ModelAPI_AttributeRefList Class Referenceabstract
Attribute that contains list of references to features (located in the same document). More...
#include <ModelAPI_AttributeRefList.h>
Inheritance diagram for ModelAPI_AttributeRefList:
virtual std::string attributeType ()
virtual void append (ObjectPtr theObject)=0
 Appends the feature to the end of a list. More...
virtual void remove (ObjectPtr theObject)=0
 Erases the first meet of the feature in the list. More...
virtual void clear ()=0
 Removes all references from the list. More...
virtual int size (const bool theWithEmpty=true) const =0
 Returns number of features in the list. More...
virtual std::list< ObjectPtr > list ()=0
 Returns the list of features. More...
virtual bool isInList (const ObjectPtr &theObj)=0
 Returns true if the object is in list. More...
virtual ObjectPtr object (const int theIndex, const bool theWithEmpty=true)=0
 Returns the referenced object by the zero-based index. More...
virtual void substitute (const ObjectPtr &theCurrent, const ObjectPtr &theNew)=0
 Substitutes the object by another one. Does nothing if such object is not found. More...
virtual void removeLast ()=0
 Removes the last element in the list. More...
virtual void remove (const std::set< int > &theIndices)=0
 Removes the elements from the list. More...
virtual bool isInitialized ()
void setInitialized ()
bool isArgument ()
bool isImmutable ()
virtual void reset ()
static std::string typeId ()
 ModelAPI_AttributeRefList ()
 Objects are created for features automatically. More...
virtual void reinit ()
bool myIsInitialized
bool mySetInitializedBlocked
bool myIsArgument
bool myIsImmutable
◆ ModelAPI_AttributeRefList()
ModelAPI_AttributeRefList::ModelAPI_AttributeRefList ( )
◆ typeId()
static std::string ModelAPI_AttributeRefList::typeId ( )
inlinestatic
◆ attributeType()
std::string ModelAPI_AttributeRefList::attributeType ( )
◆ append()
virtual void ModelAPI_AttributeRefList::append ( ObjectPtr  theObject)
pure virtual
Implemented in Model_AttributeRefList.
◆ remove() [1/2]
virtual void ModelAPI_AttributeRefList::remove ( ObjectPtr  theObject)
pure virtual
◆ clear()
virtual void ModelAPI_AttributeRefList::clear ( )
pure virtual
◆ size()
virtual int ModelAPI_AttributeRefList::size ( const bool  theWithEmpty = true) const
pure virtual
theWithEmptyif it is false, returns the number of not-empty referenced objects
◆ list()
virtual std::list< ObjectPtr > ModelAPI_AttributeRefList::list ( )
pure virtual
◆ isInList()
virtual bool ModelAPI_AttributeRefList::isInList ( const ObjectPtr &  theObj)
pure virtual
◆ object()
virtual ObjectPtr ModelAPI_AttributeRefList::object ( const int  theIndex,
pure virtual
theIndexzero-based index in the list
theWithEmptyif it is false, counts the not-empty referenced objects only
◆ substitute()
virtual void ModelAPI_AttributeRefList::substitute ( const ObjectPtr &  theCurrent,
const ObjectPtr &  theNew
pure virtual
◆ removeLast()
virtual void ModelAPI_AttributeRefList::removeLast ( )
pure virtual
◆ remove() [2/2]
virtual void ModelAPI_AttributeRefList::remove ( const std::set< int > &  theIndices)
pure virtual
theIndicesa list of indices of elements to be removed
◆ setObject()
◆ owner()
◆ isInitialized()
◆ setInitialized()
◆ blockSetInitialized()
theBlocka block value
the previous block value
◆ setIsArgument()
By default it is true.
◆ isArgument()
◆ setImmutable()
◆ isImmutable()
◆ id()
◆ reset()
void ModelAPI_Attribute::reset ( )
◆ setID()
◆ reinit()
◆ myIsInitialized
◆ mySetInitializedBlocked
◆ myIsArgument
◆ myIsImmutable
