ConstructionPlugin_Point Class Reference
Feature for creation of the new part in PartSet. More...
#include <ConstructionPlugin_Point.h>
Inheritance diagram for ConstructionPlugin_Point:
virtual void execute ()
 ConstructionPlugin_Point ()
virtual bool customisePresentation (ResultPtr theResult, AISObjectPtr thePrs)
 Customize presentation of the feature. More...
 sets the alone result More...
virtual bool isAction ()
std::wstring name ()
virtual bool isInHistory ()
virtual bool isDisplayed ()
virtual bool hasTexture ()
static const std::string & DEFAULT_COLOR ()
 Default color for a point. More...
static const std::string & COLOR_NAME ()
 Default color property name. More...
 Point kind. More...
static const std::string & CREATION_METHOD ()
 Attribute name for creation method. More...
static const std::string & CREATION_METHOD_BY_XYZ ()
static const std::string & CREATION_METHOD_BY_DISTANCE_ON_EDGE ()
static const std::string & CREATION_METHOD_BY_PROJECTION ()
static const std::string & CREATION_METHOD_BY_INTERSECTION ()
static const std::string & CREATION_METHOD_BY_GEOMETRICAL_PROPERTY ()
static const std::string & POINT3D ()
static const std::string & EDGE ()
 Attribute name for selected edge. More...
static const std::string & OFFSET_TYPE ()
 Attribute name for offset type on selected edge. More...
static const std::string & OFFSET_TYPE_BY_DISTANCE ()
 Attribute name for offset type by distance. More...
static const std::string & OFFSET_TYPE_BY_RATIO ()
 Attribute name for offset type by ratio. More...
static const std::string & DISTANCE ()
 Attribute name for distance. More...
static const std::string & RATIO ()
 Attribute name for percent flag. More...
static const std::string & REVERSE ()
 Attribute name for reverse flag. More...
static const std::string & POINT_TO_PROJECT ()
 Attribute name for point to projection. More...
static const std::string & PROJECTION_TYPE ()
 Attribute name for projection type. More...
static const std::string & PROJECTION_TYPE_ON_EDGE ()
 Attribute name for projection type on edge. More...
static const std::string & PROJECTION_TYPE_ON_FACE ()
 Attribute name for projection type on face. More...
static const std::string & EDGE_FOR_POINT_PROJECTION ()
 Attribute name for edge for point projection. More...
static const std::string & FACE_FOR_POINT_PROJECTION ()
 Attribute name for face for point projection. More...
static const std::string & INTERSECTION_TYPE ()
 Attribute name for intersection type. More...
static const std::string & INTERSECTION_TYPE_BY_LINES ()
 Attribute name for intersection type by lines. More...
static const std::string & INTERSECTION_TYPE_BY_LINE_AND_PLANE ()
 Attribute name for intersection type by line and plane. More...
static const std::string & INTERSECTION_TYPE_BY_PLANES ()
 Attribute name for intersection type by planes. More...
static const std::string & INTERSECTION_LINE_1 ()
 Attribute name for selected first intersection line. More...
static const std::string & INTERSECTION_LINE_2 ()
 Attribute name for selected second intersection line. More...
static const std::string & INTERSECTION_LINE ()
 Attribute name for selected intersection line. More...
static const std::string & INTERSECTION_PLANE ()
 Attribute name for selected intersection plane. More...
static const std::string & USE_OFFSET ()
 Attribute name for use offset for the intersection plane. More...
static const std::string & OFFSET ()
 Attribute name for offset for the intersection plane. More...
static const std::string & REVERSE_OFFSET ()
 Attribute name for reverse offset for the intersection plane. More...
static const std::string & INTERSECTION_PLANE_1 ()
static const std::string & INTERSECTION_PLANE_2 ()
static const std::string & INTERSECTION_PLANE_3 ()
static const std::string & GEOMETRICAL_PROPERTY_TYPE ()
 Attribute name for property type. More...
static const std::string & GEOMETRICAL_PROPERTY_TYPE_BY_CENTER_OF_GRAVITY ()
 Attribute name for property type by center of gravity. More...
static const std::string & GEOMETRICAL_PROPERTY_TYPE_BY_CENTER_OF_CIRCLE ()
 Attribute name for property type by center of circle. More...
static const std::string & OBJECT_FOR_CENTER_OF_GRAVITY ()
 Attribute name for selected object for center of gravity. More...
static const std::string & OBJECT_FOR_CENTER_OF_CIRCLE ()
 Attribute name for selected object for center of cricle. More...
static std::string group ()
◆ ConstructionPlugin_Point()
ConstructionPlugin_Point::ConstructionPlugin_Point ( )
◆ getKind()
const std::string & ConstructionPlugin_Point::getKind ( )
Implements ModelAPI_Feature.
