Model_Data Class Reference
General object of the application that allows to get/set attributes from the document and compute result of an operation. More...
#include <Model_Data.h>
Inheritance diagram for Model_Data:
 Model_Data ()
 The simplest constructor. "setLabel" must be called just after to initialize correctly. More...
virtual MODEL_EXPORT std::wstring name ()
 Returns the name of the feature visible by the user in the object browser. More...
virtual MODEL_EXPORT std::wstring name (std::shared_ptr< GeomAPI_Shape > theSubShape)
 Returns the name of the shape. More...
virtual MODEL_EXPORT void setName (const std::wstring &theName)
 Defines the name of the feature visible by the user in the object browser. More...
virtual MODEL_EXPORT bool hasUserDefinedName () const
 Return true if the object has been renamed by the user. More...
virtual MODEL_EXPORT std::string version ()
 Returns version of the feature (empty string if not applicable) More...
virtual MODEL_EXPORT void setVersion (const std::string &theVersion)
 Initialize the version of the feature. More...
virtual MODEL_EXPORT std::shared_ptr< ModelAPI_AttributeDocRef > document (const std::string &theID)
 Returns the attribute that references to another document. More...
virtual MODEL_EXPORT std::shared_ptr< ModelAPI_AttributeDouble > real (const std::string &theID)
 Returns the attribute that contains real value with double precision. More...
virtual MODEL_EXPORT std::shared_ptr< ModelAPI_AttributeDoubleArray > realArray (const std::string &theID)
 Returns the attribute that contains double values array. More...
virtual MODEL_EXPORT std::shared_ptr< ModelAPI_AttributeInteger > integer (const std::string &theID)
 Returns the attribute that contains integer value. More...
virtual MODEL_EXPORT std::shared_ptr< ModelAPI_AttributeReference > reference (const std::string &theID)
 Returns the attribute that contains reference to a feature. More...
virtual MODEL_EXPORT std::shared_ptr< ModelAPI_AttributeSelection > selection (const std::string &theID)
 Returns the attribute that contains selection to a shape. More...
virtual MODEL_EXPORT std::shared_ptr< ModelAPI_AttributeSelectionList > selectionList (const std::string &theID)
virtual MODEL_EXPORT std::shared_ptr< ModelAPI_AttributeRefAttr > refattr (const std::string &theID)
 Returns the attribute that contains reference to an attribute of a feature. More...
virtual MODEL_EXPORT std::shared_ptr< ModelAPI_AttributeRefList > reflist (const std::string &theID)
 Returns the attribute that contains list of references to features. More...
virtual MODEL_EXPORT std::shared_ptr< ModelAPI_AttributeRefAttrList > refattrlist (const std::string &theID)
 Returns the attribute that contains list of references to features or reference to an attribute of a feature. More...
virtual MODEL_EXPORT std::shared_ptr< ModelAPI_AttributeBoolean > boolean (const std::string &theID)
 Returns the attribute that contains boolean value. More...
virtual MODEL_EXPORT std::shared_ptr< ModelAPI_AttributeString > string (const std::string &theID)
virtual MODEL_EXPORT std::shared_ptr< ModelAPI_AttributeIntArray > intArray (const std::string &theID)
 Returns the attribute that contains integer values array. More...
virtual MODEL_EXPORT std::shared_ptr< ModelAPI_AttributeStringArray > stringArray (const std::string &theID)
 Returns the attribute that contains string values array. More...
virtual MODEL_EXPORT std::shared_ptr< ModelAPI_AttributeTables > tables (const std::string &theID)
virtual MODEL_EXPORT std::shared_ptr< ModelAPI_AttributeImage > image (const std::string &theID)
 Returns the attribute that contains image. More...
virtual MODEL_EXPORT std::shared_ptr< ModelAPI_Attribute > attribute (const std::string &theID)
 Returns the generic attribute by identifier. More...
virtual MODEL_EXPORT std::list< std::shared_ptr< ModelAPI_Attribute > > attributes (const std::string &theType)
 Returns all attributes of the feature of the given type or all attributes if "theType" is empty. More...
