ModelAPI_AttributeRefList.h
20#ifndef ModelAPI_AttributeRefList_H_
21#define ModelAPI_AttributeRefList_H_
23#include "ModelAPI_Attribute.h"
24#include "ModelAPI_Feature.h"
25#include <list>
26
33{
34 public:
36 MODELAPI_EXPORT static std::string typeId()
37 {
38 return "RefList";
39 }
40
42 MODELAPI_EXPORT virtual std::string attributeType();
43
45 virtual void append(ObjectPtr theObject) = 0;
46
48 virtual void remove(ObjectPtr theObject) = 0;
49
51 virtual void clear() = 0;
52
55 virtual int size(const bool theWithEmpty = true) const = 0;
56
58 virtual std::list<ObjectPtr> list() = 0;
59
61 virtual bool isInList(const ObjectPtr& theObj) = 0;
62
66 virtual ObjectPtr object(const int theIndex, const bool theWithEmpty = true) = 0;
67
69 virtual void substitute(const ObjectPtr& theCurrent, const ObjectPtr& theNew) = 0;
70
72 virtual void removeLast() = 0;
73
76 virtual void remove(const std::set<int>& theIndices) = 0;
77
78 MODELAPI_EXPORT virtual ~ModelAPI_AttributeRefList();
79 protected:
81 MODELAPI_EXPORT ModelAPI_AttributeRefList();
82
83};
84
85typedef std::shared_ptr<ModelAPI_AttributeRefList> AttributeRefListPtr;
86
87#endif
Attribute that contains list of references to features (located in the same document).
Definition: ModelAPI_AttributeRefList.h:33
virtual void remove(const std::set< int > &theIndices)=0
Removes the elements from the list.
virtual void append(ObjectPtr theObject)=0
Appends the feature to the end of a list.
Returns the type of this class of attributes, not static method.
Definition: ModelAPI_AttributeRefList.cpp:22
virtual std::list< ObjectPtr > list()=0
Returns the list of features.
virtual void substitute(const ObjectPtr &theCurrent, const ObjectPtr &theNew)=0
Substitutes the object by another one. Does nothing if such object is not found.
virtual int size(const bool theWithEmpty=true) const =0
Returns number of features in the list.
virtual void remove(ObjectPtr theObject)=0
Erases the first meet of the feature in the list.
virtual void clear()=0
Removes all references from the list.
Returns the type of this class of attributes.
Definition: ModelAPI_AttributeRefList.h:36
virtual ObjectPtr object(const int theIndex, const bool theWithEmpty=true)=0
Returns the referenced object by the zero-based index.
Definition: ModelAPI_AttributeRefList.cpp:32
virtual void removeLast()=0
Removes the last element in the list.
virtual bool isInList(const ObjectPtr &theObj)=0
Returns true if the object is in list.
