salome.py File Reference
class  salome.SessionContextManager
class  salome.LogManagerLaunchMonitoringFileCtxMgr
class  salome.Barrier
class  salome.LockGuardCM
class  salome.ContainerLauncherCM
namespace  salome
 Module salome gives access to Salome resources.
def salome.extend_path (pname)
def salome.standalone ()
def salome.withServers ()
def salome.salome_init (path=None, embedded=False, iorfakensfile=None, forced=False)
def salome.salome_init_without_session_common (path=None, embedded=False)
def salome.salome_init_without_session (path=None, embedded=False, iorfakensfile=None)
def salome.salome_init_without_session_attached (path=None, embedded=False)
def salome.salome_init_with_session (path=None, embedded=False)
def salome.salome_close ()
def salome.salome_NS ()
def salome.salome_walk_on_containers (ns, root)
def salome.salome_shutdown_containers_with_session ()
def salome.retrieve_containers_in_ns ()
def salome.get_all_containers ()
def salome.salome_shutdown_containers_without_session ()
def salome.salome_shutdown_containers ()
def salome.ContainerManagerSetOverrideEnvForContainersSimple (self, env)
def salome.LogManagerNaiveFetch (self)
def salome.LogManagerFetch (self, clearMemory=False)
def salome.LogManagerDumpInFile (self, fileName, clearMemory=False)
def salome.LogManagerLaunchMonitoringDumpFile (self, intervalInMs, outFileName)
def salome.LogManagerDumpIORInFile (self, iorFileName)
def salome.LogManagerLoadFromFile (fileName)
def salome.LogManagerLoadFromIORFile (iorFile)
def salome.LogManagerFinalFetchBeforeDying (self)
def salome.LogManagerGetLatestMonitoringDumpFile (self)
Variables
string salome.ROOT_PYTHONPACKAGE_NAME = "salome"
string salome.MATCH_ENDING_PATTERN = "site-packages" + os.path.sep + "salome"
 salome.flags = None
 salome.orb
 salome.lcc
 salome.naming_service
 salome.cm
 salome.sg
 salome.esm
 salome.dsm
 salome.logm
 salome.modulcat
 salome.rm
 salome.lm
 salome.myStudy
 salome.myStudyName
bool salome.salome_initial = True
string salome.CM_NAME_IN_NS = "/ContainerManager"
string salome.RM_NAME_IN_NS = "/ResourcesManager"
string salome.DSM_NAME_IN_NS = "/DataServerManager"
string salome.ESM_NAME_IN_NS = "/ExternalServers"
string salome.LOGM_NAME_IN_NS = "/LogManager"
string salome.LAUNCHER_NAME_IN_NS = "/SalomeLauncher"
 salome.__all__ = dir()
