SalomeOnDemandTK.extension_remover Namespace Reference
def remove_if_empty (top_dir, directory)
def remove_bylist (root_dir, salomexc)
def remove_salomex (install_dir, salomex_name)
Variables
 arg_1
 arg_2
◆ remove_bylist()
def SalomeOnDemandTK.extension_remover.remove_bylist (   root_dir,
  salomexc
Remove files and directories listed in the given salomexc file.
Args:
    root_dir - a root dir for listed files
    salomexc - file that contents a list of files to remove.
Returns:
    True if all the files were deleted without critical errors.
References SalomeOnDemandTK.extension_remover.remove_if_empty().
Referenced by SalomeOnDemandTK.extension_remover.remove_salomex().
◆ remove_if_empty()
def SalomeOnDemandTK.extension_remover.remove_if_empty (   top_dir,
  directory
Recursively remove empty directories from the given one to the top.
Args:
    top_dir - top parent directory that can be removed as well
    directory - the given directory
Returns:
    None.
References SalomeOnDemandTK.extension_utilities.is_empty_dir(), and SalomeOnDemandTK.extension_remover.remove_if_empty().
Referenced by SalomeOnDemandTK.extension_remover.remove_bylist(), and SalomeOnDemandTK.extension_remover.remove_if_empty().
◆ remove_salomex()
def SalomeOnDemandTK.extension_remover.remove_salomex (   install_dir,
  salomex_name
Remove a salome extension from SALOME install root.
Args:
    salome_root - path to SALOME install root directory.
    salomex_name - a name of salome extension to remove.
Returns:
    List of deleted components or None if the functions fails.
References SalomeOnDemandTK.extension_utilities.check_if_installed(), SalomeOnDemandTK.extension_utilities.find_envpy(), SalomeOnDemandTK.extension_utilities.isvalid_dirname(), SalomeOnDemandTK.extension_utilities.list_dependants(), SalomeOnDemandTK.extension_remover.remove_bylist(), and SalomeOnDemandTK.extension_utilities.value_from_salomexd().
Variable Documentation
◆ arg_1
SalomeOnDemandTK.extension_remover.arg_1
◆ arg_2
SalomeOnDemandTK.extension_remover.arg_2
