XGUI_DataModel Class Reference
This is a data model for Object Browser (QTreeView). More...
#include <XGUI_DataModel.h>
Inheritance diagram for XGUI_DataModel:
Signals
void beforeTreeRebuild ()
 Signal send before tree rebuild. More...
void treeRebuilt ()
 Signal about tree had been rebuilt. More...
 XGUI_DataModel (QObject *theParent)
virtual ~XGUI_DataModel ()
void setRoot (ModuleBase_ITreeNode *theRoot)
ModuleBase_ITreeNode * root () const
virtual void processEvent (const std::shared_ptr< Events_Message > &theMessage)
 Event Listener method. More...
virtual ObjectPtr object (const QModelIndex &theIndex) const
 Returns an object by the given Model index. More...
virtual QModelIndex objectIndex (const ObjectPtr theObject, int theColumn=1) const
 Returns index of the object. More...
virtual void clear ()
 Clear internal data. More...
virtual void rebuildDataTree ()
 Rebuild data tree. More...
virtual QVariant data (const QModelIndex &theIndex, int theRole) const
 Returns the data stored under the given role for the item referred to by the index. More...
virtual QVariant headerData (int theSection, Qt::Orientation theOrient, int theRole=Qt::DisplayRole) const
 Returns the data for the given role and section in the header with the specified orientation. More...
virtual int rowCount (const QModelIndex &theParent=QModelIndex()) const
 Returns the number of rows under the given parent. More...
virtual int columnCount (const QModelIndex &theParent=QModelIndex()) const
 Returns the number of columns for the children of the given parent. More...
virtual QModelIndex index (int theRow, int theColumn, const QModelIndex &theParent=QModelIndex()) const
 Returns the index of the item in the model specified by the given row, column and parent index. More...
virtual QModelIndex parent (const QModelIndex &theIndex) const
 Returns the parent of the model item with the given index. More...
virtual bool hasChildren (const QModelIndex &theParent=QModelIndex()) const
 Returns true if parent has any children; otherwise returns false. More...
virtual bool insertRows (int theRow, int theCount, const QModelIndex &theParent=QModelIndex())
 Inserts count rows into the model before the given row. More...
virtual bool removeRows (int theRow, int theCount, const QModelIndex &theParent=QModelIndex())
 Removes count rows starting with the given row under parent parent from the model. More...
virtual Qt::ItemFlags flags (const QModelIndex &theIndex) const
 Returns the item flags for the given index. More...
virtual bool canDropMimeData (const QMimeData *theData, Qt::DropAction theAction, int theRow, int theColumn, const QModelIndex &theParent) const override
 Returns true if a model can accept a drop of the data (used for drag and drop functionality). More...
virtual QMimeData * mimeData (const QModelIndexList &indexes) const override
 Converts the dragged items information into mime data format (to be encoded in dropMimeData) More...
virtual bool dropMimeData (const QMimeData *theData, Qt::DropAction theAction, int theRow, int theColumn, const QModelIndex &theParent) override
 Performs a drag and drop of Part feature operation when it is dropped. More...
QModelIndex documentRootIndex (DocumentPtr theDoc, int theColumn=1) const
 Returns an index which is root of the given document. More...
bool hasHiddenState (const QModelIndex &theIndex)
 Returns true if the data model item has Hidden visual state. More...
bool hasIndex (const QModelIndex &theIndex) const
 Returns true if the given index exists in data tree. More...
bool hasNode (ModuleBase_ITreeNode *theNode) const
 Returns true if the given node is a parto of the data tree. More...
DocumentPtr document (const QModelIndex &theIndex) const
 Returns document of the given index. More...
QModelIndex getIndex (ModuleBase_ITreeNode *theNode, int thCol) const
 Returns index for the node and column. More...
virtual Qt::DropActions supportedDropActions () const override
 Allows to support drag and drop of some model items. More...
virtual EVENTS_EXPORT bool groupMessages ()
 Listener that needs mostly grouped messages received returns true in this method. More...
void groupWhileFlush (const std::shared_ptr< Events_Message > &theMessage)
 Allows to group messages while they are flushed (for flush for groupMessages=true listeners) More...
EVENTS_EXPORT void flushGrouped (const Events_ID &theID)
 Sends myGroups on flush finish. More...
It uses XML file for definition of data tree. Some tips about organization of the model:
  • Non Valid Index - root index
  • An index with internal Id == -1 is a folder of root document
  • An index which contains internal pointer as ModelAPI_Object its the object
  • An index which contains internal pointer as ModelAPI_Document is a folder which belongs to this document
◆ XGUI_DataModel()
XGUI_DataModel::XGUI_DataModel ( QObject *  theParent)
theParenta parent object
◆ ~XGUI_DataModel()
XGUI_DataModel::~XGUI_DataModel ( )
◆ processEvent()
void XGUI_DataModel::processEvent ( const std::shared_ptr< Events_Message > &  theMessage)
theMessagean event message
Implements Events_Listener.
