Duplicates the active part (not root). More...
#include <PartSetPlugin_Duplicate.h>
| virtual const std::string & | getGroup () |
| Returns to which group in the document must be added feature. More... | |
| Not normal feature that stored in the tree. More... | |
| virtual void | execute () |
| Performs the "duplicate". More... | |
| PartSetPlugin_Duplicate () | |
| std::wstring | name () |
| Duplicate kind. More... | |
Creates a new "part" feature.
inline |
inlinestatic |
Duplicate kind.
inlinevirtual |
Implements ModelAPI_Feature.
inlinevirtual |
inlinevirtual |
Implements ModelAPI_Object.
inlinevirtual |
inlinestaticinherited |
inlinevirtualinherited |
inlineinherited |
only internally
staticinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
inlineinherited |
protectedvirtualinherited |
