Collaboration diagram for compo_utils:
def compo_utils.create_input_dict (deterministic_dict, parametric_input)
 This function returns a dictionary containing the input values to be used in the computation code. More...
def compo_utils.create_normal_parametric_output (output_dict, parametric_input)
 This function returns a structure describing the output of the computation code in parametric studies. More...
def compo_utils.create_error_parametric_output (error_message)
 This function returns a structure describing the output of the computation code in parametric studies in case of error. More...
def KERNEL_PY.kernel.parametric.compo_utils.create_input_dict (deterministic_dict, parametric_input)
def KERNEL_PY.kernel.parametric.compo_utils.create_normal_parametric_output (output_dict, parametric_input)
def KERNEL_PY.kernel.parametric.compo_utils.create_error_parametric_output (error_message)
This module provides utility functions for the computation codes intended for use in parametric studies. The computation codes must be implemented as SALOME components to use these functions. If the computation code is implemented as a Python script or function, use module salome.kernel.parametric.compo_utils instead.
◆ create_error_parametric_output() [1/2]
def compo_utils.create_error_parametric_output (   error_message)
error_message(string) the error message.
a structure of type SALOME_TYPES/ParametricOutput describing the error.
◆ create_error_parametric_output() [2/2]
def KERNEL_PY.kernel.parametric.compo_utils.create_error_parametric_output (   error_message)
:type  error_message: string
:param error_message: the error message.
:return: a structure of type SALOME_TYPES/ParametricOutput describing the
         error.
◆ create_input_dict() [1/2]
def compo_utils.create_input_dict (   deterministic_dict,
  parametric_input
deterministic_dict(dict) dictionary containing the fixed values (i.e. non-parametric). This dictionary can be empty if all variables are parametric.
parametric_input(SALOME_TYPES/ParametricInput) structure containing the description and values of the parametric variables.
a dictionary containing the input values for the computation code.
◆ create_input_dict() [2/2]
def KERNEL_PY.kernel.parametric.compo_utils.create_input_dict (   deterministic_dict,
  parametric_input
:type  deterministic_dict: dict
:param deterministic_dict: dictionary containing the fixed values (i.e.
:type  parametric_input: SALOME_TYPES/ParametricInput
:param parametric_input: structure containing the description and values
:return: a dictionary containing the input values for the computation code.
◆ create_normal_parametric_output() [1/2]
def compo_utils.create_normal_parametric_output (   output_dict,
  parametric_input
output_dict(dict) dictionary containing the output values of the computation code (the keys are the variable names, the values are the variable values).
a structure of type SALOME_TYPES/ParametricOutput containing the output of the computation code.
◆ create_normal_parametric_output() [2/2]
def KERNEL_PY.kernel.parametric.compo_utils.create_normal_parametric_output (   output_dict,
  parametric_input
:type  output_dict: dict
:param output_dict: dictionary containing the output values of the
:return: a structure of type SALOME_TYPES/ParametricOutput containing the