◆ DEFAULT_COLOR()
static const std::string & ConstructionPlugin_Point::DEFAULT_COLOR ( )
inlinestatic
◆ COLOR_NAME()
static const std::string & ConstructionPlugin_Point::COLOR_NAME ( )
inlinestatic
◆ ID()
static const std::string & ConstructionPlugin_Point::ID ( )
inlinestatic
Point kind.
◆ CREATION_METHOD()
static const std::string & ConstructionPlugin_Point::CREATION_METHOD ( )
inlinestatic
◆ CREATION_METHOD_BY_XYZ()
static const std::string & ConstructionPlugin_Point::CREATION_METHOD_BY_XYZ ( )
inlinestatic
◆ CREATION_METHOD_BY_DISTANCE_ON_EDGE()
static const std::string & ConstructionPlugin_Point::CREATION_METHOD_BY_DISTANCE_ON_EDGE ( )
inlinestatic
◆ CREATION_METHOD_BY_PROJECTION()
static const std::string & ConstructionPlugin_Point::CREATION_METHOD_BY_PROJECTION ( )
inlinestatic
◆ CREATION_METHOD_BY_INTERSECTION()
static const std::string & ConstructionPlugin_Point::CREATION_METHOD_BY_INTERSECTION ( )
inlinestatic
◆ CREATION_METHOD_BY_GEOMETRICAL_PROPERTY()
static const std::string & ConstructionPlugin_Point::CREATION_METHOD_BY_GEOMETRICAL_PROPERTY ( )
inlinestatic
◆ EDGE()
static const std::string & ConstructionPlugin_Point::EDGE ( )
inlinestatic
◆ OFFSET_TYPE()
static const std::string & ConstructionPlugin_Point::OFFSET_TYPE ( )
inlinestatic
◆ OFFSET_TYPE_BY_DISTANCE()
static const std::string & ConstructionPlugin_Point::OFFSET_TYPE_BY_DISTANCE ( )
inlinestatic
◆ OFFSET_TYPE_BY_RATIO()
static const std::string & ConstructionPlugin_Point::OFFSET_TYPE_BY_RATIO ( )
inlinestatic
◆ DISTANCE()
static const std::string & ConstructionPlugin_Point::DISTANCE ( )
inlinestatic
◆ RATIO()
static const std::string & ConstructionPlugin_Point::RATIO ( )
inlinestatic
◆ REVERSE()
static const std::string & ConstructionPlugin_Point::REVERSE ( )
inlinestatic
◆ POINT_TO_PROJECT()
static const std::string & ConstructionPlugin_Point::POINT_TO_PROJECT ( )
inlinestatic
◆ PROJECTION_TYPE()
static const std::string & ConstructionPlugin_Point::PROJECTION_TYPE ( )
inlinestatic
◆ PROJECTION_TYPE_ON_EDGE()
static const std::string & ConstructionPlugin_Point::PROJECTION_TYPE_ON_EDGE ( )
inlinestatic
◆ PROJECTION_TYPE_ON_FACE()
static const std::string & ConstructionPlugin_Point::PROJECTION_TYPE_ON_FACE ( )
inlinestatic
◆ EDGE_FOR_POINT_PROJECTION()
static const std::string & ConstructionPlugin_Point::EDGE_FOR_POINT_PROJECTION ( )
inlinestatic
◆ FACE_FOR_POINT_PROJECTION()
static const std::string & ConstructionPlugin_Point::FACE_FOR_POINT_PROJECTION ( )
inlinestatic
◆ INTERSECTION_TYPE()
static const std::string & ConstructionPlugin_Point::INTERSECTION_TYPE ( )
inlinestatic
◆ INTERSECTION_TYPE_BY_LINES()
static const std::string & ConstructionPlugin_Point::INTERSECTION_TYPE_BY_LINES ( )
inlinestatic
◆ INTERSECTION_TYPE_BY_LINE_AND_PLANE()
static const std::string & ConstructionPlugin_Point::INTERSECTION_TYPE_BY_LINE_AND_PLANE ( )
inlinestatic
◆ INTERSECTION_TYPE_BY_PLANES()
static const std::string & ConstructionPlugin_Point::INTERSECTION_TYPE_BY_PLANES ( )
inlinestatic
◆ INTERSECTION_LINE_1()
static const std::string & ConstructionPlugin_Point::INTERSECTION_LINE_1 ( )
inlinestatic
◆ INTERSECTION_LINE_2()
