Model_ResultPart Class Reference
The Part document, result of a creation of new part feature. More...
#include <Model_ResultPart.h>
Inheritance diagram for Model_ResultPart:
 Request for initialization of data model of the result: adding all attributes. More...
virtual std::shared_ptr< ModelAPI_Document > partDoc ()
 Returns the part-document of this result. More...
virtual std::shared_ptr< ModelAPI_ResultPart > original ()
 Returns the original part result: for transformation features results this is the original Part feature result. More...
virtual void activate ()
 Sets this document as current and if it is not loaded yet, loads it. More...
virtual bool setDisabled (std::shared_ptr< ModelAPI_Result > theThis, const bool theFlag)
 disable all feature of the part on disable of the part result More...
virtual std::shared_ptr< GeomAPI_Shape > shape ()
 Result shape of part document is compound of bodies inside of this part. More...
virtual std::wstring nameInPart (const std::shared_ptr< GeomAPI_Shape > &theShape, int &theIndex)
 Returns the name of the shape inside of the part. More...
virtual bool updateInPart (const int theIndex)
 Updates the selection inside of the part by the selection index. More...
virtual std::shared_ptr< GeomAPI_Shape > shapeInPart (const std::wstring &theName, const std::string &theType, int &theIndex)
 Returns the shape by the name in the part. More...
virtual void setSubShapeColor (const std::shared_ptr< GeomAPI_Shape > &theShape, const std::vector< int > &theColor)
 Set color on subshape. More...
virtual void getSubShapeColor (const std::shared_ptr< GeomAPI_Shape > &theShape, std::vector< int > &theColor)
 Get color on subshape. More...
virtual void getColoredSubShapes (std::map< std::shared_ptr< GeomAPI_Shape >, std::vector< int > > &theColoredSubShapes)
 Get colored shapes from result. More...
virtual void removeSubShapeColors ()
 Forget subshape colors. More...
virtual bool combineGeometrical (const int theIndex, std::wstring &theNewName)
 Updates the selection inside of the part as a geometrical selection. More...
virtual void updateShape ()
 Updates the shape-result of the part (called on Part feature execution) More...
virtual void setTrsf (std::shared_ptr< ModelAPI_Result > theThis, const std::shared_ptr< GeomAPI_Trsf > &theTransformation)
 Applies the additional transformation of the part. More...
virtual std::shared_ptr< GeomAPI_Trsf > summaryTrsf ()
 Returns the summary transformations of all references to the origin. More...
virtual void colorConfigInfo (std::string &theSection, std::string &theName, std::string &theDefault)
virtual std::shared_ptr< GeomAPI_Shape > selectionValue (const int theIndex)
 Returns the shape selected in the selection index. More...
virtual void loadPart ()
 Loading the part from file. More...
virtual std::shared_ptr< ModelAPI_AttributeSelection > selection ()
 Return Attribute selection. More...
virtual bool isConcealed ()
 Returns true if the result is concealed from the data tree (referenced by other objects) More...
virtual void setIsConcealed (const bool theValue, const bool theForced=false)
 Sets the result as concealed in the data tree (referenced by other objects) More...
virtual bool isDisabled ()
 Returns the result is disabled or not. More...
 Returns all the vertices of this result. More...
 Returns all the edges of this result. More...
 Returns all the wires of this result. More...
 Returns all the faces of this result. More...
 Returns all the shells of this result. More...
 Returns all the solids of this result. More...
