexd (file_path, key)
def SalomeOnDemandTK.extension_utilities.ext_info_bykey (salome_root, salomex_name, key)
def SalomeOnDemandTK.extension_utilities.create_salomexb (name, included)
def SalomeOnDemandTK.extension_utilities.read_salomexb (file_path)
def SalomeOnDemandTK.extension_utilities.list_files (dir_path)
def SalomeOnDemandTK.extension_utilities.filter_to_regex (dir_path, filter_patterns)
def SalomeOnDemandTK.extension_utilities.list_files_filter (dir_path, filter_patterns)
def SalomeOnDemandTK.extension_utilities.list_files_ext (dir_path, ext)
def SalomeOnDemandTK.extension_utilities.list_tonewline_str (str_list)
def SalomeOnDemandTK.extension_utilities.isvalid_filename (filename, extension)
def SalomeOnDemandTK.extension_utilities.isvalid_dirname (dirname)
def SalomeOnDemandTK.extension_utilities.list_dependants (install_dir, salomex_name)
def SalomeOnDemandTK.extension_utilities.is_empty_dir (directory)
def SalomeOnDemandTK.extension_utilities.find_file (directory, file_name)
def SalomeOnDemandTK.extension_utilities.find_salomexd (install_dir, salomex_name)
def SalomeOnDemandTK.extension_utilities.find_salomexc (install_dir, salomex_name)
def SalomeOnDemandTK.extension_utilities.find_envpy (install_dir, salomex_name)
def SalomeOnDemandTK.extension_utilities.module_from_filename (filename)
def SalomeOnDemandTK.extension_utilities.set_selext_env (install_dir, salomex_name, context=None)
def SalomeOnDemandTK.extension_utilities.get_app_root (levels_up=5)
def SalomeOnDemandTK.extension_utilities.check_if_installed (install_dir, salomex_name)
Variables
string SalomeOnDemandTK.extension_utilities.FORMAT = '%(levelname)s : %(asctime)s : [%(filename)s:%(funcName)s:%(lineno)s] : %(message)s'
 SalomeOnDemandTK.extension_utilities.format
 SalomeOnDemandTK.extension_utilities.level
 SalomeOnDemandTK.extension_utilities.logger = logging.getLogger()
string SalomeOnDemandTK.extension_utilities.SALOME_EXTDIR = '__SALOME_EXT__'
string SalomeOnDemandTK.extension_utilities.ARCFILE_EXT = 'salomex'
string SalomeOnDemandTK.extension_utilities.BFILE_EXT = 'salomexb'
string SalomeOnDemandTK.extension_utilities.CFILE_EXT = 'salomexc'
string SalomeOnDemandTK.extension_utilities.DFILE_EXT = 'salomexd'
string SalomeOnDemandTK.extension_utilities.PYFILE_EXT = 'py'
string SalomeOnDemandTK.extension_utilities.ENVPYFILE_SUF = '_env.py'
string SalomeOnDemandTK.extension_utilities.EXTNAME_KEY = 'name'
string SalomeOnDemandTK.extension_utilities.EXTDESCR_KEY = 'descr'
string SalomeOnDemandTK.extension_utilities.EXTDEPENDSON_KEY = 'depends_on'
string SalomeOnDemandTK.extension_utilities.EXTAUTHOR_KEY = 'author'
string SalomeOnDemandTK.extension_utilities.EXTCOMPONENT_KEY = 'components'
