Functions | |
| def | __deprecated_with_msg (func, msg) |
| def | deprecated (msg=msg_seedoc) |
| This is a decorator which can be used to mark functions as deprecated. More... | |
| def | deprecated_module (msg=msg_seedoc) |
| This function can be used to mark a module as deprecated. More... | |
| def | is_called_by_sphinx () |
| Determine if the calling code is ultimately called by sphinx to generate documentation. More... | |
| def | __show_colored_warning (message, category, filename, lineno, file=None, line=None) |
Variables | |
| string | msg_seedoc = "See documentation for possible replacements." |
| showwarning | |
private |
Referenced by deprecated().
private |
References termcolor.canDisplayColor(), and termcolor.makeColoredMessage().
| string deprecation.msg_seedoc = "See documentation for possible replacements." |
| deprecation.showwarning |