 On change of attribute of the result update presentation of this result: for the current moment there are only presentation attributes assigned to results. More...
virtual bool isInHistory ()
virtual bool isDisplayed ()
virtual bool hasTexture ()
static const std::string & BASE_REF_ID ()
 the reference to the base result document, may be null if this is the root, others make sequence of references More...
static std::string group ()
static const std::string & DOC_REF ()
 part document reference attribute More...
static const std::string & DEFAULT_COLOR ()
 default color for a result body More...
static const std::string & COLOR_ID ()
 Reference to the color of the result. More...
static const std::string & DEFLECTION_ID ()
 Reference to the deflection of the result. More...
static const std::string & TRANSPARENCY_ID ()
 Reference to the transparency of the result. More...
static const std::string & ISO_LINES_ID ()
static const std::string & SHOW_ISO_LINES_ID ()
static const std::string & SHOW_EDGES_DIRECTION_ID ()
static const std::string & BRING_TO_FRONT_ID ()
 Reference to the BringToFront flag of the result. More...
 Model_ResultPart ()
 makes a result on a temporary feature (an action) More...
gp_Trsf sumTrsf ()
 returns sum of transformations of the whole sequence of transformation-parts More...
virtual bool isActivated ()
 Returns true if document is activated (loaded into the memory) More...
virtual void init ()
virtual void erase ()
 removes all fields from this feature More...
bool myIsDisabled
 the result is disabled: removed for the user, but keeps the general info More...
Friends
class Model_Objects
This result leaves without feature: no parametricity for this element, only add/remove, undo/redo.
◆ Model_ResultPart()
Model_ResultPart::Model_ResultPart ( )
◆ BASE_REF_ID()
static const std::string & Model_ResultPart::BASE_REF_ID ( )
inlinestatic
◆ initAttributes()
void Model_ResultPart::initAttributes ( )
Reimplemented from ModelAPI_Result.
◆ partDoc()
std::shared_ptr< ModelAPI_Document > Model_ResultPart::partDoc ( )
Implements ModelAPI_ResultPart.
◆ original()
std::shared_ptr< ModelAPI_ResultPart > Model_ResultPart::original ( )
◆ activate()
void Model_ResultPart::activate ( )
◆ setDisabled()
bool Model_ResultPart::setDisabled ( std::shared_ptr< ModelAPI_Result >  theThis,
const bool  theFlag
◆ shape()
std::shared_ptr< GeomAPI_Shape > Model_ResultPart::shape ( )
◆ nameInPart()
std::wstring Model_ResultPart::nameInPart ( const std::shared_ptr< GeomAPI_Shape > &  theShape,
int &  theIndex
theShapeselected shape in this document
theIndexis returned as one-based index if selection was required, "0" otherwise
empty name is selection is not correct
◆ updateInPart()
bool Model_ResultPart::updateInPart ( const int  theIndex)
◆ shapeInPart()
std::shared_ptr< GeomAPI_Shape > Model_ResultPart::shapeInPart ( const std::wstring &  theName,
const std::string &  theType,
int &  theIndex
◆ setSubShapeColor()
void Model_ResultPart::setSubShapeColor ( const std::shared_ptr< GeomAPI_Shape > &  theShape,
const std::vector< int > &  theColor
◆ getSubShapeColor()
void Model_ResultPart::getSubShapeColor ( const std::shared_ptr< GeomAPI_Shape > &  theShape,
◆ getColoredSubShapes()
void Model_ResultPart::getColoredSubShapes ( std::map< std::shared_ptr< GeomAPI_Shape >, std::vector< int > > &  theColoredSubShapes)
◆ removeSubShapeColors()
void Model_ResultPart::removeSubShapeColors ( )
◆ combineGeometrical()
bool Model_ResultPart::combineGeometrical ( const int  theIndex,
std::wstring &  theNewName
◆ updateShape()
void Model_ResultPart::updateShape ( )
◆ setTrsf()
void Model_ResultPart::setTrsf ( std::shared_ptr< ModelAPI_Result >  theThis,
const std::shared_ptr< GeomAPI_Trsf > &  theTransformation
◆ summaryTrsf()
std::shared_ptr< GeomAPI_Trsf > Model_ResultPart::summaryTrsf ( )
◆ colorConfigInfo()
void Model_ResultPart::colorConfigInfo ( std::string &  theSection,
std::string &  theName,
std::string &  theDefault
Returns the parameters of color definition in the resources config manager.