virtual MODEL_EXPORT std::list< std::string > attributesIDs (const std::string &theType)
 Returns all attributes ids of the feature of the given type or all attributes if "theType" is empty. More...
virtual MODEL_EXPORT const std::string & id (const std::shared_ptr< ModelAPI_Attribute > &theAttr)
 Identifier by the id (not fast, iteration by map) More...
virtual MODEL_EXPORT bool isEqual (const std::shared_ptr< ModelAPI_Data > &theData)
 Returns true if data belongs to same features. More...
virtual MODEL_EXPORT bool isValid ()
 Returns true if it is correctly connected to the data model. More...
TDF_Label shapeLab () const
 Returns the label where the shape must be stored (used in ResultBody) More...
virtual MODEL_EXPORT AttributePtr addAttribute (const std::string &theID, const std::string theAttrType, const int theIndex=-1)
 Initializes object by the attributes: must be called just after the object is created for each attribute of the object. More...
virtual MODEL_EXPORT AttributePtr addFloatingAttribute (const std::string &theID, const std::string theAttrType, const std::string &theGroup)
 Adds a floating attribute (that may be added/removed during the data life) More...
virtual MODEL_EXPORT void allGroups (std::list< std::string > &theGroups)
 Returns all groups of this data (ordered). More...
virtual MODEL_EXPORT void attributesOfGroup (const std::string &theGroup, std::list< std::shared_ptr< ModelAPI_Attribute > > &theAttrs)
 Returns an ordered list of attributes that belong to the given group. More...
virtual MODEL_EXPORT void removeAttributes (const std::string &theGroup)
 Remove all attributes of the given group. More...
virtual MODEL_EXPORT void sendAttributeUpdated (ModelAPI_Attribute *theAttr)
 Useful method for "set" methods of the attributes: sends an UPDATE event and makes attribute initialized. More...
virtual MODEL_EXPORT bool blockSendAttributeUpdated (const bool theBlock, const bool theSendMessage=true)
MODEL_EXPORT void setLabel (TDF_Label theLab)
 Puts feature to the document data sub-structure. More...
virtual MODEL_EXPORT void setObject (ObjectPtr theObject)
 Sets the object of this data. More...
virtual MODEL_EXPORT void erase ()
 Erases all the data from the data model. More...
virtual MODEL_EXPORT void execState (const ModelAPI_ExecState theState)
 Stores the state of the object to execute it later accordingly. More...
virtual MODEL_EXPORT ModelAPI_ExecState execState ()
 Returns the state of the latest execution of the feature. More...
virtual MODEL_EXPORT void setError (const std::string &theError, bool theSend=true)
void eraseErrorString ()
 Erases the error string if it is not empty. More...
virtual MODEL_EXPORT std::string error () const
virtual MODEL_EXPORT int featureId () const
 Returns the identifier of feature-owner, unique in this document. More...
virtual MODEL_EXPORT const std::set< AttributePtr > & refsToMe ()
 returns all objects referenced to this More...
virtual MODEL_EXPORT void referencesToObjects (std::list< std::pair< std::string, std::list< ObjectPtr > > > &theRefs)
 returns all references by attributes of this data More...
virtual MODEL_EXPORT void copyTo (std::shared_ptr< ModelAPI_Data > theTarget)
 Copies all attributes content into theTarget data. More...
virtual MODEL_EXPORT std::shared_ptr< ModelAPI_Data > invalidPtr ()
 Returns the invalid data pointer (to avoid working with NULL shared pointers in swig) More...
virtual MODEL_EXPORT int updateID ()
 Identifier of the transaction when object (feature or result) was updated last time. More...
virtual MODEL_EXPORT void setUpdateID (const int theID)
virtual MODEL_EXPORT std::shared_ptr< ModelAPI_Object > owner ()
 Returns true if the given object is owner of this data (needed for correct erase of object with duplicated data) More...
static std::shared_ptr< ModelAPI_Data > invalidData ()
 Returns the invalid data pointer: static method. More...
