Feature for export shapes to the external files in CAD formats. More...
#include <ExchangePlugin_ExportFeature.h>
| EXCHANGEPLUGIN_EXPORT | ExchangePlugin_ExportFeature () |
| virtual EXCHANGEPLUGIN_EXPORT | ~ExchangePlugin_ExportFeature () |
| Default destructor. More... | |
| virtual EXCHANGEPLUGIN_EXPORT const std::string & | getKind () |
| Returns the unique kind of a feature. More... | |
| virtual EXCHANGEPLUGIN_EXPORT void | initAttributes () |
| virtual EXCHANGEPLUGIN_EXPORT void | attributeChanged (const std::string &theID) |
| Reimplemented from ModelAPI_Feature::attributeChanged() More... | |
| virtual EXCHANGEPLUGIN_EXPORT void | execute () |
| virtual EXCHANGEPLUGIN_EXPORT bool | isMacro () const |
| Reimplemented from ModelAPI_Feature::isMacro(). Returns false. More... | |
| virtual EXCHANGEPLUGIN_EXPORT bool | isPreviewNeeded () const |
| Reimplemented from ModelAPI_Feature::isPreviewNeeded(). Returns false. More... | |
| bool | isInHistory () |
| Do not put in history. More... | |
| std::wstring | name () |
| Feature kind. More... | |
| static const std::string & | EXPORT_TYPE_ID () |
| attribute name for file format More... | |
| static const std::string & | FILE_PATH_ID () |
| attribute name of file path More... | |
| static const std::string & | XAO_FILE_PATH_ID () |
| attribute name of xao file path More... | |
| static const std::string & | STL_FILE_PATH_ID () |
| attribute name of stl file path More... | |
| static const std::string & | STL_OBJECT_SELECTED () |
| Attribute name for selected object to export in stl file path. More... | |
| static const std::string & | STL_DEFLECTION_TYPE () |
| Attribute name for deflection type. More... | |
| static const std::string & | STL_DEFLECTION_TYPE_RELATIVE () |
| Attribute name for deflection type relative. More... | |
| static const std::string & | STL_DEFLECTION_TYPE_ABSOLUTE () |
| Attribute name for deflection type absolute. More... | |
| static const std::string & | STL_RELATIVE () |
| Attribute name for relative. More... | |
| static const std::string & | STL_ABSOLUTE () |
| Attribute name for absolute. More... | |
| static const std::string & | STL_FILE_TYPE () |
| Attribute name for stl file type. More... | |
| static const std::string & | STL_FILE_TYPE_ASCII () |
| Attribute name for stl file type ascii. More... | |
| static const std::string & | STL_FILE_TYPE_BINARY () |
| Attribute name for stl file type binary. More... | |
| static const std::string & | FILE_FORMAT_ID () |
| attribute name of file format More... | |
| static const std::string & | SELECTION_LIST_ID () |
| attribute name of selection list More... | |
| static const std::string & | XAO_SELECTION_LIST_ID () |
| attribute name of xao selection list More... | |
| static const std::string & | XAO_AUTHOR_ID () |
| attribute name of author for XAO format More... | |
| static const std::string & | XAO_GEOMETRY_NAME_ID () |
| attribute name of geometry name for XAO format More... | |
| static const std::string & | XAO_SHAPE_FILE_PATH_ID () |
| attribute name of xao shape file path More... | |
| static const std::string & | XAO_SHAPE_FILE_SEPARATE_ID () |
| attribute flag to export shape in a separate file during xao export, name of shape file will be xao_file_path + .brep More... | |
| static const std::string & | MEMORY_BUFFER_ID () |
| attribute string memory buffer More... | |
| EXCHANGEPLUGIN_EXPORT void | exportFile (const std::string &theFileName, const std::string &theFormat, const bool isMemoryExport) |
| Performs export of the file. More... | |
| EXCHANGEPLUGIN_EXPORT void | exportXAO (const std::string &theFileName, const bool isMemoryExport) |
| Performs export to XAO file. More... | |
| EXCHANGEPLUGIN_EXPORT void | exportSTL (const std::string &theFileName) |
| Performs export to STL file. More... | |
| EXCHANGEPLUGIN_EXPORT void | exportSTEP (const std::string &theFileName) |
| Performs export to STEP file. More... | |
The list of supported formats is defined in the configuration file.
| ExchangePlugin_ExportFeature::ExchangePlugin_ExportFeature | ( | ) |
Default destructor.
inlinestatic |
Feature kind.
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinestatic |
inlinevirtual |
Implements ModelAPI_Feature.
Implements ModelAPI_Object.
inlinevirtual |
inlinevirtual |
Since it is not a macro, it is not deleted, but we don't want to see it.
protected |
do not export pictures
protected |
documents of Parts selected and used in export
translation of the part
protected |
protected |
inlinestaticinherited |
inlinevirtualinherited |
inlineinherited |
only internally
staticinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
protectedvirtualinherited |
