Config_DataModelReader Class Reference
Class that reads data model definition XML for further processing in the XGUI_DataModel. More...
#include <Config_DataModelReader.h>
Inheritance diagram for Config_DataModelReader:
CONFIG_EXPORT Config_DataModelReader ()
CONFIG_EXPORT std::string rootType () const
 Returns name of type of tree items in root. More...
CONFIG_EXPORT size_t rootFoldersNumber () const
 Returns number of folders under root. More...
CONFIG_EXPORT std::string rootFolderName (int theId) const
 Returns name of the folder by its Id. More...
CONFIG_EXPORT std::string rootFolderType (int theId) const
 Returns data type in the folder by its Id. More...
CONFIG_EXPORT std::string rootFolderIcon (int theId) const
 Returns icon of a folder by its Id. More...
CONFIG_EXPORT int rootFolderId (std::string theType) const
 Returns id of a folder containing the given type. More...
CONFIG_EXPORT bool rootShowEmpty (int theId) const
 Returns true if the folder can be shown without items. More...
CONFIG_EXPORT std::string rootFolderFeatures (const std::string &theFolderName) const
 Returns list of features attached to folder with name theFolderName in sub-document. More...
CONFIG_EXPORT std::string subType () const
 Returns name of type of tree items in sub document. More...
CONFIG_EXPORT size_t subFoldersNumber () const
 Returns number of folders under sub document. More...
CONFIG_EXPORT std::string subFolderName (int theId) const
CONFIG_EXPORT std::string subFolderType (int theId) const
CONFIG_EXPORT std::string subFolderIcon (int theId) const
CONFIG_EXPORT bool subShowEmpty (int theId) const
CONFIG_EXPORT int subFolderId (std::string theType) const
CONFIG_EXPORT std::string subFolderFeatures (const std::string &theFolderName) const
CONFIG_EXPORT bool isAttachToResult () const
 Returns true if the sub-document data tree has to be attached to Part Result node Otherwise it has to be connected to Part feature node. More...
CONFIG_EXPORT void readAll ()
CONFIG_EXPORT xmlNodePtr findRoot (const std::string theDocumentPath="")
CONFIG_EXPORT const char * encoding () const
static CONFIG_EXPORT std::string resourcesConfigFile ()
static CONFIG_EXPORT std::string pluginConfigFile ()
static CONFIG_EXPORT std::string findConfigFile (const std::string theFileName, const int theFindIndex=0)
 Checks all possible paths to configuration file given Uses theFindIndex if several solutions can be found (this is the number of solution to find) More...
virtual void processNode (xmlNodePtr theNode)
 Overloaded method. Defines how to process each node. More...
virtual void cleanup (xmlNodePtr aNode)
virtual bool processChildren (xmlNodePtr aNode)
 Defines which nodes should be processed recursively. Virtual. The default impl is to read all nodes. More...
void readRecursively (xmlNodePtr theParent)
xmlNodePtr node (void *theNode)
 void* -> xmlNodePtr More...
std::string getNodeName (xmlNodePtr theNode)
 Gets xml node name. More...
void storeAttribute (xmlNodePtr theNode, const char *theNodeAttribute, bool doClean=false)
 Stores an attribute in internal map for later use. More...
std::string restoreAttribute (xmlNodePtr theNode, const char *theNodeAttribute)
 Restores an attribute from internal map. More...
std::string restoreAttribute (const char *theNodeName, const char *theNodeAttribute)
bool cleanupAttribute (xmlNodePtr theNode, const char *theNodeAttribute)
 Cleanups attribute from cache. More...
bool cleanupAttribute (const char *theNodeName, const char *theNodeAttribute)
std::string myDocumentPath
 Path to the xml document. More...
xmlDocPtr myXmlDoc
 Root of the xml document. More...
std::string myRootFileName
 name of the root file More...
std::map< std::string, std::string > myCachedAttributes
 A map to store all parent's attributes. More...
