Model_AttributeIntArray Class Reference
API for the attribute that contains several integers in the array inside. More...
#include <Model_AttributeIntArray.h>
Inheritance diagram for Model_AttributeIntArray:
virtual MODEL_EXPORT int size ()
 Returns the size of the array (zero means that it is empty) More...
virtual MODEL_EXPORT void setSize (const int theSize, bool sendUpdated=true)
 Sets the new size of the array. The previous data is erased. More...
virtual MODEL_EXPORT void setValue (const int theIndex, const int theValue, bool sendUpdated=true)
 Defines the value of the array by index [0; size-1]. More...
virtual MODEL_EXPORT int value (const int theIndex)
 Returns the value by the index. More...
virtual MODELAPI_EXPORT std::string attributeType ()
virtual bool isInitialized ()
void setInitialized ()
bool isArgument ()
bool isImmutable ()
virtual void reset ()
static MODELAPI_EXPORT std::string typeId ()
 Model_AttributeIntArray (TDF_Label &theLabel)
 Initializes attributes. More...
virtual void reinit ()
bool myIsInitialized
bool mySetInitializedBlocked
bool myIsArgument
bool myIsImmutable
Friends
class Model_Data
Used for RGB color storage for an example. By default size is one, zero-based. Represented as array in OCCT. Empty array means that this attribute does not exists.
◆ Model_AttributeIntArray()
Model_AttributeIntArray::Model_AttributeIntArray ( TDF_Label &  theLabel)
◆ size()
int Model_AttributeIntArray::size ( )
Implements ModelAPI_AttributeIntArray.
◆ setSize()
void Model_AttributeIntArray::setSize ( const int  theSize,
bool  sendUpdated = true
◆ setValue()
void Model_AttributeIntArray::setValue ( const int  theIndex,
const int  theValue,
◆ value()
int Model_AttributeIntArray::value ( const int  theIndex)
◆ reinit()
void Model_AttributeIntArray::reinit ( )
Reimplemented from ModelAPI_Attribute.
◆ typeId()
static MODELAPI_EXPORT std::string ModelAPI_AttributeIntArray::typeId ( )
inlinestaticinherited
◆ attributeType()
std::string ModelAPI_AttributeIntArray::attributeType ( )
◆ setObject()
◆ owner()
◆ isInitialized()
◆ setInitialized()
◆ blockSetInitialized()
theBlocka block value
the previous block value
◆ setIsArgument()
By default it is true.
◆ isArgument()
◆ setImmutable()
◆ isImmutable()
◆ id()
◆ reset()
void ModelAPI_Attribute::reset ( )
◆ setID()
◆ myIsInitialized
◆ mySetInitializedBlocked
◆ myIsArgument
◆ myIsImmutable
