Functions | |
| def | IsRemote (hostName) |
| def | RemoveFileSafe (fileName) |
| def | RetrieveRemoteFileLocallyInSameFileName (remoteHostName, fileName) |
| def | DestroyRemotely (remoteHostName, fileName) |
| def | GetSizeOfBufferedReader (f) |
| def | GetObjectFromFile (fname, visitor=None) |
| def | DumpInFile (obj, fname) |
| def | IncrRefInFile (fname) |
| def | DecrRefInFile (fname) |
| def | GetBigObjectOnDiskThreshold () |
| def | ActivateProxyMecanismOrNot (sizeInByte) |
| def | GetBigObjectDirectory () |
| def | GetBigObjectFileName () |
| def | ProxyfyPickeled (obj, pickleObjInit=None, visitor=None) |
| def | SpoolPickleObject (obj, visitor=None) |
| def | UnProxyObjectSimple (obj, visitor=None) |
| def | UnProxyObjectSimpleLocal (obj) |
| def | FileSystemMonitoring (intervalInMs, dirNameToInspect, outFileName=None) |
| def | CPUMemoryMonitoring (intervalInMs, outFileName=None) |
| def | StopMonitoring (monitoringInfo) |
| def | ReadCPUMemInfoInternal (fileName) |
| def | ReadCPUMemInfo (monitoringInfo) |
| def | ReadInodeSizeInfoInternal (fileName) |
| def | ReadInodeSizeInfo (monitoringInfo) |
| def | ExchangeModeServerSideFactory (exchangeMode) |
| def | ExchangeModeCltSideFactory (exchangeMode, keepFilesToReplay) |
| def | ExecCrashProofGeneric (code, context, outargsname, containerRef, instanceOfLogOfCurrentSession, keepFilesToReplay, closeEyesOnErrorAtExit) |
| def | ExecCrashProofWithReplay (code, context, outargsname, containerRef, instanceOfLogOfCurrentSession) |
| def | ExecCrashProofWithoutReplay (code, context, outargsname, containerRef, instanceOfLogOfCurrentSession) |
| def | ExecCrashProofWithReplayFT (code, context, outargsname, containerRef, instanceOfLogOfCurrentSession) |
| def | ExecCrashProofWithoutReplayFT (code, context, outargsname, containerRef, instanceOfLogOfCurrentSession) |
| def | ExecLocal (code, context, outargsname, containerRef, instanceOfLogOfCurrentSession) |
Variables | |
| string | MY_CONTAINER_ENTRY_IN_GLBS = "my_container" |
| string | MY_PERFORMANCE_LOG_ENTRY_IN_GLBS = "my_log_4_this_session" |
| string | MY_KEY_TO_DETECT_FINISH = "neib av tuot" |
| dictionary | BigFileOnDiskClsFromProtocol = { 0 : BigFileOnDiskShare, 1 : BigFileOnDiskSSDNoShare } |
| dictionary | DicoForProxyFile = { } |
| dictionary | BigObjectDirHandlerFromProtocol = { 0 : BigObjectDirHandlerOnDiskShare, 1 : BigObjectDirHandlerOnDiskSSDNoShare } |
| string | FinalCode |
| def SALOME_PyNode.ActivateProxyMecanismOrNot | ( | sizeInByte | ) |
References GetBigObjectOnDiskThreshold().
Referenced by SpoolPickleObject().
| def SALOME_PyNode.CPUMemoryMonitoring | ( | intervalInMs, | |
outFileName = None |
Launch a subprocess monitoring self process. This monitoring subprocess is a python process lauching every intervalInMs ms evaluation of CPU usage and RSS memory of the calling process. Communication between subprocess and self is done by file. Args: ---- outFileName (str) : name of file inside the results will be written. If None a new file is generated See also FileSystemMonitoring
References SalomeOnDemandTK.extension_utilities.format.
Referenced by SALOME_PyNode.PyScriptNode_Abstract_i.executeSecond(), testPerfLogManager1.testPerfLogManager1.testPerfLogManager0(), and testPerfLogManager1.testPerfLogManager1.testPerfLogManager1().
| def SALOME_PyNode.DecrRefInFile | ( | fname | ) |
:param fname: :type fname: BigFileOnDiskBase
Referenced by SALOME_PyNode.BigObjectOnDiskBase.__del__(), SALOME_PyNode.BigObjectOnDiskBase.decrRef(), testCrashProofContainer.testPerfLogManager1.test6(), testCrashProofContainer.testPerfLogManager1.test7(), testCrashProofContainer.testPerfLogManager1.test8(), and testCrashProofContainer.testPerfLogManager1.test9().
| def SALOME_PyNode.DestroyRemotely | ( | remoteHostName, | |
| fileName | |||
Referenced by SALOME_PyNode.BigFileOnDiskSSDNoShare.unlink().
