ModelAPI_Data Class Referenceabstract
General object of the application that allows to get/set attributes from the document and compute result of an operation. More...
#include <ModelAPI_Data.h>
Inheritance diagram for ModelAPI_Data:
virtual std::wstring name ()=0
 Returns the name of the feature visible by the user in the object browser. More...
virtual std::wstring name (std::shared_ptr< GeomAPI_Shape > theSubShape)=0
 Returns the name of the shape. More...
virtual void setName (const std::wstring &theName)=0
 Defines the name of the feature visible by the user in the object browser. More...
virtual bool hasUserDefinedName () const =0
 Return true if the object has been renamed by the user. More...
virtual std::string version ()=0
 Returns version of the feature (empty string if not applicable) More...
virtual void setVersion (const std::string &theVersion)=0
 Initialize the version of the feature. More...
virtual std::shared_ptr< ModelAPI_AttributeDocRef > document (const std::string &theID)=0
 Returns the attribute that references to another document. More...
virtual std::shared_ptr< ModelAPI_AttributeDouble > real (const std::string &theID)=0
 Returns the attribute that contains real value with double precision. More...
virtual std::shared_ptr< ModelAPI_AttributeDoubleArray > realArray (const std::string &theID)=0
 Returns the attribute that contains double values array. More...
virtual std::shared_ptr< ModelAPI_AttributeInteger > integer (const std::string &theID)=0
 Returns the attribute that contains integer value. More...
virtual std::shared_ptr< ModelAPI_AttributeReference > reference (const std::string &theID)=0
 Returns the attribute that contains reference to a feature. More...
virtual std::shared_ptr< ModelAPI_AttributeSelection > selection (const std::string &theID)=0
 Returns the attribute that contains selection to a shape. More...
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > selectionList (const std::string &theID)=0
virtual std::shared_ptr< ModelAPI_AttributeRefAttr > refattr (const std::string &theID)=0
 Returns the attribute that contains reference to an attribute of a feature. More...
virtual std::shared_ptr< ModelAPI_AttributeRefList > reflist (const std::string &theID)=0
 Returns the attribute that contains list of references to features. More...
virtual std::shared_ptr< ModelAPI_AttributeRefAttrList > refattrlist (const std::string &theID)=0
 Returns the attribute that contains list of references to features or reference to an attribute of a feature. More...
virtual std::shared_ptr< ModelAPI_AttributeBoolean > boolean (const std::string &theID)=0
 Returns the attribute that contains boolean value. More...
virtual std::shared_ptr< ModelAPI_AttributeString > string (const std::string &theID)=0
virtual std::shared_ptr< ModelAPI_AttributeIntArray > intArray (const std::string &theID)=0
 Returns the attribute that contains integer values array. More...
virtual std::shared_ptr< ModelAPI_AttributeStringArray > stringArray (const std::string &theID)=0
 Returns the attribute that contains string values array. More...
virtual std::shared_ptr< ModelAPI_AttributeImage > image (const std::string &theID)=0
 Returns the attribute that contains image. More...
virtual std::shared_ptr< ModelAPI_AttributeTables > tables (const std::string &theID)=0
 Returns the attribute that contains tables. More...
virtual std::shared_ptr< ModelAPI_Attribute > attribute (const std::string &theID)=0
 Returns the generic attribute by identifier. More...
virtual std::list< std::shared_ptr< ModelAPI_Attribute > > attributes (const std::string &theType)=0
 Returns all attributes of the feature of the given type or all attributes if "theType" is empty. More...
virtual std::list< std::string > attributesIDs (const std::string &theType)=0
 Returns all attributes ids of the feature of the given type or all attributes if "theType" is empty. More...
virtual const std::string & id (const std::shared_ptr< ModelAPI_Attribute > &theAttr)=0
 Identifier by the id (not fast, iteration by map) More...
virtual bool isEqual (const std::shared_ptr< ModelAPI_Data > &theData)=0
 Returns true if data belongs to same features. More...
virtual bool isValid ()=0
 Returns true if it is correctly connected to the data model. More...
