SketchSolver_Manager Class Reference
Listens the changes of SketchPlugin features and transforms the Constraint feature into the format understandable by sketch solver. More...
#include <SketchSolver_Manager.h>
Inheritance diagram for SketchSolver_Manager:
virtual void processEvent (const std::shared_ptr< Events_Message > &theMessage)
 Implementation of Event Listener method. More...
virtual bool groupMessages ()
 The solver needs all the updated objects are transferred in one group, not one by one. More...
static SketchSolver_Manager * instance ()
 Main method to create constraint manager. More...
bool updateFeature (const std::shared_ptr< SketchPlugin_Feature > &theFeature)
 Adds or updates a constraint or an entity in the suitable group. More...
bool updateSketch (const std::shared_ptr< ModelAPI_CompositeFeature > &theSketch)
 Updates the sketch and related constraints, if the sketch plane is changed. More...
bool moveFeature (const std::shared_ptr< SketchPlugin_Feature > &theMovedFeature, const std::shared_ptr< GeomAPI_Pnt2d > &theFromPoint, const std::shared_ptr< GeomAPI_Pnt2d > &theToPoint)
 Move feature. More...
bool moveAttribute (const std::shared_ptr< ModelAPI_Attribute > &theMovedAttribute, const int theMovedPointIndex, const std::shared_ptr< GeomAPI_Pnt2d > &theFromPoint, const std::shared_ptr< GeomAPI_Pnt2d > &theToPoint)
 Move feature using its moved attribute. More...
bool removeConstraint (std::shared_ptr< SketchPlugin_Constraint > theConstraint)
 Removes a constraint from the manager. More...
bool resolveConstraints ()
 Goes through the list of groups and solve the constraints. More...
void groupWhileFlush (const std::shared_ptr< Events_Message > &theMessage)
 Allows to group messages while they are flushed (for flush for groupMessages=true listeners) More...
EVENTS_EXPORT void flushGrouped (const Events_ID &theID)
 Sends myGroups on flush finish. More...
Remarks
This is a singleton.
◆ instance()
SketchSolver_Manager * SketchSolver_Manager::instance ( )
pointer to the singleton
◆ processEvent()
void SketchSolver_Manager::processEvent ( const std::shared_ptr< Events_Message > &  theMessage)
[in]theMessagethe data of the event
Implements Events_Listener.
◆ groupMessages()
bool SketchSolver_Manager::groupMessages ( )
This iscreases performance and avoids problems in resolve of only part of the made updates.
Reimplemented from Events_Listener.
◆ updateFeature()
bool SketchSolver_Manager::updateFeature ( const std::shared_ptr< SketchPlugin_Feature > &  theFeature)
[in]theFeaturesketch feature to be changed
true if the feature changed successfully
◆ updateSketch()
bool SketchSolver_Manager::updateSketch ( const std::shared_ptr< ModelAPI_CompositeFeature > &  theSketch)
[in]theSketchsketch to be updated
true if the sketch plane is changed
◆ moveFeature()
bool SketchSolver_Manager::moveFeature ( const std::shared_ptr< SketchPlugin_Feature > &  theMovedFeature,
const std::shared_ptr< GeomAPI_Pnt2d > &  theFromPoint,
const std::shared_ptr< GeomAPI_Pnt2d > &  theToPoint
Move feature.
[in]theMovedFeaturedragged sketch feature
[in]theFromPointoriginal position of the feature
[in]theToPointprefereble position of the feature (current position of the mouse)
true if the feature has been changed successfully
◆ moveAttribute()
bool SketchSolver_Manager::moveAttribute ( const std::shared_ptr< ModelAPI_Attribute > &  theMovedAttribute,
[in]theMovedAttributedragged point (array of points) attribute of sketch feature
[in]theMovedPointIndexindex of dragged point in an array (-1 otherwise)
[in]theFromPointoriginal position of the moved point
[in]theToPointprefereble position (current position of the mouse)
true if the attribute owner has been changed successfully
◆ removeConstraint()
bool SketchSolver_Manager::removeConstraint ( std::shared_ptr< SketchPlugin_Constraint >  theConstraint)
[in]theConstraintconstraint to be removed
true if the constraint removed successfully
◆ resolveConstraints()
bool SketchSolver_Manager::resolveConstraints ( )
true, if groups are resolved, and features should be updated (send the Update event)
◆ groupWhileFlush()
void Events_Listener::groupWhileFlush ( const std::shared_ptr< Events_Message > &  theMessage)
◆ flushGrouped()
void Events_Listener::flushGrouped ( const Events_ID &  theID)
