ModelAPI_AttributeRefAttrList Class Referenceabstract
Attribute that contains list of references to features (located in the same document) or references to attributes of the features (list of AttributeRefAttr) More...
#include <ModelAPI_AttributeRefAttrList.h>
Inheritance diagram for ModelAPI_AttributeRefAttrList:
virtual std::string attributeType ()
virtual void append (ObjectPtr theObject)=0
 Appends the feature to the end of a list. More...
virtual void append (AttributePtr theAttr)=0
 Appends the attribute to the end of a list. More...
virtual void remove (ObjectPtr theObject)=0
 Erases the first meet of the feature in the list. More...
virtual void remove (AttributePtr theAttr)=0
 Erases the first meet of the attribute in the list. More...
virtual void clear ()=0
 Removes all references from the list. More...
virtual int size () const =0
 Returns number of features in the list. More...
virtual std::list< std::pair< ObjectPtr, AttributePtr > > list ()=0
 Returns the list of features and attributes (if it is reference to the attribute) More...
virtual bool isInList (const ObjectPtr &theObj)=0
 Returns true if the object is in list. More...
virtual bool isInList (const AttributePtr &theObj)=0
 Returns true if the attribute is in list. More...
virtual bool isAttribute (const int theIndex) const =0
 Returns true if this is reference to an attribute, not just object. More...
virtual ObjectPtr object (const int theIndex) const =0
 Returns the referenced object by the zero-based index. More...
virtual AttributePtr attribute (const int theIndex) const =0
 Returns the referenced attribute by the zero-based index. More...
virtual void removeLast ()=0
 Removes the last element in the list. More...
virtual void remove (const std::set< int > &theIndices)=0
 Removes the elements from the list. More...
virtual bool isInitialized ()
void setInitialized ()
bool isArgument ()
bool isImmutable ()
virtual void reset ()
static std::string typeId ()
 ModelAPI_AttributeRefAttrList ()
 Objects are created for features automatically. More...
virtual void reinit ()
bool myIsInitialized
bool mySetInitializedBlocked
bool myIsArgument
bool myIsImmutable
◆ ModelAPI_AttributeRefAttrList()
ModelAPI_AttributeRefAttrList::ModelAPI_AttributeRefAttrList ( )
◆ typeId()
static std::string ModelAPI_AttributeRefAttrList::typeId ( )
inlinestatic
◆ attributeType()
std::string ModelAPI_AttributeRefAttrList::attributeType ( )
◆ append() [1/2]
virtual void ModelAPI_AttributeRefAttrList::append ( ObjectPtr  theObject)
pure virtual
Implemented in Model_AttributeRefAttrList.
◆ append() [2/2]
virtual void ModelAPI_AttributeRefAttrList::append ( AttributePtr  theAttr)
pure virtual
◆ remove() [1/3]
virtual void ModelAPI_AttributeRefAttrList::remove ( ObjectPtr  theObject)
pure virtual
◆ remove() [2/3]
virtual void ModelAPI_AttributeRefAttrList::remove ( AttributePtr  theAttr)
pure virtual
◆ clear()
virtual void ModelAPI_AttributeRefAttrList::clear ( )
pure virtual
◆ size()
virtual int ModelAPI_AttributeRefAttrList::size ( ) const
pure virtual
◆ list()
virtual std::list< std::pair< ObjectPtr, AttributePtr > > ModelAPI_AttributeRefAttrList::list ( )
pure virtual
◆ isInList() [1/2]
virtual bool ModelAPI_AttributeRefAttrList::isInList ( const ObjectPtr &  theObj)
pure virtual
◆ isInList() [2/2]
virtual bool ModelAPI_AttributeRefAttrList::isInList ( const AttributePtr &  theObj)
pure virtual
◆ isAttribute()
virtual bool ModelAPI_AttributeRefAttrList::isAttribute ( const int  theIndex) const
pure virtual
◆ object()
virtual ObjectPtr ModelAPI_AttributeRefAttrList::object ( const int  theIndex) const
pure virtual
theIndexzero-based index in the list
◆ attribute()
virtual AttributePtr ModelAPI_AttributeRefAttrList::attribute ( const int  theIndex) const
pure virtual
◆ removeLast()
virtual void ModelAPI_AttributeRefAttrList::removeLast ( )
pure virtual
◆ remove() [3/3]
virtual void ModelAPI_AttributeRefAttrList::remove ( const std::set< int > &  theIndices)
pure virtual
theIndicesa list of indices of elements to be removed
◆ setObject()
◆ owner()
◆ isInitialized()
◆ setInitialized()
◆ blockSetInitialized()
theBlocka block value
the previous block value
◆ setIsArgument()
By default it is true.
◆ isArgument()
◆ setImmutable()
◆ isImmutable()
◆ id()
◆ reset()
void ModelAPI_Attribute::reset ( )
◆ setID()
◆ reinit()
◆ myIsInitialized
◆ mySetInitializedBlocked
◆ myIsArgument
◆ myIsImmutable