bool isFromMemory
◆ Config_DataModelReader()
Config_DataModelReader::Config_DataModelReader ( )
Constructor
◆ rootType()
CONFIG_EXPORT std::string Config_DataModelReader::rootType ( ) const
◆ rootFoldersNumber()
CONFIG_EXPORT size_t Config_DataModelReader::rootFoldersNumber ( ) const
◆ rootFolderName()
CONFIG_EXPORT std::string Config_DataModelReader::rootFolderName ( int  theId) const
theIdid of the folder
◆ rootFolderType()
CONFIG_EXPORT std::string Config_DataModelReader::rootFolderType ( int  theId) const
◆ rootFolderIcon()
CONFIG_EXPORT std::string Config_DataModelReader::rootFolderIcon ( int  theId) const
◆ rootFolderId()
int Config_DataModelReader::rootFolderId ( std::string  theType) const
theTypetype of objects in folder
◆ rootShowEmpty()
CONFIG_EXPORT bool Config_DataModelReader::rootShowEmpty ( int  theId) const
◆ rootFolderFeatures()
std::string Config_DataModelReader::rootFolderFeatures ( const std::string &  theFolderName) const
theFolderNamea name of the folder
◆ subType()
CONFIG_EXPORT std::string Config_DataModelReader::subType ( ) const
◆ subFoldersNumber()
CONFIG_EXPORT size_t Config_DataModelReader::subFoldersNumber ( ) const
◆ subFolderName()
CONFIG_EXPORT std::string Config_DataModelReader::subFolderName ( int  theId) const
◆ subFolderType()
CONFIG_EXPORT std::string Config_DataModelReader::subFolderType ( int  theId) const
◆ subFolderIcon()
CONFIG_EXPORT std::string Config_DataModelReader::subFolderIcon ( int  theId) const
◆ subShowEmpty()
CONFIG_EXPORT bool Config_DataModelReader::subShowEmpty ( int  theId) const
◆ subFolderId()
int Config_DataModelReader::subFolderId ( std::string  theType) const
◆ subFolderFeatures()
std::string Config_DataModelReader::subFolderFeatures ( const std::string &  theFolderName) const
◆ isAttachToResult()
CONFIG_EXPORT bool Config_DataModelReader::isAttachToResult ( ) const
◆ processNode()
void Config_DataModelReader::processNode ( xmlNodePtr  theNode)
Reimplemented from Config_XMLReader.
◆ resourcesConfigFile()
std::string Config_XMLReader::resourcesConfigFile ( )
Returns a path to resource files (created from ROOT_DIR environment variable)
string value
◆ pluginConfigFile()
std::string Config_XMLReader::pluginConfigFile ( )
Returns a path to the plugins.xml file (created from ROOT_DIR environment variable)
string value
◆ readAll()
void Config_XMLReader::readAll ( )
Read all nodes in associated xml file, recursively if processChildren(xmlNode) is true for the xmlNode. For each read node the processNode will be called.
◆ findRoot()
xmlNodePtr Config_XMLReader::findRoot ( const std::string  theDocumentPath = "")
Returns xmlNodePtr to the root of reader's document or NULL if not found. If the path to the document to read is empty, uses myDocumentPath.
◆ findConfigFile()
std::string Config_XMLReader::findConfigFile ( const std::string  theFileName,
const int  theFindIndex = 0
◆ cleanup()
void Config_XMLReader::cleanup ( xmlNodePtr  aNode)
This method gives an ability to finalize processing of a node, when reader is about to leave the node (node and all it's children are processed)
Reimplemented in Config_FeatureReader, and Config_ValidatorReader.
◆ processChildren()
bool Config_XMLReader::processChildren ( xmlNodePtr  aNode)
Reimplemented in Config_FeatureReader, Config_ModuleReader, Config_ValidatorReader, and Config_WidgetReader.
◆ readRecursively()
void Config_XMLReader::readRecursively ( xmlNodePtr  theParent)
Calls processNode() for each child (for some - recursively) of the given node.
See also
ReadAll()
◆ node()
xmlNodePtr Config_XMLReader::node ( void *  theNode)
void* -> xmlNodePtr
◆ getNodeName()
std::string Config_XMLReader::getNodeName ( xmlNodePtr  theNode)
Gets xml node name.
◆ storeAttribute()
void Config_XMLReader::storeAttribute ( xmlNodePtr  theNode,
const char *  theNodeAttribute,
bool  doClean = false
Key is "Node_Name:Node_Attribute" and value is getProperty(theNodeAttribute)
◆ restoreAttribute() [1/2]
std::string Config_XMLReader::restoreAttribute ( xmlNodePtr  theNode,
◆ restoreAttribute() [2/2]
std::string Config_XMLReader::restoreAttribute ( const char *  theNodeName,
◆ cleanupAttribute() [1/2]
bool Config_XMLReader::cleanupAttribute ( xmlNodePtr  theNode,
◆ cleanupAttribute() [2/2]
bool Config_XMLReader::cleanupAttribute ( const char *  theNodeName,
◆ myDocumentPath
std::string Config_XMLReader::myDocumentPath
◆ myXmlDoc
xmlDocPtr Config_XMLReader::myXmlDoc
◆ myRootFileName
std::string Config_XMLReader::myRootFileName
◆ myCachedAttributes
std::map<std::string, std::string> Config_XMLReader::myCachedAttributes
The key has from "Node_Name:Node_Attribute"
