SalomeOnDemandTK.extension_builder Namespace Reference
def add_files (ext, files_abs, files_rel)
def create_salomex (salomexb, salomexd, env_py, top_repository)
Variables
 arg_1
 arg_2
 arg_3
 arg_4
◆ add_files()
def SalomeOnDemandTK.extension_builder.add_files (   ext,
  files_abs,
  files_rel
Add selected files into salome extension archive.
Args:
    ext - a file oject to pack in.
    files_abs - a list of the files with abs file names.
    files_rel - a list of the files with rel file names.
Returns:
    None.
Referenced by SalomeOnDemandTK.extension_builder.create_salomex().
◆ create_salomex()
def SalomeOnDemandTK.extension_builder.create_salomex (   salomexb,
  salomexd,
  env_py,
  top_repository
Makes salome extension archive from provided in salomexb file directories.
Args:
    salomexb - a path to the <extension>.salomexb file.
    salomexd - a path to the <extension>.salomexd file.
    env_py - a path to the <ext>_env.py file.
    top_repository - a root directory for all the paths listed inside salomexb file.
Returns:
    None.
References SalomeOnDemandTK.extension_builder.add_files(), SalomeOnDemandTK.extension_utilities.isvalid_dirname(), SalomeOnDemandTK.extension_utilities.isvalid_filename(), SalomeOnDemandTK.extension_utilities.list_files_filter(), SalomeOnDemandTK.extension_utilities.list_tonewline_str(), SalomeOnDemandTK.extension_utilities.read_salomexb(), and SalomeOnDemandTK.extension_utilities.read_salomexd().
Variable Documentation
◆ arg_1
SalomeOnDemandTK.extension_builder.arg_1
◆ arg_2
SalomeOnDemandTK.extension_builder.arg_2
◆ arg_3
SalomeOnDemandTK.extension_builder.arg_3
◆ arg_4
SalomeOnDemandTK.extension_builder.arg_4
