20#ifndef CONFIG_DATAMODELREADER_H_
21#define CONFIG_DATAMODELREADER_H_
23#include <Config_def.h>
24#include <Config_XMLReader.h>
46 CONFIG_EXPORT std::string
rootType()
const {
return myRootTypes; }
53 CONFIG_EXPORT std::string
rootFolderName(
int theId)
const {
return myRootFolderNames[theId]; }
57 CONFIG_EXPORT std::string
rootFolderType(
int theId)
const {
return myRootFolderTypes[theId]; }
61 CONFIG_EXPORT std::string
rootFolderIcon(
int theId)
const {
return myRootFolderIcons[theId]; }
65 CONFIG_EXPORT
int rootFolderId(std::string theType)
const;
69 CONFIG_EXPORT
bool rootShowEmpty(
int theId)
const {
return myRootFolderShowEmpty[theId]; }
78 CONFIG_EXPORT std::string
subType()
const {
return mySubTypes; }
85 CONFIG_EXPORT std::string
subFolderName(
int theId)
const {
return mySubFolderNames[theId]; }
89 CONFIG_EXPORT std::string
subFolderType(
int theId)
const {
return mySubFolderTypes[theId]; }
93 CONFIG_EXPORT std::string
subFolderIcon(
int theId)
const {
return mySubFolderIcons[theId]; }
97 CONFIG_EXPORT
bool subShowEmpty(
int theId)
const {
return mySubFolderShowEmpty[theId]; }
101 CONFIG_EXPORT
int subFolderId(std::string theType)
const;
105 CONFIG_EXPORT std::string
subFolderFeatures(
const std::string& theFolderName)
const;
120 std::vector<std::string> myRootFolderNames;
121 std::vector<std::string> myRootFolderTypes;
122 std::vector<std::string> myRootFolderIcons;
123 std::vector<std::string> myRootFeaturesList;
124 std::vector<bool> myRootFolderShowEmpty;
126 std::string myRootTypes;
129 std::vector<std::string> mySubFolderNames;
130 std::vector<std::string> mySubFolderTypes;
131 std::vector<std::string> mySubFolderIcons;
132 std::vector<std::string> mySubFeaturesList;
133 std::vector<bool> mySubFolderShowEmpty;
136 std::string mySubTypes;
Class that reads data model definition XML for further processing in the XGUI_DataModel.
Definition: Config_DataModelReader.h:36
CONFIG_EXPORT std::string rootFolderIcon(int theId) const
Returns icon of a folder by its Id.
Definition: Config_DataModelReader.h:61
CONFIG_EXPORT std::string subType() const
Returns name of type of tree items in sub document.
Definition: Config_DataModelReader.h:78
CONFIG_EXPORT std::string rootFolderFeatures(const std::string &theFolderName) const
Returns list of features attached to folder with name theFolderName in sub-document.
Definition: Config_DataModelReader.cpp:130
CONFIG_EXPORT bool isAttachToResult() const
Returns true if the sub-document data tree has to be attached to Part Result node Otherwise it has to...
Definition: Config_DataModelReader.h:110
CONFIG_EXPORT bool subShowEmpty(int theId) const
Returns true if the folder can be shown without items.
Definition: Config_DataModelReader.h:97
CONFIG_EXPORT bool rootShowEmpty(int theId) const
Definition: Config_DataModelReader.h:69
virtual void processNode(xmlNodePtr theNode)
Overloaded method. Defines how to process each node.
Definition: Config_DataModelReader.cpp:39
CONFIG_EXPORT std::string subFolderType(int theId) const
Returns data type in the folder by its Id.
Definition: Config_DataModelReader.h:89
CONFIG_EXPORT int subFolderId(std::string theType) const
Returns id of a folder containing the given type.
Definition: Config_DataModelReader.cpp:93
CONFIG_EXPORT std::string subFolderName(int theId) const
Returns name of the folder by its Id.
Definition: Config_DataModelReader.h:85
CONFIG_EXPORT size_t subFoldersNumber() const
Returns number of folders under sub document.
Definition: Config_DataModelReader.h:81
CONFIG_EXPORT std::string rootFolderName(int theId) const
Definition: Config_DataModelReader.h:53
CONFIG_EXPORT std::string rootFolderType(int theId) const
Definition: Config_DataModelReader.h:57
CONFIG_EXPORT std::string subFolderFeatures(const std::string &theFolderName) const
Definition: Config_DataModelReader.cpp:123
CONFIG_EXPORT std::string subFolderIcon(int theId) const
Definition: Config_DataModelReader.h:93
CONFIG_EXPORT Config_DataModelReader()
Definition: Config_DataModelReader.cpp:30
CONFIG_EXPORT std::string rootType() const
Returns name of type of tree items in root.
Definition: Config_DataModelReader.h:46
CONFIG_EXPORT int rootFolderId(std::string theType) const
Definition: Config_DataModelReader.cpp:82
CONFIG_EXPORT size_t rootFoldersNumber() const
Returns number of folders under root.
Definition: Config_DataModelReader.h:49
Base class for all libxml readers. Provides high-level API for all xml operations.
Definition: Config_XMLReader.h:48