◆ selectionValue()
std::shared_ptr< GeomAPI_Shape > Model_ResultPart::selectionValue ( const int  theIndex)
◆ loadPart()
void Model_ResultPart::loadPart ( )
◆ selection()
std::shared_ptr< ModelAPI_AttributeSelection > Model_ResultPart::selection ( )
◆ sumTrsf()
gp_Trsf Model_ResultPart::sumTrsf ( )
◆ isActivated()
bool Model_ResultPart::isActivated ( )
◆ groupName()
std::string ModelAPI_ResultPart::groupName ( )
Implements ModelAPI_Object.
◆ group()
static std::string ModelAPI_ResultPart::group ( )
inlinestaticinherited
◆ DOC_REF()
static const std::string & ModelAPI_ResultPart::DOC_REF ( )
◆ DEFAULT_COLOR()
static const std::string & ModelAPI_ResultPart::DEFAULT_COLOR ( )
◆ COLOR_ID()
static const std::string & ModelAPI_Result::COLOR_ID ( )
The integer array is used. It contains three values for red, green and blue values. The values are in [0, 255] range
◆ DEFLECTION_ID()
static const std::string & ModelAPI_Result::DEFLECTION_ID ( )
The double value is used. The value is in [0, 1] range
◆ TRANSPARENCY_ID()
static const std::string & ModelAPI_Result::TRANSPARENCY_ID ( )
◆ ISO_LINES_ID()
static const std::string & ModelAPI_Result::ISO_LINES_ID ( )
◆ SHOW_ISO_LINES_ID()
static const std::string & ModelAPI_Result::SHOW_ISO_LINES_ID ( )
◆ SHOW_EDGES_DIRECTION_ID()
static const std::string & ModelAPI_Result::SHOW_EDGES_DIRECTION_ID ( )
◆ BRING_TO_FRONT_ID()
static const std::string & ModelAPI_Result::BRING_TO_FRONT_ID ( )
The bool value is used.
◆ isConcealed()
bool ModelAPI_Result::isConcealed ( )
◆ setIsConcealed()
void ModelAPI_Result::setIsConcealed ( const bool  theValue,
const bool  theForced = false
Reimplemented in Model_ResultBody, and Model_ResultConstruction.
◆ isDisabled()
bool ModelAPI_Result::isDisabled ( )
◆ vertices()
ListOfShape ModelAPI_Result::vertices ( const bool  theOnlyUnique = false)
◆ edges()
ListOfShape ModelAPI_Result::edges ( const bool  theOnlyUnique = false)
◆ wires()
ListOfShape ModelAPI_Result::wires ( const bool  theOnlyUnique = false)
◆ faces()
ListOfShape ModelAPI_Result::faces ( const bool  theOnlyUnique = false)
◆ shells()
ListOfShape ModelAPI_Result::shells ( const bool  theOnlyUnique = false)
◆ solids()
ListOfShape ModelAPI_Result::solids ( const bool  theOnlyUnique = false)
◆ attributeChanged()
void ModelAPI_Result::attributeChanged ( const std::string &  theID)
◆ init()
void ModelAPI_Result::init ( )
◆ isInHistory()
◆ setInHistory()
const bool  theFlag
◆ data()
◆ isSame()
◆ document()
std::shared_ptr< ModelAPI_Document > ModelAPI_Object::document ( ) const
Reimplemented in Model_ResultField::Model_FieldStep, and ModelAPI_Feature.
◆ isDisplayed()
◆ setDisplayed()
◆ hasTexture()
inlinevirtualinherited
◆ setData()
◆ setDoc()
◆ erase()
void ModelAPI_Object::erase ( )
◆ emptyFunction()
◆ myIsDisabled
bool ModelAPI_Result::myIsDisabled
