Feature for creation of a new arc filleting two objects which have coincident point. More...
#include <SketchPlugin_Fillet.h>
| virtual void | execute () |
| virtual AISObjectPtr | getAISObject (AISObjectPtr thePrevious) |
| Returns the AIS preview. More... | |
| virtual bool | isMacro () const |
| Reimplemented from ModelAPI_Feature::isMacro(). More... | |
| virtual bool | isPreviewNeeded () const |
| virtual void | move (const double, const double) |
| Reimplemented from SketchPlugin_Feature::move(). More... | |
| SketchPlugin_Fillet () | |
| virtual bool | isExternal () const |
| Returns true of the feature is created basing on the external shape of not-this-sketch object. More... | |
| virtual bool | isCopy () const |
| Returns true of the feature is a copy of other feature. More... | |
| Returns true if this feature must be displayed in the history (top level of Part tree) More... | |
| virtual bool | canBeDisplayed () const |
| Returns true if the feature and the feature results can be displayed. More... | |
| virtual bool | isFixed () |
| Returns true is sketch element is under the rigid constraint. More... | |
| SketchPlugin_Sketch * | sketch () |
| Returns the sketch of this feature. More... | |
| std::wstring | name () |
| Feature kind. More... | |
| static const std::string & | FILLET_POINT_ID () |
| Attribute name of fillet point. More... | |
| static const std::string & | AUXILIARY_ID () |
| Reference to the construction type of the feature. More... | |
| static const std::string & | EXTERNAL_ID () |
| Reference to the external edge or vertex as a AttributeSelection. More... | |
| static const std::string & | COPY_ID () |
| Reference to the copy type of the feature. More... | |
| static const std::string & | PARENT_ID () |
| Reference to the parent feature if exist. More... | |
| static const int | SKETCH_LINE_WIDTH_AUXILIARY () |
| Width of the auxiliary line. More... | |
| static const int | SKETCH_LINE_WIDTH () |
| Width of the line. More... | |
| static const int | SKETCH_LINE_STYLE_AUXILIARY () |
| Style of the auxiliary line. More... | |
| static const int | SKETCH_LINE_STYLE () |
| Style of the line. More... | |
| virtual void | initDerivedClassAttributes () |
| Initializes attributes of derived class. More... | |
| virtual void | initDerivedClassAttributes2 () |
| Initializes attributes of derived class which were added recently. More... | |
| void | setSketch (SketchPlugin_Sketch *theSketch) |
| Sets the higher-level feature for the sub-feature (sketch for line) More... | |
| void | keepCurrentFeature () |
| Store current feature of the document if it is not the sub-feature of the current sketch. More... | |
| void | restoreCurrentFeature () |
| Restore current feature of the document after adding new feature to the sketch. More... | |
| SketchPlugin_Fillet::SketchPlugin_Fillet | ( | ) |
inlinestatic |
Feature kind.
inlinestatic |
inlinevirtual |
Implements ModelAPI_Feature.
Reimplemented from SketchPlugin_SketchEntity.
inlinevirtual |
inlinevirtual |
inlinevirtual |
Do nothing.
inlinestaticinherited |
Width of the line.
Style of the line.
inlinevirtualinherited |
Reimplemented from SketchPlugin_Feature.
Reimplemented in SketchPlugin_Arc, SketchPlugin_BSpline, SketchPlugin_BSplineBase, SketchPlugin_Circle, SketchPlugin_CurveFitting, SketchPlugin_Ellipse, SketchPlugin_EllipticArc, SketchPlugin_IntersectionPoint, SketchPlugin_Line, SketchPlugin_Point, and SketchPlugin_Projection.
Reimplemented in SketchPlugin_Projection.
Reimplemented in SketchPlugin_Arc, SketchPlugin_BSplineBase, SketchPlugin_Circle, SketchPlugin_Ellipse, SketchPlugin_EllipticArc, SketchPlugin_IntersectionPoint, SketchPlugin_Line, SketchPlugin_Point, and SketchPlugin_Projection.
inlineprotectedinherited |
inlineinherited |
Implements ModelAPI_Object.
only internally
staticinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