virtual std::shared_ptr< ModelAPI_Attribute > addAttribute (const std::string &theID, const std::string theAttrType, const int theIndex=-1)=0
 Initializes object by the attributes: must be called just after the object is created for each attribute of the object. More...
virtual std::shared_ptr< ModelAPI_Attribute > addFloatingAttribute (const std::string &theID, const std::string theAttrType, const std::string &theGroup)=0
 Adds a floating attribute (that may be added/removed during the data life) More...
virtual void allGroups (std::list< std::string > &theGroups)=0
 Returns all groups of this data (ordered). More...
virtual void attributesOfGroup (const std::string &theGroup, std::list< std::shared_ptr< ModelAPI_Attribute > > &theAttrs)=0
 Returns an ordered list of attributes that belong to the given group. More...
virtual void removeAttributes (const std::string &theGroup)=0
 Remove all attributes of the given group. More...
virtual void sendAttributeUpdated (ModelAPI_Attribute *theAttr)=0
 Useful method for "set" methods of the attributes: sends an UPDATE event and makes attribute initialized. More...
virtual bool blockSendAttributeUpdated (const bool theBlock, const bool theSendMessage=true)=0
virtual void erase ()=0
 Erases all the data from the data model. More...
virtual ~ModelAPI_Data ()
 To virtually destroy the fields of successors. More...
virtual void execState (const ModelAPI_ExecState theState)=0
 Stores the state of the object to execute it later accordingly. More...
virtual ModelAPI_ExecState execState ()=0
 Returns the state of the latest execution of the feature. More...
virtual void setError (const std::string &theError, bool theSend=true)=0
virtual std::string error () const =0
virtual int featureId () const =0
 Returns the identifier of feature-owner, unique in this document. More...
virtual const std::set< std::shared_ptr< ModelAPI_Attribute > > & refsToMe ()=0
 returns all objects referenced to this More...
virtual void referencesToObjects (std::list< std::pair< std::string, std::list< std::shared_ptr< ModelAPI_Object > > > > &theRefs)=0
 returns all references by attributes of this data More...
virtual void copyTo (std::shared_ptr< ModelAPI_Data > theTarget)=0
 Copies all attributes content into theTarget data. More...
virtual std::shared_ptr< ModelAPI_Data > invalidPtr ()=0
 Returns the invalid data pointer (to avoid working with NULL shared pointers in swig) More...
virtual int updateID ()=0
 Identifier of the transaction when object (feature or result) was updated last time. More...
virtual void setUpdateID (const int theID)=0
virtual std::shared_ptr< ModelAPI_Object > owner ()=0
 Returns the owner of this data. More...
virtual bool isDeleted ()=0
 Returns true if the object is deleted, but some data is still kept in memory. More...
virtual void setIsDeleted (const bool theFlag)=0
 Sets true if the object is deleted, but some data is still kept in memory. More...
virtual bool isPrecedingAttribute (const std::string &theAttribute1, const std::string &theAttribute2) const =0
 Returns true if theAttribute1 is going earlier than theAttribute2 in the data. More...
 ModelAPI_Data ()
 Objects are created for features automatically. More...
virtual bool isInHistory ()=0
 Returns true if "is in history" custom behaviors is defined for the feature. More...
virtual void setIsInHistory (const bool theFlag)=0
 Defines the custom "is in history" behavior. More...
virtual bool isDisplayed ()=0
virtual void setDisplayed (const bool theDisplay)=0
Friends
class ModelAPI_Object
◆ ~ModelAPI_Data()
ModelAPI_Data::~ModelAPI_Data ( )
◆ ModelAPI_Data()
ModelAPI_Data::ModelAPI_Data ( )
◆ name() [1/2]
virtual std::wstring ModelAPI_Data::name ( )
pure virtual
Implemented in Model_Data.
