study_exchange_vars
Collaboration diagram for study_exchange_vars:
class  study_exchange_vars.Variable
 This class describes a single variable. More...
class  study_exchange_vars.ExchangeVariables
 This class describes "Exchange Variables", i.e. More...
class  KERNEL_PY.kernel.parametric.study_exchange_vars.Variable
class  KERNEL_PY.kernel.parametric.study_exchange_vars.ExchangeVariables
def study_exchange_vars.createSObjectForExchangeVariables (fatherSobj, exchangeVariables, name=DEFAULT_NAME, icon=None, typeId=None)
 Create a SObject to store an ExchangeVariables instance. More...
def study_exchange_vars.updateSObjectForExchangeVariables (sobj, exchangeVariables, name=DEFAULT_NAME, icon=None, typeId=None)
 Update an existing SObject storing an ExchangeVariables instance. More...
def study_exchange_vars.getExchangeVariablesFromSObject (sobj)
 Get an ExchangeVariables instance from a SObject that stores it. More...
def study_exchange_vars.loadExchangeVariablesFromXmlFile (filepath)
 Load an ExchangeVariables instance from an XML file. More...
def KERNEL_PY.kernel.parametric.study_exchange_vars.createSObjectForExchangeVariables (fatherSobj, exchangeVariables, name=DEFAULT_NAME, icon=None, typeId=None)
def KERNEL_PY.kernel.parametric.study_exchange_vars.updateSObjectForExchangeVariables (sobj, exchangeVariables, name=DEFAULT_NAME, icon=None, typeId=None)
def KERNEL_PY.kernel.parametric.study_exchange_vars.getExchangeVariablesFromSObject (sobj)
def KERNEL_PY.kernel.parametric.study_exchange_vars.loadExchangeVariablesFromXmlFile (filepath)
This module provides classes and functions to handle "Exchange Variables", i.e. description of variables to be exchanged between a supervision code and a computation code. These Exchange Variables can be stored in a SObject in Salome study.
◆ createSObjectForExchangeVariables() [1/2]
def study_exchange_vars.createSObjectForExchangeVariables (   fatherSobj,
  exchangeVariables,
  name = DEFAULT_NAME,
  icon = None,
  typeId = None
fatherSobj(SObject) parent of the SObject to create.
exchangeVariables(ExchangeVariables) ExchangeVariables instance to store in Salome study.
name(string) name of the SObject to create.
icon(string) icon of the SObject to create.
typeId(integer) type of the SObject to create.
the newly created SObject.
References _setSObjectForExchangeVariables(), and studyedit.getStudyEditor().
◆ createSObjectForExchangeVariables() [2/2]
def KERNEL_PY.kernel.parametric.study_exchange_vars.createSObjectForExchangeVariables (   fatherSobj,
  exchangeVariables,
  icon = None,
  typeId = None
Create a SObject to store an :class:`ExchangeVariables` instance.
:type  fatherSobj: SObject
:param fatherSobj: parent of the SObject to create.
:type  exchangeVariables: :class:`ExchangeVariables`
:param exchangeVariables: :class:`ExchangeVariables` instance to store in
                          Salome study.
:type  name: string
:param name: name of the SObject to create.
:type  icon: string
:param icon: icon of the SObject to create.
:type  typeId: integer
:param typeId: type of the SObject to create.
:return: the newly created SObject.
References KERNEL_PY.kernel.parametric.study_exchange_vars._setSObjectForExchangeVariables(), and studyedit.getStudyEditor().
◆ getExchangeVariablesFromSObject() [1/2]
def study_exchange_vars.getExchangeVariablesFromSObject (   sobj)
sobj(SObject) the SObject from which to read the ExchangeVariables instance.
the newly created ExchangeVariables instance.
◆ getExchangeVariablesFromSObject() [2/2]
def KERNEL_PY.kernel.parametric.study_exchange_vars.getExchangeVariablesFromSObject (   sobj)
Get an :class:`ExchangeVariables` instance from a SObject that stores it.
:type  sobj: SObject
:param sobj: the SObject from which to read the :class:`ExchangeVariables`
             instance.
:return: the newly created :class:`ExchangeVariables` instance.
◆ loadExchangeVariablesFromXmlFile() [1/2]
def study_exchange_vars.loadExchangeVariablesFromXmlFile (   filepath)
filepath(string) path of the XML file to load.
◆ loadExchangeVariablesFromXmlFile() [2/2]
def KERNEL_PY.kernel.parametric.study_exchange_vars.loadExchangeVariablesFromXmlFile (   filepath)
Load an :class:`ExchangeVariables` instance from an XML file.
:type  filepath: string
:param filepath: path of the XML file to load.
◆ updateSObjectForExchangeVariables() [1/2]
def study_exchange_vars.updateSObjectForExchangeVariables (   sobj,
  exchangeVariables,
  icon = None,
  typeId = None
sobj(SObject) the SObject to update.
See createSObjectForExchangeVariables() for the description of the other parameters.
◆ updateSObjectForExchangeVariables() [2/2]
def KERNEL_PY.kernel.parametric.study_exchange_vars.updateSObjectForExchangeVariables (   sobj,
  exchangeVariables,
  icon = None,
  typeId = None
Update an existing SObject storing an :class:`ExchangeVariables` instance.
:type  sobj: SObject
:param sobj: the SObject to update.
See :func:`createSObjectForExchangeVariables` for the description of the
other parameters.
