GeomData_Dir Class Reference
Attribute that contains direction. More...
#include <GeomData_Dir.h>
Inheritance diagram for GeomData_Dir:
virtual void setValue (const double theX, const double theY, const double theZ)
 Defines the double value. More...
virtual void setValue (const std::shared_ptr< GeomAPI_Dir > &theDir)
 Defines the direction. More...
virtual double x () const
 Returns the X double value. More...
virtual double y () const
 Returns the Y double value. More...
virtual double z () const
 Returns the Z double value. More...
virtual std::shared_ptr< GeomAPI_Dir > dir ()
 Returns the direction of this attribute. More...
virtual std::shared_ptr< GeomAPI_XYZ > xyz ()
 Returns the coordinates of this attribute. More...
virtual bool isInitialized ()
 Returns true if the direction is initialized. More...
virtual void reset ()
virtual std::string attributeType ()
void setInitialized ()
bool isArgument ()
bool isImmutable ()
static std::string typeId ()
 GeomData_Dir (TDF_Label &theLabel)
 Initializes attributes. More...
virtual void reinit ()
bool myIsInitialized
bool mySetInitializedBlocked
bool myIsArgument
bool myIsImmutable
Friends
class Model_Data
◆ GeomData_Dir()
GeomData_Dir::GeomData_Dir ( TDF_Label &  theLabel)
◆ setValue() [1/2]
void GeomData_Dir::setValue ( const double  theX,
const double  theY,
const double  theZ
Implements GeomDataAPI_Dir.
◆ setValue() [2/2]
void GeomData_Dir::setValue ( const std::shared_ptr< GeomAPI_Dir > &  theDir)
◆ x()
double GeomData_Dir::x ( ) const
◆ y()
double GeomData_Dir::y ( ) const
◆ z()
double GeomData_Dir::z ( ) const
◆ dir()
std::shared_ptr< GeomAPI_Dir > GeomData_Dir::dir ( )
◆ xyz()
std::shared_ptr< GeomAPI_XYZ > GeomData_Dir::xyz ( )
◆ isInitialized()
bool GeomData_Dir::isInitialized ( )
Reimplemented from ModelAPI_Attribute.
◆ reset()
void GeomData_Dir::reset ( )
◆ reinit()
void GeomData_Dir::reinit ( )
◆ typeId()
static std::string GeomDataAPI_Dir::typeId ( )
inlinestaticinherited
◆ attributeType()
std::string GeomDataAPI_Dir::attributeType ( )
◆ setObject()
◆ owner()
◆ setInitialized()
◆ blockSetInitialized()
theBlocka block value
the previous block value
◆ setIsArgument()
By default it is true.
◆ isArgument()
◆ setImmutable()
◆ isImmutable()
◆ id()
◆ setID()
◆ myIsInitialized
◆ mySetInitializedBlocked
◆ myIsArgument
◆ myIsImmutable