◆ name() [2/2]
virtual std::wstring ModelAPI_Data::name ( std::shared_ptr< GeomAPI_Shape >  theSubShape)
pure virtual
◆ setName()
virtual void ModelAPI_Data::setName ( const std::wstring &  theName)
pure virtual
◆ hasUserDefinedName()
virtual bool ModelAPI_Data::hasUserDefinedName ( ) const
pure virtual
◆ version()
virtual std::string ModelAPI_Data::version ( )
pure virtual
◆ setVersion()
virtual void ModelAPI_Data::setVersion ( const std::string &  theVersion)
pure virtual
◆ document()
virtual std::shared_ptr< ModelAPI_AttributeDocRef > ModelAPI_Data::document ( const std::string &  theID)
pure virtual
◆ real()
virtual std::shared_ptr< ModelAPI_AttributeDouble > ModelAPI_Data::real ( const std::string &  theID)
pure virtual
◆ realArray()
virtual std::shared_ptr< ModelAPI_AttributeDoubleArray > ModelAPI_Data::realArray ( const std::string &  theID)
pure virtual
◆ integer()
virtual std::shared_ptr< ModelAPI_AttributeInteger > ModelAPI_Data::integer ( const std::string &  theID)
pure virtual
◆ reference()
virtual std::shared_ptr< ModelAPI_AttributeReference > ModelAPI_Data::reference ( const std::string &  theID)
pure virtual
◆ selection()
virtual std::shared_ptr< ModelAPI_AttributeSelection > ModelAPI_Data::selection ( const std::string &  theID)
pure virtual
◆ selectionList()
virtual std::shared_ptr< ModelAPI_AttributeSelectionList > ModelAPI_Data::selectionList ( const std::string &  theID)
pure virtual
◆ refattr()
virtual std::shared_ptr< ModelAPI_AttributeRefAttr > ModelAPI_Data::refattr ( const std::string &  theID)
pure virtual
◆ reflist()
virtual std::shared_ptr< ModelAPI_AttributeRefList > ModelAPI_Data::reflist ( const std::string &  theID)
pure virtual
◆ refattrlist()
virtual std::shared_ptr< ModelAPI_AttributeRefAttrList > ModelAPI_Data::refattrlist ( const std::string &  theID)
pure virtual
◆ boolean()
virtual std::shared_ptr< ModelAPI_AttributeBoolean > ModelAPI_Data::boolean ( const std::string &  theID)
pure virtual
◆ string()
virtual std::shared_ptr< ModelAPI_AttributeString > ModelAPI_Data::string ( const std::string &  theID)
pure virtual
◆ intArray()
virtual std::shared_ptr< ModelAPI_AttributeIntArray > ModelAPI_Data::intArray ( const std::string &  theID)
pure virtual
◆ stringArray()
virtual std::shared_ptr< ModelAPI_AttributeStringArray > ModelAPI_Data::stringArray ( const std::string &  theID)
pure virtual
◆ image()
virtual std::shared_ptr< ModelAPI_AttributeImage > ModelAPI_Data::image ( const std::string &  theID)
pure virtual
◆ tables()
virtual std::shared_ptr< ModelAPI_AttributeTables > ModelAPI_Data::tables ( const std::string &  theID)
pure virtual
◆ attribute()
virtual std::shared_ptr< ModelAPI_Attribute > ModelAPI_Data::attribute ( const std::string &  theID)
pure virtual
theIDidentifier of the attribute
◆ attributes()
virtual std::list< std::shared_ptr< ModelAPI_Attribute > > ModelAPI_Data::attributes ( const std::string &  theType)
pure virtual
◆ attributesIDs()
virtual std::list< std::string > ModelAPI_Data::attributesIDs ( const std::string &  theType)
pure virtual
◆ id()
virtual const std::string & ModelAPI_Data::id ( const std::shared_ptr< ModelAPI_Attribute > &  theAttr)
pure virtual
theAttrattribute already created in this data
◆ isEqual()
virtual bool ModelAPI_Data::isEqual ( const std::shared_ptr< ModelAPI_Data > &  theData)
pure virtual
◆ isValid()
virtual bool ModelAPI_Data::isValid ( )
pure virtual
◆ addAttribute()
