Model_AttributeReference.h
20#ifndef Model_AttributeReference_H_
21#define Model_AttributeReference_H_
23#include "Model.h"
24#include "ModelAPI_AttributeReference.h"
26#include <TDF_Label.hxx>
27#include <TDF_Reference.hxx>
28
35{
36 TDF_Label myLab;
37 Handle_TDF_Reference myRef;
38 public:
40 MODEL_EXPORT virtual void setValue(ObjectPtr theObject);
41
43 MODEL_EXPORT virtual ObjectPtr value();
44
45 MODEL_EXPORT ~Model_AttributeReference();
46
47 MODEL_EXPORT virtual void setObject(const std::shared_ptr<ModelAPI_Object>& theObject);
48
50 MODEL_EXPORT virtual bool isInitialized();
51
52
53protected:
55 MODEL_EXPORT Model_AttributeReference(TDF_Label& theLabel);
57 virtual void reinit();
58
59 friend class Model_Data;
60 friend class Model_AttributeSelection;
61};
62
63#endif
Attribute that contains reference to feature (located in the same document).
Definition: ModelAPI_AttributeReference.h:32
Definition: Model_AttributeReference.h:35
Model_AttributeReference(TDF_Label &theLabel)
Definition: Model_AttributeReference.cpp:119
Returns object referenced from this attribute.
Definition: Model_AttributeReference.cpp:75
Reinitializes the internal state of the attribute (may be needed on undo/redo, abort,...
Definition: Model_AttributeReference.cpp:125
Defines the object referenced from this attribute.
Definition: Model_AttributeReference.cpp:32
Returns true if attribute was initialized by some value.
Definition: Model_AttributeReference.cpp:110
virtual void setObject(const std::shared_ptr< ModelAPI_Object > &theObject)
Sets the owner of this attribute.
Definition: Model_AttributeReference.cpp:139
Definition: Model_AttributeSelection.h:40
General object of the application that allows to get/set attributes from the document and compute res...
Definition: Model_Data.h:62