virtual MODEL_EXPORT bool isInHistory ()
 Returns true if "is in history" custom behaviors is defined for the feature. More...
virtual MODEL_EXPORT void setIsInHistory (const bool theFlag)
 Defines the custom "is in history" behavior. More...
virtual MODEL_EXPORT bool isDeleted ()
 Returns true if the object is deleted, but some data is still kept in memory. More...
virtual MODEL_EXPORT void setIsDeleted (const bool theFlag)
 Sets true if the object is deleted, but some data is still kept in memory. More...
void clearAttributes ()
 Erases all attributes from myAttrs, but keeping them in the data structure. More...
Friends
class Model_Document
class Model_Objects
class Model_Update
class Model_AttributeReference
class Model_AttributeRefAttr
class Model_AttributeRefList
class Model_AttributeRefAttrList
class Model_AttributeSelection
class Model_AttributeSelectionList
class Model_ValidatorsFactory
class Model_SelectionNaming
class Model_ResultConstruction
class Model_ResultBody
class Model_Tools
◆ Model_Data()
Model_Data::Model_Data ( )
◆ name() [1/2]
std::wstring Model_Data::name ( )
Implements ModelAPI_Data.
◆ name() [2/2]
std::wstring Model_Data::name ( std::shared_ptr< GeomAPI_Shape >  theSubShape)
◆ setName()
void Model_Data::setName ( const std::wstring &  theName)
◆ hasUserDefinedName()
bool Model_Data::hasUserDefinedName ( ) const
◆ version()
std::string Model_Data::version ( )
◆ setVersion()
void Model_Data::setVersion ( const std::string &  theVersion)
◆ document()
std::shared_ptr< ModelAPI_AttributeDocRef > Model_Data::document ( const std::string &  theID)
◆ real()
std::shared_ptr< ModelAPI_AttributeDouble > Model_Data::real ( const std::string &  theID)
◆ realArray()
std::shared_ptr< ModelAPI_AttributeDoubleArray > Model_Data::realArray ( const std::string &  theID)
◆ integer()
std::shared_ptr< ModelAPI_AttributeInteger > Model_Data::integer ( const std::string &  theID)
◆ reference()
std::shared_ptr< ModelAPI_AttributeReference > Model_Data::reference ( const std::string &  theID)
◆ selection()
std::shared_ptr< ModelAPI_AttributeSelection > Model_Data::selection ( const std::string &  theID)
◆ selectionList()
std::shared_ptr< ModelAPI_AttributeSelectionList > Model_Data::selectionList ( const std::string &  theID)
◆ refattr()
std::shared_ptr< ModelAPI_AttributeRefAttr > Model_Data::refattr ( const std::string &  theID)
◆ reflist()
std::shared_ptr< ModelAPI_AttributeRefList > Model_Data::reflist ( const std::string &  theID)
◆ refattrlist()
std::shared_ptr< ModelAPI_AttributeRefAttrList > Model_Data::refattrlist ( const std::string &  theID)
◆ boolean()
std::shared_ptr< ModelAPI_AttributeBoolean > Model_Data::boolean ( const std::string &  theID)
◆ string()
std::shared_ptr< ModelAPI_AttributeString > Model_Data::string ( const std::string &  theID)
◆ intArray()
std::shared_ptr< ModelAPI_AttributeIntArray > Model_Data::intArray ( const std::string &  theID)
◆ stringArray()
std::shared_ptr< ModelAPI_AttributeStringArray > Model_Data::stringArray ( const std::string &  theID)
◆ tables()
std::shared_ptr< ModelAPI_AttributeTables > Model_Data::tables ( const std::string &  theID)
◆ image()
std::shared_ptr< ModelAPI_AttributeImage > Model_Data::image ( const std::string &  theID)
◆ attribute()
std::shared_ptr< ModelAPI_Attribute > Model_Data::attribute ( const std::string &  theID)
theIDidentifier of the attribute
◆ attributes()
std::list< std::shared_ptr< ModelAPI_Attribute > > Model_Data::attributes ( const std::string &  theType)
