salome_test_driver Namespace Reference
class  TimeoutException
def runTest (command)
def processResult (res, out, err)
def installHook (hook=None)
def timeoutHandler (signum, frame)
Variables
 timeout_delay = sys.argv[1]
 args = sys.argv[2:]
 index = args.index('--hook')
 hook = args.pop(index)
 _
 ext
list test_and_args = [sys.executable] + args
 timeout_sec = abs(int(timeout_delay)-10)
 timer = Timer(timeout_sec, timeoutHandler)
int res = 1
 salome_instance = SalomeInstance.start(shutdown_servers=True)
 port = salome_instance.get_port()
 out
 err
◆ installHook()
def salome_test_driver.installHook (   hook = None)
Install custome hook to process test result.
◆ processResult()
def salome_test_driver.processResult (   res,
  out,
  err
◆ runTest()
def salome_test_driver.runTest (   command)
◆ timeoutHandler()
def salome_test_driver.timeoutHandler (   signum,
  frame
Variable Documentation
◆ _
salome_test_driver._
◆ args
salome_test_driver.args = sys.argv[2:]
◆ err
salome_test_driver.err
◆ ext
salome_test_driver.ext
◆ hook
salome_test_driver.hook = args.pop(index)
◆ index
salome_test_driver.index = args.index('--hook')
◆ out
salome_test_driver.out
◆ port
salome_test_driver.port = salome_instance.get_port()
◆ res
def salome_test_driver.res = 1
◆ salome_instance
salome_test_driver.salome_instance = SalomeInstance.start(shutdown_servers=True)
◆ test_and_args
salome_test_driver.test_and_args = [sys.executable] + args
◆ timeout_delay
salome_test_driver.timeout_delay = sys.argv[1]
◆ timeout_sec
salome_test_driver.timeout_sec = abs(int(timeout_delay)-10)
◆ timer
salome_test_driver.timer = Timer(timeout_sec, timeoutHandler)
