Generic attribute of the Object. More...
#include <ModelAPI_Attribute.h>
| virtual std::string | attributeType ()=0 |
| Returns the type of this class of attributes, not static method. More... | |
| virtual | ~ModelAPI_Attribute () |
| To virtually destroy the fields of successors. More... | |
| virtual void | setObject (const std::shared_ptr< ModelAPI_Object > &theObject) |
| Sets the owner of this attribute. More... | |
| const std::shared_ptr< ModelAPI_Object > & | owner () const |
| Returns the owner of this attribute. More... | |
| virtual bool | isInitialized () |
| Returns true if attribute was initialized by some value. More... | |
| void | setInitialized () |
| Makes attribute initialized. More... | |
| bool | blockSetInitialized (const bool theBlock) |
| Blocks sending "attribute updated" if theBlock is true. More... | |
| void | setIsArgument (const bool theFlag) |
| Set this attribute is argument for result (change of this attribute requires update of result). More... | |
| bool | isArgument () |
| Returns true if attribute causes the result change. More... | |
| bool | setImmutable (const bool theFlag) |
| Immutable argument can not be changed programmatically (e.g. More... | |
| bool | isImmutable () |
| Returns true if can not be changed programmatically. More... | |
| const std::string & | id () const |
| ID of the attribute in Data. More... | |
| virtual void | reset () |
| Resets attribute to default state. More... | |
| ModelAPI_Attribute () | |
| Objects are created for features automatically. More... | |
| virtual void | setID (const std::string theID) |
| Sets the ID of the attribute in Data (called from Data) More... | |
| virtual void | reinit () |
| Reinitializes the internal state of the attribute (may be needed on undo/redo, abort, etc) More... | |
Protected Attributes | |
| bool | myIsInitialized |
| is some value assigned to this attribute More... | |
| bool | mySetInitializedBlocked |
| is initialized blocked More... | |
| bool | myIsArgument |
| is this attribute used as an argument for execution More... | |
| bool | myIsImmutable |
| is this attribute can be changed programmatically (e.g. by constraint) More... | |
Friends | |
| class | Model_Data |
| class | Model_Objects |
protected |
pure virtual |
Implemented in GeomDataAPI_Dir, GeomDataAPI_Point, GeomDataAPI_Point2D, GeomDataAPI_Point2DArray, ModelAPI_AttributeBoolean, ModelAPI_AttributeDocRef, ModelAPI_AttributeDouble, ModelAPI_AttributeDoubleArray, ModelAPI_AttributeImage, ModelAPI_AttributeIntArray, ModelAPI_AttributeInteger, ModelAPI_AttributeRefAttr, ModelAPI_AttributeRefAttrList, ModelAPI_AttributeReference, ModelAPI_AttributeRefList, ModelAPI_AttributeSelection, ModelAPI_AttributeSelectionList, ModelAPI_AttributeString, ModelAPI_AttributeStringArray, and ModelAPI_AttributeTables.
| const std::shared_ptr< ModelAPI_Object > & ModelAPI_Attribute::owner | ( | ) | const |
Reimplemented in GeomData_Dir, Model_AttributeRefAttr, Model_AttributeRefAttrList, Model_AttributeReference, Model_AttributeRefList, Model_AttributeSelection, and Model_AttributeSelectionList.
| void ModelAPI_Attribute::setInitialized | ( | ) |
| bool ModelAPI_Attribute::blockSetInitialized | ( | const bool | theBlock | ) |
| theBlock | a block value |
| void ModelAPI_Attribute::setIsArgument | ( | const bool | theFlag | ) |
By default it is true.
| bool ModelAPI_Attribute::isArgument | ( | ) |
| bool ModelAPI_Attribute::setImmutable | ( | const bool | theFlag | ) |
| bool ModelAPI_Attribute::isImmutable | ( | ) |
| const std::string & ModelAPI_Attribute::id | ( | ) | const |
protectedvirtual |
protectedvirtual |
Reimplemented in GeomData_Dir, GeomData_Point, GeomData_Point2D, GeomData_Point2DArray, Model_AttributeBoolean, Model_AttributeDocRef, Model_AttributeDouble, Model_AttributeDoubleArray, Model_AttributeImage, Model_AttributeIntArray, Model_AttributeInteger, Model_AttributeRefAttr, Model_AttributeRefAttrList, Model_AttributeReference, Model_AttributeRefList, Model_AttributeSelectionList, Model_AttributeString, and Model_AttributeTables.
protected |
protected |
protected |
protected |
