SALOME::Session Interface Reference
Interface of the session. More...
import"SALOME_Session.idl";
exception  GUIActive
 This exception is raised when trying to stop the session with active GUI. More...
exception  RunningStudy
 This exception is raised when trying to stop the session with running study. More...
void GetInterface ()
 Launches GUI in the session. More...
Engines::EngineComponent GetComponent (in string theLibraryName)
 Returns a standalone component. More...
void StopSession () raises (GUIActive, RunningStudy)
 Stops the Session (It must be idle) More...
StatSession GetStatSession ()
 Gets Session State. More...
void Shutdown ()
 Shutdowns Session server. More...
void ping ()
 Determines whether the server has already been loaded or not. More...
long getPID ()
 Returns the PID of the server. More...
string getHostname ()
 Returns host name. More...
boolean restoreVisualState (in long theSavePoint)
 Restores a state of the study at theSavePoint. More...
StringSeq getSelection ()
 Get list of selected entities. More...
void emitMessage (in string theMessage)
 Send a message to the session GUI desktop that will emit a qt signal. More...
oneway void emitMessageOneWay (in string theMessage)
 same as emitMessage but in a non blocking way More...
The session Server launches and stops GUI (Graphical User Interface). The session can be active without GUI (It can contain one or more running studies)
◆ emitMessage()
void SALOME::Session::emitMessage ( in string  theMessage)
This method can be used to send a message to the GUI from the standalone container. Caution: this method can block the Session and the calling container if it is called when container processes some request from the GUI (mutual lock takes place). In such a case it is recommended to use oneway method.
◆ emitMessageOneWay()
oneway void SALOME::Session::emitMessageOneWay ( in string  theMessage)
Emit a qt signal from the session GUI desktop window. This method can be used to send a message to the GUI from the standalone container. This method never blocks the Session and the calling container.
◆ GetComponent()
Engines::EngineComponent SALOME::Session::GetComponent ( in string  theLibraryName)
◆ getHostname()
string SALOME::Session::getHostname ( )
Returns host name.
◆ GetInterface()
void SALOME::Session::GetInterface ( )
◆ getPID()
long SALOME::Session::getPID ( )
◆ getSelection()
StringSeq SALOME::Session::getSelection ( )
◆ GetStatSession()
StatSession SALOME::Session::GetStatSession ( )
Gets Session State.
◆ ping()
void SALOME::Session::ping ( )
◆ restoreVisualState()
boolean SALOME::Session::restoreVisualState ( in long  theSavePoint)
◆ Shutdown()
void SALOME::Session::Shutdown ( )
◆ StopSession()
void SALOME::Session::StopSession ( )
raises (GUIActive,
RunningStudy