static const std::string & ConstructionPlugin_Point::INTERSECTION_LINE_2 ( )
inlinestatic
◆ INTERSECTION_LINE()
static const std::string & ConstructionPlugin_Point::INTERSECTION_LINE ( )
inlinestatic
◆ INTERSECTION_PLANE()
static const std::string & ConstructionPlugin_Point::INTERSECTION_PLANE ( )
inlinestatic
◆ USE_OFFSET()
static const std::string & ConstructionPlugin_Point::USE_OFFSET ( )
inlinestatic
◆ OFFSET()
static const std::string & ConstructionPlugin_Point::OFFSET ( )
inlinestatic
◆ REVERSE_OFFSET()
static const std::string & ConstructionPlugin_Point::REVERSE_OFFSET ( )
inlinestatic
◆ INTERSECTION_PLANE_1()
static const std::string & ConstructionPlugin_Point::INTERSECTION_PLANE_1 ( )
inlinestatic
◆ INTERSECTION_PLANE_2()
static const std::string & ConstructionPlugin_Point::INTERSECTION_PLANE_2 ( )
inlinestatic
◆ INTERSECTION_PLANE_3()
static const std::string & ConstructionPlugin_Point::INTERSECTION_PLANE_3 ( )
inlinestatic
◆ GEOMETRICAL_PROPERTY_TYPE()
static const std::string & ConstructionPlugin_Point::GEOMETRICAL_PROPERTY_TYPE ( )
inlinestatic
◆ GEOMETRICAL_PROPERTY_TYPE_BY_CENTER_OF_GRAVITY()
static const std::string & ConstructionPlugin_Point::GEOMETRICAL_PROPERTY_TYPE_BY_CENTER_OF_GRAVITY ( )
inlinestatic
◆ GEOMETRICAL_PROPERTY_TYPE_BY_CENTER_OF_CIRCLE()
static const std::string & ConstructionPlugin_Point::GEOMETRICAL_PROPERTY_TYPE_BY_CENTER_OF_CIRCLE ( )
inlinestatic
◆ OBJECT_FOR_CENTER_OF_GRAVITY()
static const std::string & ConstructionPlugin_Point::OBJECT_FOR_CENTER_OF_GRAVITY ( )
inlinestatic
◆ OBJECT_FOR_CENTER_OF_CIRCLE()
static const std::string & ConstructionPlugin_Point::OBJECT_FOR_CENTER_OF_CIRCLE ( )
inlinestatic
◆ execute()
void ConstructionPlugin_Point::execute ( )
◆ initAttributes()
void ConstructionPlugin_Point::initAttributes ( )
Implements ModelAPI_Object.
◆ customisePresentation()
bool ConstructionPlugin_Point::customisePresentation ( ResultPtr  theResult,
AISObjectPtr  thePrs
Implements GeomAPI_ICustomPrs.
◆ group()
inlinestaticinherited
◆ document() [1/2]
inlinevirtualinherited
◆ document() [2/2]
◆ groupName()
◆ compute()
◆ setError()
bool  isSend = true,
bool  isTranslate = true
◆ error()
◆ results()
◆ firstResult()
◆ lastResult()
◆ setResult() [1/2]
◆ setResult() [2/2]
const int  theIndex
◆ removeResults()
const bool  theFlush = true
◆ eraseResults()
◆ erase()
◆ eraseResultFromList()
only internally
◆ isPersistentResult()
◆ isAction()
◆ isMacro()
◆ isPreviewNeeded()
◆ documentToAdd()
◆ setDisabled()
Enables/disables the feature.
◆ isDisabled()
◆ feature()
◆ setStable()
Set the stable feature flag.
◆ isStable()
◆ isEditable()
◆ customAction()
theActionIdan action key
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ boolean()
◆ real()
◆ integer()
◆ intArray()
◆ refattr()
◆ refattrlist()
◆ reference()
◆ reflist()
◆ selection()
◆ selectionList()
◆ string()
◆ stringArray()
◆ tables()
◆ attribute()
◆ init()
◆ isInHistory()
◆ setInHistory()
const bool  theFlag
◆ data()
◆ isSame()
◆ colorConfigInfo()
std::string &  ,
std::string &
◆ attributeChanged()
◆ isDisplayed()
◆ setDisplayed()
◆ hasTexture()
◆ setData()
◆ setDoc()
◆ emptyFunction()
