Registry::Components Interface Reference
interface to use SALOME registry More...
import"SALOME_Registry.idl";
void ping ()
 check if registry is running More...
long getPID ()
 Get the pid of registry server. More...
unsigned long add (in Infos lesInfos)
 Add one information to the registry. More...
void remove (in unsigned long id)
 Remove an information from the registry. More...
unsigned long size ()
 Get the size of the registry. More...
AllInfos getall ()
 Get all information from registry. More...
AllInfos history ()
 Get history information from registry. More...
oneway void end ()
 Stop the registry (hard exit) More...
oneway void hello (in unsigned long id)
 Say hello to registry from process id. More...
void Shutdown ()
 Shutdown registry server (CORBA exit) More...
◆ add()
unsigned long Registry::Components::add ( in Infos  lesInfos)
◆ end()
oneway void Registry::Components::end ( )
◆ getall()
AllInfos Registry::Components::getall ( )
◆ getPID()
long Registry::Components::getPID ( )
◆ hello()
oneway void Registry::Components::hello ( in unsigned long  id)
◆ history()
AllInfos Registry::Components::history ( )
◆ ping()
void Registry::Components::ping ( )
◆ remove()
void Registry::Components::remove ( in unsigned long  id)
◆ Shutdown()
void Registry::Components::Shutdown ( )
◆ size()
unsigned long Registry::Components::size ( )
