SalomeOnDemandTK.extension_unpacker Namespace Reference
def unpack_salomex (salome_root, salomex)
def install_salomex (salomex)
Variables
 arg_1
 arg_2
◆ install_salomex()
def SalomeOnDemandTK.extension_unpacker.install_salomex (   salomex)
Install a given salome extension into SALOME_APPLICATION_DIR.
Args:
    salomex - a given salomex file to unpack.
Returns:
    A list of components to be activated later or None if the function failed.
References SalomeOnDemandTK.extension_utilities.ext_info_bykey(), SalomeOnDemandTK.extension_utilities.get_app_root(), SalomeOnDemandTK.extension_utilities.set_selext_env(), and SalomeOnDemandTK.extension_unpacker.unpack_salomex().
◆ unpack_salomex()
def SalomeOnDemandTK.extension_unpacker.unpack_salomex (   salome_root,
  salomex
Unpack a given salome extension archive into SALOME install root.
Args:
    salome_root - path to SALOME install root directory.
Returns:
    True if an ext was successfully unpacked.
References SalomeOnDemandTK.extension_utilities.check_if_installed(), SalomeOnDemandTK.extension_utilities.isvalid_dirname(), and SalomeOnDemandTK.extension_utilities.isvalid_filename().
Referenced by SalomeOnDemandTK.extension_unpacker.install_salomex().
Variable Documentation
◆ arg_1
SalomeOnDemandTK.extension_unpacker.arg_1
◆ arg_2
SalomeOnDemandTK.extension_unpacker.arg_2