◆ attributesIDs()
std::list< std::string > Model_Data::attributesIDs ( const std::string &  theType)
◆ id()
const std::string & Model_Data::id ( const std::shared_ptr< ModelAPI_Attribute > &  theAttr)
theAttrattribute already created in this data
◆ isEqual()
bool Model_Data::isEqual ( const std::shared_ptr< ModelAPI_Data > &  theData)
◆ isValid()
bool Model_Data::isValid ( )
◆ shapeLab()
TDF_Label Model_Data::shapeLab ( ) const
◆ addAttribute()
AttributePtr Model_Data::addAttribute ( const std::string &  theID,
const int  theIndex = -1
theIDidentifier of the attribute that can be referenced by this ID later
theAttrTypetype of the created attribute (received from the type method)
theIndexindex of the attribute in the internal data structure, for not-floating attributes it is -1 to let it automatically be added
the just created attribute
◆ addFloatingAttribute()
AttributePtr Model_Data::addFloatingAttribute ( const std::string &  theID,
const std::string &  theGroup
theGroupidentifier of the group this attribute belongs to, may be an empty string
◆ allGroups()
void Model_Data::allGroups ( std::list< std::string > &  theGroups)
◆ attributesOfGroup()
void Model_Data::attributesOfGroup ( const std::string &  theGroup,
std::list< std::shared_ptr< ModelAPI_Attribute > > &  theAttrs
◆ removeAttributes()
void Model_Data::removeAttributes ( const std::string &  theGroup)
◆ sendAttributeUpdated()
void Model_Data::sendAttributeUpdated ( ModelAPI_Attribute *  theAttr)
◆ blockSendAttributeUpdated()
bool Model_Data::blockSendAttributeUpdated ( const bool  theBlock,
const bool  theSendMessage = true
theBlockallows switching on/off the blocking state
theSendMessageif false, it does not send the update message even if something is changed (normally is it used in attributeChanged because this message will be sent anyway)
the previous state of block
◆ setLabel()
void Model_Data::setLabel ( TDF_Label  theLab)
◆ setObject()
virtual MODEL_EXPORT void Model_Data::setObject ( ObjectPtr  theObject)
◆ erase()
void Model_Data::erase ( )
◆ execState() [1/2]
void Model_Data::execState ( const ModelAPI_ExecState  theState)
◆ execState() [2/2]
ModelAPI_ExecState Model_Data::execState ( )
◆ setError()
void Model_Data::setError ( const std::string &  theError,
bool  theSend = true
◆ eraseErrorString()
void Model_Data::eraseErrorString ( )
◆ error()
std::string Model_Data::error ( ) const
◆ featureId()
int Model_Data::featureId ( ) const
◆ refsToMe()
virtual MODEL_EXPORT const std::set< AttributePtr > & Model_Data::refsToMe ( )
◆ referencesToObjects()
void Model_Data::referencesToObjects ( std::list< std::pair< std::string, std::list< ObjectPtr > > > &  theRefs)
theRefsreturned list of pairs: id of referenced attribute and list of referenced objects
◆ copyTo()
void Model_Data::copyTo ( std::shared_ptr< ModelAPI_Data >  theTarget)
◆ invalidPtr()
std::shared_ptr< ModelAPI_Data > Model_Data::invalidPtr ( )
◆ invalidData()
std::shared_ptr< ModelAPI_Data > Model_Data::invalidData ( )
◆ updateID()
int Model_Data::updateID ( )
◆ setUpdateID()
void Model_Data::setUpdateID ( const int  theID)
This method is called by the updater.
◆ owner()
std::shared_ptr< ModelAPI_Object > Model_Data::owner ( )
◆ isInHistory()
bool Model_Data::isInHistory ( )
◆ setIsInHistory()
void Model_Data::setIsInHistory ( const bool  theFlag)
◆ isDeleted()
bool Model_Data::isDeleted ( )
◆ setIsDeleted()
void Model_Data::setIsDeleted ( const bool  theFlag)
◆ clearAttributes()
void Model_Data::clearAttributes ( )