virtual std::shared_ptr< ModelAPI_Attribute > ModelAPI_Data::addAttribute ( const std::string &  theID,
const int  theIndex = -1
pure virtual
theIDidentifier of the attribute that can be referenced by this ID later
theAttrTypetype of the created attribute (received from the type method)
theIndexindex of the attribute in the internal data structure, for not-floating attributes it is -1 to let it automatically be added
the just created attribute
◆ addFloatingAttribute()
virtual std::shared_ptr< ModelAPI_Attribute > ModelAPI_Data::addFloatingAttribute ( const std::string &  theID,
const std::string &  theGroup
pure virtual
theGroupidentifier of the group this attribute belongs to, may be an empty string
◆ allGroups()
virtual void ModelAPI_Data::allGroups ( std::list< std::string > &  theGroups)
pure virtual
◆ attributesOfGroup()
virtual void ModelAPI_Data::attributesOfGroup ( const std::string &  theGroup,
std::list< std::shared_ptr< ModelAPI_Attribute > > &  theAttrs
pure virtual
◆ removeAttributes()
virtual void ModelAPI_Data::removeAttributes ( const std::string &  theGroup)
pure virtual
◆ sendAttributeUpdated()
virtual void ModelAPI_Data::sendAttributeUpdated ( ModelAPI_Attribute *  theAttr)
pure virtual
◆ blockSendAttributeUpdated()
virtual bool ModelAPI_Data::blockSendAttributeUpdated ( const bool  theBlock,
const bool  theSendMessage = true
pure virtual
the previous state of block
◆ erase()
virtual void ModelAPI_Data::erase ( )
pure virtual
◆ execState() [1/2]
virtual void ModelAPI_Data::execState ( const ModelAPI_ExecState  theState)
pure virtual
◆ execState() [2/2]
virtual ModelAPI_ExecState ModelAPI_Data::execState ( )
pure virtual
◆ setError()
virtual void ModelAPI_Data::setError ( const std::string &  theError,
bool  theSend = true
pure virtual
◆ error()
virtual std::string ModelAPI_Data::error ( ) const
pure virtual
◆ featureId()
virtual int ModelAPI_Data::featureId ( ) const
pure virtual
◆ refsToMe()
virtual const std::set< std::shared_ptr< ModelAPI_Attribute > > & ModelAPI_Data::refsToMe ( )
pure virtual
◆ referencesToObjects()
virtual void ModelAPI_Data::referencesToObjects ( std::list< std::pair< std::string, std::list< std::shared_ptr< ModelAPI_Object > > > > &  theRefs)
pure virtual
theRefsreturned list of pairs: id of referenced attribute and list of referenced objects
◆ copyTo()
virtual void ModelAPI_Data::copyTo ( std::shared_ptr< ModelAPI_Data >  theTarget)
pure virtual
◆ invalidPtr()
virtual std::shared_ptr< ModelAPI_Data > ModelAPI_Data::invalidPtr ( )
pure virtual
◆ updateID()
virtual int ModelAPI_Data::updateID ( )
pure virtual
◆ setUpdateID()
virtual void ModelAPI_Data::setUpdateID ( const int  theID)
pure virtual
This method is called by the updater.
◆ owner()
virtual std::shared_ptr< ModelAPI_Object > ModelAPI_Data::owner ( )
pure virtual
◆ isDeleted()
virtual bool ModelAPI_Data::isDeleted ( )
pure virtual
◆ setIsDeleted()
virtual void ModelAPI_Data::setIsDeleted ( const bool  theFlag)
pure virtual
◆ isPrecedingAttribute()
virtual bool ModelAPI_Data::isPrecedingAttribute ( const std::string &  theAttribute1,
const std::string &  theAttribute2
pure virtual
◆ isInHistory()
virtual bool ModelAPI_Data::isInHistory ( )
protectedpure virtual
◆ setIsInHistory()
virtual void ModelAPI_Data::setIsInHistory ( const bool  theFlag)
◆ isDisplayed()
virtual bool ModelAPI_Data::isDisplayed ( )
◆ setDisplayed()
virtual void ModelAPI_Data::setDisplayed ( const bool  theDisplay)
