SketchPlugin_Split Class Reference
Feature for creation of a new constraint splitting object. More...
#include <SketchPlugin_Split.h>
Inheritance diagram for SketchPlugin_Split:
virtual void execute ()
virtual bool isMacro () const
 Reimplemented from ModelAPI_Feature::isMacro(). More...
virtual bool isPreviewNeeded () const
 Reimplemented from ModelAPI_Feature::isPreviewNeeded(). More...
 SketchPlugin_Split ()
virtual std::string processEvent (const std::shared_ptr< Events_Message > &theMessage)
 Apply information of the message to current object. It fills selected point and object. More...
virtual bool isInHistory ()
virtual bool isCopy () const
virtual bool isFixed ()
 sets the alone result More...
virtual bool isAction ()
std::wstring name ()
virtual bool isDisplayed ()
virtual bool hasTexture ()
 Split constraint kind. More...
static const std::string & SELECTED_OBJECT ()
static const std::string & SELECTED_POINT ()
 Start 2D point of the split segment. More...
static const std::string & PREVIEW_OBJECT ()
 The value parameter for the preview object. More...
static const std::string & PREVIEW_POINT ()
static std::string group ()
void keepCurrentFeature ()
void restoreCurrentFeature ()
Entities for split:
  • Linear segment by point(s) on this line
  • Circular/elliptic arc by point(s) on this arc
  • Circle/ellipse by at least 2 split-points on it
The following constraints will be applied after split to keep the divided segments geometry:
  • Coincident constraints for both parts of created segments in the point of splitting
  • For linear segments parallel, for circles/ellipses - tangent constraint, for arc - tangent and equal constraints. In case of three segments in result two couple of constraints are created
    • parallel and equal constraints: the first is between 1st and middle entity, the second is between 1st and 3rd.
    • tangency constraints: the first between 1st and 2nd, the second between 2nd and 3rd.
  • Constraints assigned to the feature before split operation are assigned after using rules:
    • Coincident constraints are assigned to the segment where they belong to. Segment of split has only a coincidence to the neighbor segment. All constraints used in the splitting of this segment are moved to point of neighbor segment. If constraint was initially built to the point of splitting segment, it stays for this point.
    • Geometrical and dimensional constraints are assigned to one of result segment, not the selected for split. In case of 3 result segments, this will be the segment nearest to the start point of arc/line.
    • Replication constraint used split feature will be deleted in the same way as it is deleted by any of entity delete in sketch which is used in this constraint.
◆ SketchPlugin_Split()
SketchPlugin_Split::SketchPlugin_Split ( )
◆ ID()
static const std::string & SketchPlugin_Split::ID ( )
inlinestatic
◆ getKind()
virtual const std::string & SketchPlugin_Split::getKind ( )
Implements ModelAPI_Feature.
◆ SELECTED_OBJECT()
static const std::string & SketchPlugin_Split::SELECTED_OBJECT ( )
inlinestatic
◆ SELECTED_POINT()
static const std::string & SketchPlugin_Split::SELECTED_POINT ( )
inlinestatic
◆ PREVIEW_OBJECT()
static const std::string & SketchPlugin_Split::PREVIEW_OBJECT ( )
inlinestatic
◆ PREVIEW_POINT()
static const std::string & SketchPlugin_Split::PREVIEW_POINT ( )
inlinestatic
◆ execute()
void SketchPlugin_Split::execute ( )
◆ initAttributes()
void SketchPlugin_Split::initAttributes ( )
Implements ModelAPI_Object.
◆ isMacro()
virtual bool SketchPlugin_Split::isMacro ( ) const
true
◆ isPreviewNeeded()
virtual bool SketchPlugin_Split::isPreviewNeeded ( ) const
Returns false. This is necessary to perform execute only by apply the feature
◆ getAISObject()
AISObjectPtr SketchPlugin_Split::getAISObject ( AISObjectPtr  thePrevious)
◆ processEvent()
std::string SketchPlugin_Split::processEvent ( const std::shared_ptr< Events_Message > &  theMessage)
Implements ModelAPI_IReentrant.
◆ isInHistory()
inlinevirtualinherited
◆ isExternal()
◆ isCopy()
◆ canBeDisplayed()
true
◆ isFixed()
◆ sketch()
◆ setSketch()
inlineprotectedinherited
◆ keepCurrentFeature()
◆ restoreCurrentFeature()
◆ group()
inlinestaticinherited
◆ document() [1/2]
◆ document() [2/2]
◆ groupName()
◆ compute()
◆ setError()
bool  isSend = true,
bool  isTranslate = true
◆ error()
◆ results()
◆ firstResult()
◆ lastResult()
◆ setResult() [1/2]
◆ setResult() [2/2]
const int  theIndex
◆ removeResults()
const bool  theFlush = true
◆ eraseResults()
◆ erase()
◆ eraseResultFromList()
only internally
◆ isPersistentResult()
◆ isAction()
◆ documentToAdd()
◆ setDisabled()
Enables/disables the feature.
◆ isDisabled()
◆ feature()
◆ setStable()
Set the stable feature flag.
◆ isStable()
◆ isEditable()
◆ customAction()
theActionIdan action key
◆ vertices()
◆ edges()
◆ wires()
◆ faces()
◆ shells()
◆ solids()
◆ boolean()
◆ real()
◆ integer()
◆ intArray()
◆ refattr()
◆ refattrlist()
◆ reference()
◆ reflist()
◆ selection()
◆ selectionList()
◆ string()
◆ stringArray()
◆ tables()
◆ attribute()
◆ init()
◆ setInHistory()
const bool  theFlag
◆ data()
◆ isSame()
◆ colorConfigInfo()
std::string &  ,
std::string &
◆ attributeChanged()
◆ isDisplayed()
◆ setDisplayed()
◆ hasTexture()
◆ setData()
◆ setDoc()
◆ emptyFunction()
