GeomAPI_Dir Class Reference
3D direction defined by three normalized coordinates More...
#include <GeomAPI_Dir.h>
Inheritance diagram for GeomAPI_Dir:
GEOMAPI_EXPORT GeomAPI_Dir (const double theX, const double theY, const double theZ)
 Creation of direction by coordinates. More...
GEOMAPI_EXPORT GeomAPI_Dir (const std::shared_ptr< GeomAPI_XYZ > &theCoords)
GEOMAPI_EXPORT double x () const
 returns X coordinate More...
GEOMAPI_EXPORT double y () const
 returns Y coordinate More...
GEOMAPI_EXPORT double z () const
 returns Z coordinate More...
GEOMAPI_EXPORT const std::shared_ptr< GeomAPI_XYZ > xyz ()
 returns coordinates of the direction More...
GEOMAPI_EXPORT void reverse ()
 inverses the direction More...
GEOMAPI_EXPORT double dot (const std::shared_ptr< GeomAPI_Dir > &theArg) const
 result is a scalar product of directions More...
GEOMAPI_EXPORT const std::shared_ptr< GeomAPI_XYZ > cross (const std::shared_ptr< GeomAPI_Dir > &theArg) const
 result is a cross product of two directions More...
GEOMAPI_EXPORT double angle (const std::shared_ptr< GeomAPI_Dir > &theArg) const
 calculates angle between two directions More...
GEOMAPI_EXPORT bool isParallel (const std::shared_ptr< GeomAPI_Dir > theDir, const double theTolerance=1.e-7) const
template<class T >
T * implPtr ()
template<class T >
const T * implPtr () const
template<class T >
const T & impl () const
template<class T >
void setImpl (T *theImpl)
◆ GeomAPI_Dir() [1/2]
GeomAPI_Dir::GeomAPI_Dir ( const double  theX,
const double  theY,
const double  theZ
◆ GeomAPI_Dir() [2/2]
GeomAPI_Dir::GeomAPI_Dir ( const std::shared_ptr< GeomAPI_XYZ > &  theCoords)
◆ x()
double GeomAPI_Dir::x ( ) const
◆ y()
double GeomAPI_Dir::y ( ) const
◆ z()
double GeomAPI_Dir::z ( ) const
◆ xyz()
const std::shared_ptr< GeomAPI_XYZ > GeomAPI_Dir::xyz ( )
◆ reverse()
void GeomAPI_Dir::reverse ( )
◆ dot()
double GeomAPI_Dir::dot ( const std::shared_ptr< GeomAPI_Dir > &  theArg) const
◆ cross()
const std::shared_ptr< GeomAPI_XYZ > GeomAPI_Dir::cross ( const std::shared_ptr< GeomAPI_Dir > &  theArg) const
◆ angle()
double GeomAPI_Dir::angle ( const std::shared_ptr< GeomAPI_Dir > &  theArg) const
◆ isParallel()
bool GeomAPI_Dir::isParallel ( const std::shared_ptr< GeomAPI_Dir >  theDir,
const double  theTolerance = 1.e-7
true if the angle between this unit vector and theDir unit vector is equal to 0 or to Pi.
◆ implPtr() [1/2]
template<class T >
◆ implPtr() [2/2]
template<class T >
◆ impl()
template<class T >
◆ setImpl()
template<class T >
◆ empty()
