Represents any object in the data model and in the object browser. More...
#include <ModelAPI_Object.h>
| virtual std::string | groupName ()=0 |
| Returns the group identifier of this object. More... | |
| virtual void | initAttributes ()=0 |
| Request for initialization of data model of the object: adding all attributes. More... | |
| virtual bool | isDisabled ()=0 |
| ModelAPI_Object () | |
| Initializes the default states of the object. More... | |
| virtual | ~ModelAPI_Object () |
| To use virtuality for destructors. More... | |
| virtual void | init ()=0 |
| virtual void | erase () |
| removes all fields from this feature More... | |
Friends | |
| class | Model_Objects |
| class | ModelAPI_Feature |
| class | Model_Document |
It may be feature or result of the feature. User just may set name for it or change this name later. Generic class for Feature, Body, Parameter and other objects related to the features and their results. Contains attributes of this object in the "Data".
| ModelAPI_Object::ModelAPI_Object | ( | ) |
Reimplemented in Model_ResultField::Model_FieldStep, and ModelAPI_Feature.
pure virtual |
Implemented in ModelAPI_Feature, ModelAPI_Folder, ModelAPI_ResultBody, ModelAPI_ResultConstruction, ModelAPI_ResultField::ModelAPI_FieldStep, ModelAPI_ResultField, ModelAPI_ResultGroup, ModelAPI_ResultParameter, and ModelAPI_ResultPart.
pure virtual |
Implemented in BuildPlugin_Compound, BuildPlugin_CompSolid, BuildPlugin_Edge, BuildPlugin_Face, BuildPlugin_Filling, BuildPlugin_Interpolation, BuildPlugin_Polyline, BuildPlugin_Shell, BuildPlugin_Solid, BuildPlugin_SubShapes, BuildPlugin_Vertex, BuildPlugin_Wire, CollectionPlugin_Field, CollectionPlugin_Group, CollectionPlugin_GroupIntersection, CollectionPlugin_GroupMerge, CollectionPlugin_GroupSubstraction, ConstructionPlugin_Axis, ConstructionPlugin_Plane, ConstructionPlugin_Point, ExchangePlugin_Dump, ExchangePlugin_ExportFeature, ExchangePlugin_ExportPart, ExchangePlugin_ImportBase, ExchangePlugin_Import, ExchangePlugin_ImportFeatureBase, ExchangePlugin_ImportFeature, ExchangePlugin_ImportPart, FeaturesPlugin_Boolean, FeaturesPlugin_BooleanCommon, FeaturesPlugin_BooleanCut, FeaturesPlugin_BooleanFill, FeaturesPlugin_BooleanFuse, FeaturesPlugin_BooleanSmash, FeaturesPlugin_BoundingBox, FeaturesPlugin_Chamfer, FeaturesPlugin_Copy, FeaturesPlugin_Defeaturing, FeaturesPlugin_Extrusion, FeaturesPlugin_ExtrusionBoolean, FeaturesPlugin_Fillet, FeaturesPlugin_Fillet1D, FeaturesPlugin_FusionFaces, FeaturesPlugin_GeometryCalculation, FeaturesPlugin_GlueFaces, FeaturesPlugin_GroupSharedFaces, FeaturesPlugin_ImportResult, FeaturesPlugin_InspectBoundingBox, FeaturesPlugin_InspectNormalToFace, FeaturesPlugin_Intersection, FeaturesPlugin_LimitTolerance, FeaturesPlugin_Loft, FeaturesPlugin_Measurement, FeaturesPlugin_MultiRotation, FeaturesPlugin_MultiTranslation, FeaturesPlugin_NormalToFace, FeaturesPlugin_Offset, FeaturesPlugin_Partition, FeaturesPlugin_Pipe, FeaturesPlugin_Placement, FeaturesPlugin_PointCloudOnFace, FeaturesPlugin_PointCoordinates, FeaturesPlugin_Recover, FeaturesPlugin_RemoveExtraEdges, FeaturesPlugin_RemoveResults, FeaturesPlugin_RemoveSubShapes, FeaturesPlugin_Revolution, FeaturesPlugin_RevolutionBoolean, FeaturesPlugin_Rotation, FeaturesPlugin_Scale, FeaturesPlugin_Sewing, FeaturesPlugin_SharedFaces, FeaturesPlugin_Symmetry, FeaturesPlugin_Thickness, FeaturesPlugin_Translation, FeaturesPlugin_Union, GDMLPlugin_ConeSegment, GDMLPlugin_Ellipsoid, Model_SelectionInPartFeature, Model_SelectionInResult, Model_ResultBody, Model_ResultParameter, Model_ResultPart, ModelAPI_Folder, ModelAPI_Result, ModelAPI_ResultField::ModelAPI_FieldStep, ParametersPlugin_Parameter, ParametersPlugin_ParametersMgr, PartSetPlugin_Duplicate, PartSetPlugin_Part, PartSetPlugin_Remove, PrimitivesPlugin_Box, PrimitivesPlugin_Cone, PrimitivesPlugin_Cylinder, PrimitivesPlugin_Sphere, PrimitivesPlugin_Torus, PrimitivesPlugin_Tube, SamplePanelPlugin_Feature, SketchPlugin_ConstraintAngle, SketchPlugin_ConstraintCoincidence, SketchPlugin_ConstraintCoincidenceInternal, SketchPlugin_ConstraintCollinear, SketchPlugin_ConstraintDistance, SketchPlugin_ConstraintDistanceAlongDir, SketchPlugin_ConstraintEqual, SketchPlugin_ConstraintHorizontal, SketchPlugin_ConstraintLength, SketchPlugin_ConstraintMiddle, SketchPlugin_ConstraintMirror, SketchPlugin_ConstraintParallel, SketchPlugin_ConstraintPerpendicular, SketchPlugin_ConstraintRadius, SketchPlugin_ConstraintRigid, SketchPlugin_ConstraintTangent, SketchPlugin_ConstraintVertical, SketchPlugin_Fillet, SketchPlugin_Line, SketchPlugin_MacroArc, SketchPlugin_MacroBSpline, SketchPlugin_MacroCircle, SketchPlugin_MacroEllipse, SketchPlugin_MacroEllipticArc, SketchPlugin_MultiRotation, SketchPlugin_MultiTranslation, SketchPlugin_Offset, SketchPlugin_Sketch, SketchPlugin_SketchCopy, SketchPlugin_SketchDrawer, SketchPlugin_SketchEntity, SketchPlugin_Split, SketchPlugin_Trim, FiltersPlugin_Selection, and ModelAPI_ResultParameter.
pure virtual |
Implemented in ModelAPI_Feature, ModelAPI_Folder, ModelAPI_Result, and ModelAPI_ResultField::ModelAPI_FieldStep.
inlinevirtual |
inlinevirtual |
protectedpure virtual |
protectedvirtual |
protectedvirtual |
protectedvirtual |
Reimplemented in ModelAPI_CompositeFeature, ModelAPI_Feature, PartSetPlugin_Part, SketchPlugin_ConstraintMirror, SketchPlugin_MultiRotation, and SketchPlugin_MultiTranslation.
inlinevirtualinherited |
