Model_AttributeRefAttrList.h
20#ifndef Model_AttributeRefAttrList_H_
21#define Model_AttributeRefAttrList_H_
23#include "Model.h"
24#include "ModelAPI_AttributeRefAttrList.h"
25#include "ModelAPI_Feature.h"
26
27#include <TDF_Label.hxx>
28#include <TDataStd_ReferenceList.hxx>
29#include <TDataStd_ExtStringList.hxx>
30
38{
39 TDF_Label myLab;
40 Handle_TDataStd_ReferenceList myRef;
41 Handle_TDataStd_ExtStringList myIDs;
42 public:
44 MODEL_EXPORT virtual void append(ObjectPtr theObject);
46 MODEL_EXPORT virtual void append(AttributePtr theAttr);
47
49 MODEL_EXPORT virtual void remove(ObjectPtr theObject);
51 MODEL_EXPORT virtual void remove(AttributePtr theAttr);
52
54 MODEL_EXPORT virtual void clear();
55
57 MODEL_EXPORT virtual int size() const;
58
60 MODEL_EXPORT virtual std::list<std::pair<ObjectPtr, AttributePtr> > list();
61
63 MODEL_EXPORT virtual bool isInList(const ObjectPtr& theObj);
65 MODEL_EXPORT virtual bool isInList(const AttributePtr& theObj);
66
68 MODEL_EXPORT virtual bool isAttribute(const int theIndex) const;
69
72 MODEL_EXPORT virtual ObjectPtr object(const int theIndex) const;
75 MODEL_EXPORT virtual AttributePtr attribute(const int theIndex) const;
76
78 MODEL_EXPORT virtual void removeLast();
79
82 MODEL_EXPORT virtual void remove(const std::set<int>& theIndices);
83
85 MODEL_EXPORT virtual bool isInitialized();
86 protected:
88 MODEL_EXPORT Model_AttributeRefAttrList(TDF_Label& theLabel);
90 virtual void reinit();
91
92 friend class Model_Data;
93};
94
95#endif
Attribute that contains list of references to features (located in the same document) or references t...
Definition: ModelAPI_AttributeRefAttrList.h:34
Definition: Model_AttributeRefAttrList.h:38
virtual std::list< std::pair< ObjectPtr, AttributePtr > > list()
Returns the list of features and attributes (if it is reference to the attribute)
Definition: Model_AttributeRefAttrList.cpp:150
Returns true if attribute was initialized by some value.
Definition: Model_AttributeRefAttrList.cpp:142
Returns number of features in the list.
Definition: Model_AttributeRefAttrList.cpp:137
virtual bool isInList(const ObjectPtr &theObj)
Returns true if the object is in list.
Definition: Model_AttributeRefAttrList.cpp:174
Reinitializes the internal state of the attribute (may be needed on undo/redo, abort,...
Definition: Model_AttributeRefAttrList.cpp:334
Appends the feature to the end of a list.
Definition: Model_AttributeRefAttrList.cpp:28
Returns true if this is reference to an attribute, not just object.
Definition: Model_AttributeRefAttrList.cpp:227
Model_AttributeRefAttrList(TDF_Label &theLabel)
Definition: Model_AttributeRefAttrList.cpp:328
Erases the first meet of the feature in the list.
Definition: Model_AttributeRefAttrList.cpp:58
Returns the referenced object by the zero-based index.
Definition: Model_AttributeRefAttrList.cpp:241
Removes the last element in the list.
Definition: Model_AttributeRefAttrList.cpp:285
Removes all references from the list.
Definition: Model_AttributeRefAttrList.cpp:125
Returns the referenced attribute by the zero-based index.
Definition: Model_AttributeRefAttrList.cpp:261
General object of the application that allows to get/set attributes from the document and compute res...
Definition: Model_Data.h:62
