Attribute that contains reference to feature (located in the same document). More...
#include <Model_AttributeReference.h>
| virtual void | setValue (ObjectPtr theObject) |
| Defines the object referenced from this attribute. More... | |
| virtual ObjectPtr | value () |
| Returns object referenced from this attribute. More... | |
| virtual void | setObject (const std::shared_ptr< ModelAPI_Object > &theObject) |
| Sets the owner of this attribute. More... | |
| virtual bool | isInitialized () |
| Returns true if attribute was initialized by some value. More... | |
| virtual std::string | attributeType () |
| Returns the type of this class of attributes, not static method. More... | |
| const std::shared_ptr< ModelAPI_Object > & | owner () const |
| Returns the owner of this attribute. More... | |
| void | setInitialized () |
| Makes attribute initialized. More... | |
| bool | blockSetInitialized (const bool theBlock) |
| Blocks sending "attribute updated" if theBlock is true. More... | |
| void | setIsArgument (const bool theFlag) |
| Set this attribute is argument for result (change of this attribute requires update of result). More... | |
| bool | isArgument () |
| Returns true if attribute causes the result change. More... | |
| bool | setImmutable (const bool theFlag) |
| Immutable argument can not be changed programmatically (e.g. More... | |
| bool | isImmutable () |
| Returns true if can not be changed programmatically. More... | |
| const std::string & | id () const |
| ID of the attribute in Data. More... | |
| virtual void | reset () |
| Resets attribute to default state. More... | |
| static std::string | typeId () |
| Returns the type of this class of attributes. More... | |
| Model_AttributeReference (TDF_Label &theLabel) | |
| Objects are created for features automatically. More... | |
| virtual void | reinit () |
| Reinitializes the internal state of the attribute (may be needed on undo/redo, abort, etc) More... | |
| virtual void | setID (const std::string theID) |
| Sets the ID of the attribute in Data (called from Data) More... | |
Protected Attributes | |
| bool | myIsInitialized |
| is some value assigned to this attribute More... | |
| bool | mySetInitializedBlocked |
| is initialized blocked More... | |
| bool | myIsArgument |
| is this attribute used as an argument for execution More... | |
| bool | myIsImmutable |
| is this attribute can be changed programmatically (e.g. by constraint) More... | |
Friends | |
| class | Model_Data |
| class | Model_AttributeSelection |
protected |
Implements ModelAPI_AttributeReference.
Reimplemented from ModelAPI_Attribute.
protectedvirtual |
inlinestaticinherited |
| theBlock | a block value |
By default it is true.
protectedvirtualinherited |
protectedinherited |