| def SALOME_PyNode.DumpInFile | ( | obj, | |
| fname | |||
Referenced by SALOME_PyNode.BigObjectOnDiskBase.__dumpIntoFile().
| def SALOME_PyNode.ExchangeModeCltSideFactory | ( | exchangeMode, | |
| keepFilesToReplay | |||
Referenced by ExecCrashProofGeneric().
| def SALOME_PyNode.ExchangeModeServerSideFactory | ( | exchangeMode | ) |
| def SALOME_PyNode.ExecCrashProofGeneric | ( | code, | |
| context, | |||
| outargsname, | |||
| containerRef, | |||
| instanceOfLogOfCurrentSession, | |||
| keepFilesToReplay, | |||
| closeEyesOnErrorAtExit | |||
Equivalent of exec(code,context) but executed in a separate subprocess to avoid to make the current process crash. Args: ----- code (str) : python code to be executed using context context (dict) : context to be used for execution. This context will be updated in accordance with the execution of code. outargsname (list<str>) : list of arguments to be exported containerRef (Engines.Container) : Container ref (retrieving the Files to created when keepFilesToReplay is set to False) instanceOfLogOfCurrentSession (LogOfCurrentExecutionSession) : instance of LogOfCurrentExecutionSession to build remotely the reference in order to log information keepFilesToReplay (bool) : if True when something goes wrong during execution all the files to replay post mortem case are kept. If False only error is reported but files to replay are destoyed. closeEyesOnErrorAtExit (bool) : if True in case of crash of subprocess, if MY_KEY_TO_DETECT_FINISH is displayed at the end of stdout Return: ------- ScriptExecInfo : instance serverside In/Out: ------- context will be modified by this method. elts in outargsname will be added and their corresponding value coming from evaluation.
References ExchangeModeCltSideFactory(), SalomeOnDemandTK.extension_utilities.format, and salome.salome_init().
Referenced by ExecCrashProofWithoutReplay(), ExecCrashProofWithoutReplayFT(), ExecCrashProofWithReplay(), and ExecCrashProofWithReplayFT().
| def SALOME_PyNode.ExecCrashProofWithoutReplay | ( | code, | |
| context, | |||
| outargsname, | |||
| containerRef, | |||
| instanceOfLogOfCurrentSession | |||
References ExecCrashProofGeneric().
Referenced by SALOME_PyNode.PyScriptNode_OutOfProcess_i.executeNow().
| def SALOME_PyNode.ExecCrashProofWithoutReplayFT | ( | code, | |
| context, | |||
| outargsname, | |||
| containerRef, | |||
Referenced by SALOME_PyNode.PyScriptNode_OutOfProcess_FT_i.executeNow().
| def SALOME_PyNode.ExecCrashProofWithReplay | ( | code, | |
| context, | |||
| outargsname, | |||
| containerRef, | |||
Referenced by SALOME_PyNode.PyScriptNode_OutOfProcess_Replay_i.executeNow().
| def SALOME_PyNode.ExecCrashProofWithReplayFT | ( | code, | |
| context, | |||
| outargsname, | |||
| containerRef, | |||
Referenced by SALOME_PyNode.PyScriptNode_OutOfProcess_Replay_FT_i.executeNow().
| def SALOME_PyNode.ExecLocal | ( | code, | |
| context, | |||
| outargsname, | |||
| containerRef, | |||
Referenced by SALOME_PyNode.PyScriptNode_i.executeNow().
| def SALOME_PyNode.FileSystemMonitoring | ( | intervalInMs, | |
| dirNameToInspect, | |||
This method loops indefinitely every intervalInMs milliseconds to scan number of inodes and size of content recursively included into the in input directory. Args: ---- outFileName (str) : name of file inside the results will be written. If None a new file is generated See also CPUMemoryMonitoring
Referenced by testPerfLogManager1.testPerfLogManager1.testPerfLogManager0(), and testPerfLogManager1.testPerfLogManager1.testPerfLogManager1().
| def SALOME_PyNode.GetBigObjectDirectory | ( | ) |
Referenced by GetBigObjectFileName().
| def SALOME_PyNode.GetBigObjectFileName | ( | ) |
Return a filename in the most secure manner (see tempfile documentation)
References GetBigObjectDirectory().
Referenced by ProxyfyPickeled().
| def SALOME_PyNode.GetBigObjectOnDiskThreshold | ( | ) |
| def SALOME_PyNode.GetObjectFromFile | ( | fname, | |
visitor = None |
References GetSizeOfBufferedReader().
Referenced by SALOME_PyNode.BigFileOnDiskShare.get(), and SALOME_PyNode.BigFileOnDiskSSDNoShare.get().
| def SALOME_PyNode.GetSizeOfBufferedReader | ( | f | ) |
This method returns in bytes size of a file openned.
