Model_AttributeDouble Class Reference
Attribute that contains real value with double precision. More...
#include <Model_AttributeDouble.h>
Inheritance diagram for Model_AttributeDouble:
virtual void setValue (const double theValue)
 Defines the double value. More...
virtual double value ()
 Returns the double value. More...
virtual void setCalculatedValue (const double theValue)
 Defines the calculated double value. More...
virtual void setText (const std::wstring &theText)
 Defines the text value. More...
virtual std::wstring text ()
 Returns the text value. More...
virtual void setExpressionInvalid (const bool theFlag)
 Allows to set expression (text) as invalid (by the parameters listener) More...
virtual bool expressionInvalid ()
 Returns true if text is invalid. More...
virtual void setExpressionError (const std::string &theError)
 Allows to set expression (text) error (by the parameters listener) More...
virtual std::string expressionError ()
 Returns an expression error. More...
virtual void setUsedParameters (const std::set< std::wstring > &theUsedParameters)
 Defines the used parameters. More...
virtual std::set< std::wstring > usedParameters () const
 Returns the used parameters. More...
virtual MODELAPI_EXPORT std::string attributeType ()
virtual bool isInitialized ()
void setInitialized ()
bool isArgument ()
bool isImmutable ()
static MODELAPI_EXPORT std::string typeId ()
 Model_AttributeDouble (TDF_Label &theLabel)
 Initializes attributes. More...
virtual void reinit ()
virtual void reset ()
bool myIsInitialized
bool mySetInitializedBlocked
bool myIsArgument
bool myIsImmutable
Friends
class Model_Data
◆ Model_AttributeDouble()
Model_AttributeDouble::Model_AttributeDouble ( TDF_Label &  theLabel)
◆ setValue()
void Model_AttributeDouble::setValue ( const double  theValue)
Implements ModelAPI_AttributeDouble.
◆ value()
double Model_AttributeDouble::value ( )
◆ setCalculatedValue()
void Model_AttributeDouble::setCalculatedValue ( const double  theValue)
◆ setText()
void Model_AttributeDouble::setText ( const std::wstring &  theText)
◆ text()
std::wstring Model_AttributeDouble::text ( )
◆ setExpressionInvalid()
void Model_AttributeDouble::setExpressionInvalid ( const bool  theFlag)
◆ expressionInvalid()
bool Model_AttributeDouble::expressionInvalid ( )
◆ setExpressionError()
void Model_AttributeDouble::setExpressionError ( const std::string &  theError)
◆ expressionError()
std::string Model_AttributeDouble::expressionError ( )
◆ setUsedParameters()
void Model_AttributeDouble::setUsedParameters ( const std::set< std::wstring > &  theUsedParameters)
◆ usedParameters()
std::set< std::wstring > Model_AttributeDouble::usedParameters ( ) const
◆ reinit()
void Model_AttributeDouble::reinit ( )
Reimplemented from ModelAPI_Attribute.
◆ reset()
void Model_AttributeDouble::reset ( )
◆ typeId()
static MODELAPI_EXPORT std::string ModelAPI_AttributeDouble::typeId ( )
inlinestaticinherited
◆ attributeType()
std::string ModelAPI_AttributeDouble::attributeType ( )
◆ setObject()
◆ owner()
◆ isInitialized()
◆ setInitialized()
◆ blockSetInitialized()
theBlocka block value
the previous block value
◆ setIsArgument()
By default it is true.
◆ isArgument()
◆ setImmutable()
◆ isImmutable()
◆ id()
◆ setID()
◆ myIsInitialized
◆ mySetInitializedBlocked
◆ myIsArgument
◆ myIsImmutable
