ModelAPI_AttributeDouble Class Referenceabstract
Attribute that contains real value with double precision. More...
#include <ModelAPI_AttributeDouble.h>
Inheritance diagram for ModelAPI_AttributeDouble:
virtual MODELAPI_EXPORT void setValue (const double theValue)=0
 Defines the double value. More...
virtual MODELAPI_EXPORT double value ()=0
 Returns the double value. More...
virtual MODELAPI_EXPORT void setCalculatedValue (const double theValue)=0
 Defines the calculated double value. More...
virtual MODELAPI_EXPORT void setText (const std::wstring &theText)=0
 Defines the text value. More...
virtual MODELAPI_EXPORT std::wstring text ()=0
 Returns the text value. More...
virtual MODELAPI_EXPORT void setExpressionInvalid (const bool theFlag)=0
 Allows to set expression (text) as invalid (by the parameters listener) More...
virtual MODELAPI_EXPORT bool expressionInvalid ()=0
 Returns true if text is invalid. More...
virtual MODELAPI_EXPORT void setExpressionError (const std::string &theError)=0
 Allows to set expression (text) error (by the parameters listener) More...
virtual MODELAPI_EXPORT std::string expressionError ()=0
 Returns an expression error. More...
virtual MODELAPI_EXPORT void setUsedParameters (const std::set< std::wstring > &theUsedParameters)=0
 Defines the used parameters. More...
virtual MODELAPI_EXPORT std::set< std::wstring > usedParameters () const =0
 Returns the used parameters. More...
virtual MODELAPI_EXPORT std::string attributeType ()
virtual MODELAPI_EXPORT ~ModelAPI_AttributeDouble ()
 To virtually destroy the fields of successors. More...
virtual bool isInitialized ()
void setInitialized ()
bool isArgument ()
bool isImmutable ()
virtual void reset ()
static MODELAPI_EXPORT std::string typeId ()
MODELAPI_EXPORT ModelAPI_AttributeDouble ()
 Objects are created for features automatically. More...
virtual void reinit ()
bool myIsInitialized
bool mySetInitializedBlocked
bool myIsArgument
bool myIsImmutable
◆ ~ModelAPI_AttributeDouble()
ModelAPI_AttributeDouble::~ModelAPI_AttributeDouble ( )
◆ ModelAPI_AttributeDouble()
ModelAPI_AttributeDouble::ModelAPI_AttributeDouble ( )
◆ setValue()
virtual MODELAPI_EXPORT void ModelAPI_AttributeDouble::setValue ( const double  theValue)
pure virtual
Implemented in Model_AttributeDouble.
◆ value()
virtual MODELAPI_EXPORT double ModelAPI_AttributeDouble::value ( )
pure virtual
◆ setCalculatedValue()
virtual MODELAPI_EXPORT void ModelAPI_AttributeDouble::setCalculatedValue ( const double  theValue)
pure virtual
◆ setText()
virtual MODELAPI_EXPORT void ModelAPI_AttributeDouble::setText ( const std::wstring &  theText)
pure virtual
◆ text()
virtual MODELAPI_EXPORT std::wstring ModelAPI_AttributeDouble::text ( )
pure virtual
◆ setExpressionInvalid()
virtual MODELAPI_EXPORT void ModelAPI_AttributeDouble::setExpressionInvalid ( const bool  theFlag)
pure virtual
◆ expressionInvalid()
virtual MODELAPI_EXPORT bool ModelAPI_AttributeDouble::expressionInvalid ( )
pure virtual
◆ setExpressionError()
virtual MODELAPI_EXPORT void ModelAPI_AttributeDouble::setExpressionError ( const std::string &  theError)
pure virtual
◆ expressionError()
virtual MODELAPI_EXPORT std::string ModelAPI_AttributeDouble::expressionError ( )
pure virtual
◆ setUsedParameters()
virtual MODELAPI_EXPORT void ModelAPI_AttributeDouble::setUsedParameters ( const std::set< std::wstring > &  theUsedParameters)
pure virtual
◆ usedParameters()
virtual MODELAPI_EXPORT std::set< std::wstring > ModelAPI_AttributeDouble::usedParameters ( ) const
pure virtual
◆ typeId()
static MODELAPI_EXPORT std::string ModelAPI_AttributeDouble::typeId ( )
inlinestatic
◆ attributeType()
std::string ModelAPI_AttributeDouble::attributeType ( )
◆ setObject()
◆ owner()
◆ isInitialized()
◆ setInitialized()
◆ blockSetInitialized()
theBlocka block value
the previous block value
◆ setIsArgument()
By default it is true.
◆ isArgument()
◆ setImmutable()
◆ isImmutable()
◆ id()
◆ reset()
void ModelAPI_Attribute::reset ( )
◆ setID()
◆ reinit()
◆ myIsInitialized
◆ mySetInitializedBlocked
◆ myIsArgument
◆ myIsImmutable