Args:
f (io.IOBase): buffered reader returned by open
int: number of bytes
Referenced by GetObjectFromFile().
| def SALOME_PyNode.IncrRefInFile | ( | fname | ) |
:param fname: :type fname: str
Referenced by SALOME_PyNode.BigObjectOnDiskBase.incrRef().
| def SALOME_PyNode.IsRemote | ( | hostName | ) |
| def SALOME_PyNode.ProxyfyPickeled | ( | obj, | |
pickleObjInit = None, |
visitor = None |
This method return a proxy instance of pickled form of object given in input.
Args:
obj (pickelable type) : object to be proxified
pickleObjInit (bytes) : Optionnal. Original pickeled form of object to be proxyfied if already computed. If not this method generate it
BigObjectOnDiskBase: proxy instance
References GetBigObjectFileName().
Referenced by SpoolPickleObject(), testPerfLogManager1.testPerfLogManager1.testPerfLogManager0(), and testPerfLogManager1.testPerfLogManager1.testPerfLogManager1().
| def SALOME_PyNode.ReadCPUMemInfo | ( | monitoringInfo | ) |
Retrieve CPU/Mem data of monitoring.
Args:
monitoringInfo (MonitoringInfo): info returned by LaunchMonitoring
CPUMemInfo instance
References ReadCPUMemInfoInternal().
| def SALOME_PyNode.ReadCPUMemInfoInternal | ( | fileName | ) |
Referenced by ReadCPUMemInfo().
| def SALOME_PyNode.ReadInodeSizeInfo | ( | monitoringInfo | ) |
Retrieve nb of inodes and size of monitoring
Args:
InodeSizeInfo
References ReadInodeSizeInfoInternal().
| def SALOME_PyNode.ReadInodeSizeInfoInternal | ( | fileName | ) |
Referenced by ReadInodeSizeInfo().
| def SALOME_PyNode.RemoveFileSafe | ( | fileName | ) |
| def SALOME_PyNode.RetrieveRemoteFileLocallyInSameFileName | ( | remoteHostName, | |
| fileName | |||
To customize
Referenced by SALOME_PyNode.CopyFileFromRemoteCtxMgr.__enter__().
| def SALOME_PyNode.SpoolPickleObject | ( | obj, | |
visitor = None |
References ActivateProxyMecanismOrNot(), and ProxyfyPickeled().
Referenced by SALOME_PyNode.PyScriptNode_Abstract_i.executeSecond().
| def SALOME_PyNode.StopMonitoring | ( | monitoringInfo | ) |
Kill monitoring subprocess.
Args:
Referenced by salome.LogManagerLaunchMonitoringFileCtxMgr.__exit__(), SALOME_PyNode.GenericPythonMonitoringLauncherCtxMgr.__exit__(), and KERNEL_PY.LogManagerLaunchMonitoringFileCtxMgr.__exit__().
| def SALOME_PyNode.UnProxyObjectSimple | ( | obj, | |
visitor = None |
Method to be called in Remote mode. Alterate the obj _status attribute.
Because the slave process does not participate in the reference counting
Args:
visitor (InOutputObjVisitor): A visitor to keep track of amount of memory on chip and those on HDD
References SalomeOnDemandTK.extension_utilities.format, and UnProxyObjectSimple().
Referenced by SALOME_PyNode.PyScriptNode_Abstract_i.executeFirst(), testCrashProofContainer.testPerfLogManager1.test6(), testCrashProofContainer.testPerfLogManager1.test7(), testCrashProofContainer.testPerfLogManager1.test8(), testCrashProofContainer.testPerfLogManager1.test9(), and UnProxyObjectSimple().
| def SALOME_PyNode.UnProxyObjectSimpleLocal | ( | obj | ) |
Method to be called in Local mode. Do not alterate the PyObj counter
References UnProxyObjectSimpleLocal().
Referenced by UnProxyObjectSimpleLocal().
| dictionary SALOME_PyNode.BigFileOnDiskClsFromProtocol = { 0 : BigFileOnDiskShare, 1 : BigFileOnDiskSSDNoShare } |
| dictionary SALOME_PyNode.BigObjectDirHandlerFromProtocol = { 0 : BigObjectDirHandlerOnDiskShare, 1 : BigObjectDirHandlerOnDiskSSDNoShare } |
| dictionary SALOME_PyNode.DicoForProxyFile = { } |
| string SALOME_PyNode.FinalCode |
| string SALOME_PyNode.MY_CONTAINER_ENTRY_IN_GLBS = "my_container" |
| string SALOME_PyNode.MY_KEY_TO_DETECT_FINISH = "neib av tuot" |
| string SALOME_PyNode.MY_PERFORMANCE_LOG_ENTRY_IN_GLBS = "my_log_4_this_session" |
