Collaboration diagram for service:
def services.getComponent (componentName="SalomeTestComponent", corbaModule="Engines", containerType="FactoryServer")
 Get a SALOME CORBA component from its name. More...
def services.getComponentList ()
 Get the list of names of all SALOME componenents register in the catalog. More...
def services.__getStudy_demo ()
 Get a study to create SALOME study. More...
def KERNEL_PY.kernel.services.getComponent (componentName="SalomeTestComponent", corbaModule="Engines", containerType="FactoryServer")
def KERNEL_PY.kernel.services.getComponentList ()
def KERNEL_PY.kernel.services.__getStudy_demo ()
Helper for using SALOME kernel services
◆ __getStudy_demo() [1/2]
def services.__getStudy_demo ( )
Warning
you should use instead the variable salome.myStudy. This function is given for illustration of usage of the naming service
◆ __getStudy_demo() [2/2]
def KERNEL_PY.kernel.services.__getStudy_demo ( )
Warning
Get a study to create SALOME study. WARN: you
◆ getComponent() [1/2]
def services.getComponent (   componentName = "SalomeTestComponent",
  corbaModule = "Engines",
  containerType = "FactoryServer"
componentNameis the name of the component as declared in the XML SALOME catalog. A loadable library with name lib<componentName>Engine.so is supposed to be reachable. This library is supposed to provide a factory function with the prototype:
PortableServer::ObjectId * <componentName>Engine_factory( CORBA::ORB_ptr orb,
PortableServer::POA_ptr poa,
PortableServer::ObjectId* contId,
const char *instanceName,
const char *interfaceName );
corbaModuleis the name of the IDL module that contains the definition of the interface of the component. This name corresponds to the namespace of the servant classes.
containerTypespecified the container in which the servants are executed.
Referenced by services.TEST_getComponent().
◆ getComponent() [2/2]
def KERNEL_PY.kernel.services.getComponent (   componentName = "SalomeTestComponent",
Referenced by KERNEL_PY.kernel.services.TEST_getComponent().
◆ getComponentList() [1/2]
def services.getComponentList ( )
Referenced by KERNEL_PY.salome_test.main(), and services.TEST_getComponentList().
◆ getComponentList() [2/2]
def KERNEL_PY.kernel.services.getComponentList ( )
the catalog.
Referenced by KERNEL_PY.kernel.services.TEST_getComponentList().
