| void | processEvent (const std::shared_ptr< Events_Message > &theMessage) |
| Redefinition of Events_Listener method. More... | |
| virtual bool | groupMessages () |
| Listener that needs mostly grouped messages received returns true in this method. More... | |
| bool | perform () |
| Perform algorithm. More... | |
| void | setConstraints (const std::set< ObjectPtr > &theConstraints) |
| Set set of constraints to check. More... | |
| bool | checkArcsAboutTangentialConflict () |
| Check arcs in sketch about tangential conflict. More... | |
| bool | checkHorizontalOrVerticalConflict () |
| Check lines in sketch about horizontal or vertical conflict. More... | |
| void | groupWhileFlush (const std::shared_ptr< Events_Message > &theMessage) |
| Allows to group messages while they are flushed (for flush for groupMessages=true listeners) More... | |
| EVENTS_EXPORT void | flushGrouped (const Events_ID &theID) |
| Sends myGroups on flush finish. More... | |
Implements Events_Listener.
inlinevirtual |
In this case during the message is flushed, all the new messages are grouped, not sended immideately and then sent in the end of flush.
Reimplemented from Events_Listener.
protected |
Perform algorithm.
protected |
protected |
protected |
protectedinherited |
