Model_AttributeRefAttrList Class Reference
Attribute that contains list of references to features (located in the same document) or references to attributes of the features (list of AttributeRefAttr) More...
#include <Model_AttributeRefAttrList.h>
Inheritance diagram for Model_AttributeRefAttrList:
virtual void append (ObjectPtr theObject)
 Appends the feature to the end of a list. More...
virtual void append (AttributePtr theAttr)
 Appends the attribute to the end of a list. More...
virtual void remove (ObjectPtr theObject)
 Erases the first meet of the feature in the list. More...
virtual void remove (AttributePtr theAttr)
 Erases the first meet of the attribute in the list. More...
virtual void clear ()
 Removes all references from the list. More...
virtual int size () const
 Returns number of features in the list. More...
virtual std::list< std::pair< ObjectPtr, AttributePtr > > list ()
 Returns the list of features and attributes (if it is reference to the attribute) More...
virtual bool isInList (const ObjectPtr &theObj)
 Returns true if the object is in list. More...
virtual bool isInList (const AttributePtr &theObj)
 Returns true if the attribute is in list. More...
virtual bool isAttribute (const int theIndex) const
 Returns true if this is reference to an attribute, not just object. More...
virtual ObjectPtr object (const int theIndex) const
 Returns the referenced object by the zero-based index. More...
virtual AttributePtr attribute (const int theIndex) const
 Returns the referenced attribute by the zero-based index. More...
virtual void removeLast ()
 Removes the last element in the list. More...
virtual void remove (const std::set< int > &theIndices)
 Removes the elements from the list. More...
virtual bool isInitialized ()
virtual std::string attributeType ()
void setInitialized ()
bool isArgument ()
bool isImmutable ()
virtual void reset ()
static std::string typeId ()
 Model_AttributeRefAttrList (TDF_Label &theLabel)
 Objects are created for features automatically. More...
virtual void reinit ()
bool myIsInitialized
bool mySetInitializedBlocked
bool myIsArgument
bool myIsImmutable
Friends
class Model_Data
◆ Model_AttributeRefAttrList()
Model_AttributeRefAttrList::Model_AttributeRefAttrList ( TDF_Label &  theLabel)
◆ append() [1/2]
void Model_AttributeRefAttrList::append ( ObjectPtr  theObject)
Implements ModelAPI_AttributeRefAttrList.
◆ append() [2/2]
void Model_AttributeRefAttrList::append ( AttributePtr  theAttr)
◆ remove() [1/3]
void Model_AttributeRefAttrList::remove ( ObjectPtr  theObject)
◆ remove() [2/3]
void Model_AttributeRefAttrList::remove ( AttributePtr  theAttr)
◆ clear()
void Model_AttributeRefAttrList::clear ( )
◆ size()
int Model_AttributeRefAttrList::size ( ) const
◆ list()
std::list< std::pair< ObjectPtr, AttributePtr > > Model_AttributeRefAttrList::list ( )
◆ isInList() [1/2]
bool Model_AttributeRefAttrList::isInList ( const ObjectPtr &  theObj)
◆ isInList() [2/2]
bool Model_AttributeRefAttrList::isInList ( const AttributePtr &  theObj)
◆ isAttribute()
bool Model_AttributeRefAttrList::isAttribute ( const int  theIndex) const
◆ object()
ObjectPtr Model_AttributeRefAttrList::object ( const int  theIndex) const
theIndexzero-based index in the list
◆ attribute()
AttributePtr Model_AttributeRefAttrList::attribute ( const int  theIndex) const
◆ removeLast()
void Model_AttributeRefAttrList::removeLast ( )
◆ remove() [3/3]
void Model_AttributeRefAttrList::remove ( const std::set< int > &  theIndices)
theIndicesa list of indices of elements to be removed
◆ isInitialized()
bool Model_AttributeRefAttrList::isInitialized ( )
Reimplemented from ModelAPI_Attribute.
◆ reinit()
void Model_AttributeRefAttrList::reinit ( )
◆ typeId()
static std::string ModelAPI_AttributeRefAttrList::typeId ( )
inlinestaticinherited
◆ attributeType()
std::string ModelAPI_AttributeRefAttrList::attributeType ( )
◆ setObject()
◆ owner()
◆ setInitialized()
◆ blockSetInitialized()
theBlocka block value
the previous block value
◆ setIsArgument()
By default it is true.
◆ isArgument()
◆ setImmutable()
◆ isImmutable()
◆ id()
◆ reset()
void ModelAPI_Attribute::reset ( )
◆ setID()
◆ myIsInitialized
◆ mySetInitializedBlocked
◆ myIsArgument
◆ myIsImmutable
