SalomeOnDemandTK.extension_query Namespace Reference
def size_to_str (size, format_in_bytes=False)
def dir_size (directory)
def dir_size_str (directory, format_in_bytes=False)
def size_bylist (root_dir, salomexc)
def ext_size (install_dir, salomex_name)
def ext_size_str (install_dir, salomex_name, format_in_bytes=False)
def dependency_tree (directory)
def ext_info_dict (directory)
def ext_by_dependants (dep_tree, depends_on=None)
def ext_by_name (directory)
def ext_canremove_flags (directory)
Variables
def ext_tree = dependency_tree(sys.argv[1])
def ext_list = ext_by_dependants(ext_tree)
 arg_1
 arg_2
◆ dependency_tree()
def SalomeOnDemandTK.extension_query.dependency_tree (   directory)
Create a dependency tree for all salome extensions
installed in the given directory.
Args:
    directory - the given directory
Returns:
    A dictionary like that for extensions A, B, C, D and E:
      A
    / B D
    C   E
    { 'A': ['B', 'C', 'D'], 'B': ['C', 'E'], 'C': [], 'D': ['E'], 'E': [] }.
References SalomeOnDemandTK.extension_utilities.list_files_ext(), and SalomeOnDemandTK.extension_utilities.read_salomexd().
Referenced by SalomeOnDemandTK.extension_query.ext_canremove_flags(), and runSalomeOnDemand.set_ext_env().
◆ dir_size()
def SalomeOnDemandTK.extension_query.dir_size (   directory)
Calculate a total size of the given directory.
Args:
Returns:
    Size of the directory.
Referenced by SalomeOnDemandTK.extension_query.dir_size_str().
◆ dir_size_str()
def SalomeOnDemandTK.extension_query.dir_size_str (   directory,
  format_in_bytes = False
Calculate a total size of the given directory and format as a string.
Args:
    format_in_bytes - if True, size is expressed in bytes,
        otherwise human readable units are used.
Returns:
    Size of the directory as a formatted string.
References SalomeOnDemandTK.extension_query.dir_size(), and SalomeOnDemandTK.extension_query.size_to_str().
Referenced by SalomeOnDemandTK.extension_query.ext_canremove_flags().
◆ ext_by_dependants()
def SalomeOnDemandTK.extension_query.ext_by_dependants (   dep_tree,
  depends_on = None
Calcualate a list of extensions names sorted by dependencies.
Args:
dep_tree - a dependecy tree of all considered extensions.
depends_on - a set of extensions names to check if the current one depends on them.
Returns:
A list of of extensions from dep_tree sorted by dependencies.
For example, dictionary like that for extensions A, B, C, D and E:
  A
/ B D
C   E
represented { 'A': ['B', 'C', 'D'], 'B': ['C', 'E'], 'C': [], 'D': ['E'], 'E': [] }
returns ['A', 'B', 'D', 'C', 'E'].
References SalomeOnDemandTK.extension_query.ext_by_dependants().
Referenced by SalomeOnDemandTK.extension_query.ext_by_dependants(), and runSalomeOnDemand.set_ext_env().
◆ ext_by_name()
def SalomeOnDemandTK.extension_query.ext_by_name (   directory)
Calcualate a list of extensions installed in the given directory.
Args:
    directory - a directory where extensions are installed.
Returns:
    A list of extensions names sorted by name.
References SalomeOnDemandTK.extension_utilities.list_files_ext().
◆ ext_canremove_flags()
def SalomeOnDemandTK.extension_query.ext_canremove_flags (   directory)
Calcualate a dict of extensions names paired with bool flag if able to be removed.
Args:
    directory - the given ext install directory.
Returns:
    For dependency tree for extensions A, B, C, D and E:
      A
    / B D
    C   E
    returns ['A': True, 'B': False, 'D': False, 'C': False, 'E': False].
    We can remove only A here, because we don't have any other modules depend on it.
References SalomeOnDemandTK.extension_query.dependency_tree(), and SalomeOnDemandTK.extension_query.dir_size_str().
◆ ext_info_dict()
def SalomeOnDemandTK.extension_query.ext_info_dict (   directory)
Get installed salome extensions info.
Args:
Returns:
    A dictionary {name: [descr, author, components, size]}.
References SalomeOnDemandTK.extension_query.ext_size_str(), SalomeOnDemandTK.extension_utilities.list_files_ext(), and SalomeOnDemandTK.extension_utilities.read_salomexd().
◆ ext_size()
def SalomeOnDemandTK.extension_query.ext_size (   install_dir,
  salomex_name
Calculate a total size of a salome extension from SALOME install root.
Args:
    salome_root - path to SALOME install root directory.
    salomex_name - a name of the given salome extension.
Returns:
    Size of the directory in bytes.
References SalomeOnDemandTK.extension_utilities.find_salomexc(), SalomeOnDemandTK.extension_utilities.isvalid_dirname(), and SalomeOnDemandTK.extension_query.size_bylist().
Referenced by SalomeOnDemandTK.extension_query.ext_size_str().
◆ ext_size_str()
def SalomeOnDemandTK.extension_query.ext_size_str (   install_dir,
  salomex_name,
Calculate a total size of the given extension and format as a string.
Args:
    install_dir - directory where the given extension is installed.
    salomex_name - the given extension's name.
Returns:
    Size of the extension as a formatted string.
References SalomeOnDemandTK.extension_query.ext_size(), and SalomeOnDemandTK.extension_query.size_to_str().
Referenced by SalomeOnDemandTK.extension_query.ext_info_dict().
◆ size_bylist()
def SalomeOnDemandTK.extension_query.size_bylist (   root_dir,
  salomexc
Calcualate the total size of files listed in the given salomexc file.
Args:
    root_dir - a root dir for listed files
    salomexc - file that contents a list of files.
Returns:
    The total size of listed files.
Referenced by SalomeOnDemandTK.extension_query.ext_size().
◆ size_to_str()
def SalomeOnDemandTK.extension_query.size_to_str (   size,
Returns a string describing a size.
Args:
    size - the size to represent as a string.
Returns:
    The size as a string with units.
Referenced by SalomeOnDemandTK.extension_query.dir_size_str(), and SalomeOnDemandTK.extension_query.ext_size_str().
Variable Documentation
◆ arg_1
SalomeOnDemandTK.extension_query.arg_1
◆ arg_2
SalomeOnDemandTK.extension_query.arg_2
◆ ext_list
def SalomeOnDemandTK.extension_query.ext_list = ext_by_dependants(ext_tree)
◆ ext_tree
def SalomeOnDemandTK.extension_query.ext_tree = dependency_tree(sys.argv[1])