◆ object()
ObjectPtr XGUI_DataModel::object ( const QModelIndex &  theIndex) const
Returns 0 if the given index is not index of an object
◆ objectIndex()
QModelIndex XGUI_DataModel::objectIndex ( const ObjectPtr  theObject,
int  theColumn = 1
theObjectobject to find
◆ clear()
void XGUI_DataModel::clear ( )
◆ rebuildDataTree()
void XGUI_DataModel::rebuildDataTree ( )
Rebuild data tree.
◆ data()
QVariant XGUI_DataModel::data ( const QModelIndex &  theIndex,
int  theRole
theIndexa model index
theRolea data role (see Qt::ItemDataRole)
◆ headerData()
QVariant XGUI_DataModel::headerData ( int  theSection,
int  theRole = Qt::DisplayRole
theSectiona section
theOrientan orientation
◆ rowCount()
int XGUI_DataModel::rowCount ( const QModelIndex &  theParent = QModelIndex()) const
When the parent is valid it means that rowCount is returning the number of children of parent.
theParenta parent model index
◆ columnCount()
int XGUI_DataModel::columnCount ( const QModelIndex &  theParent = QModelIndex()) const
It has a one column
◆ index()
QModelIndex XGUI_DataModel::index ( int  theRow,
int  theColumn,
theRowa row
theColumna column
◆ parent()
QModelIndex XGUI_DataModel::parent ( const QModelIndex &  theIndex) const
If the item has no parent, an invalid QModelIndex is returned.
◆ hasChildren()
bool XGUI_DataModel::hasChildren ( const QModelIndex &  theParent = QModelIndex()) const
◆ insertRows()
bool XGUI_DataModel::insertRows ( int  theRow,
int  theCount,
Items in the new row will be children of the item represented by the parent model index.
theRowa start row
theCounta nember of rows to insert
◆ removeRows()
bool XGUI_DataModel::removeRows ( int  theRow,
int  theCount,
theRowa start row
theCounta nember of rows to remove
◆ flags()
Qt::ItemFlags XGUI_DataModel::flags ( const QModelIndex &  theIndex) const
◆ canDropMimeData()
bool XGUI_DataModel::canDropMimeData ( const QMimeData *  theData,
int  theRow,
int  theColumn,
overridevirtual
◆ mimeData()
QMimeData * XGUI_DataModel::mimeData ( const QModelIndexList &  indexes) const
overridevirtual
◆ dropMimeData()
bool XGUI_DataModel::dropMimeData ( const QMimeData *  theData,
int  theRow,
int  theColumn,
overridevirtual
◆ documentRootIndex()
QModelIndex XGUI_DataModel::documentRootIndex ( DocumentPtr  theDoc,
int  theColumn = 1
theDoca document
◆ hasHiddenState()
bool XGUI_DataModel::hasHiddenState ( const QModelIndex &  theIndex)
theIndexa tree model item
boolean value
◆ hasIndex()
bool XGUI_DataModel::hasIndex ( const QModelIndex &  theIndex) const
theIndexan index to check
◆ hasNode()
bool XGUI_DataModel::hasNode ( ModuleBase_ITreeNode *  theNode) const
theNodea node to check
◆ document()
DocumentPtr XGUI_DataModel::document ( const QModelIndex &  theIndex) const
◆ getIndex()
QModelIndex XGUI_DataModel::getIndex ( ModuleBase_ITreeNode *  theNode,
int  thCol
theNodea node
thCola column
◆ supportedDropActions()
virtual Qt::DropActions XGUI_DataModel::supportedDropActions ( ) const
inlineoverridevirtual
◆ beforeTreeRebuild
void XGUI_DataModel::beforeTreeRebuild ( )
signal
◆ treeRebuilt
void XGUI_DataModel::treeRebuilt ( )
signal
◆ groupMessages()
virtual EVENTS_EXPORT bool Events_Listener::groupMessages ( )
inlinevirtualinherited
In this case during the message is flushed, all the new messages are grouped, not sended immideately and then sent in the end of flush.
Reimplemented in SketchPlugin_OverConstraintsResolver, and SketchSolver_Manager.
◆ groupWhileFlush()
void Events_Listener::groupWhileFlush ( const std::shared_ptr< Events_Message > &  theMessage)
◆ flushGrouped()
void Events_Listener::flushGrouped ( const Events_ID &  theID)
