Model_AttributeRefAttr Class Reference
Attribute that contains reference to an attribute of a feature (located in the same document). More...
#include <Model_AttributeRefAttr.h>
Inheritance diagram for Model_AttributeRefAttr:
virtual bool isObject ()
 Returns true if this attribute references to a object (not to the attribute) More...
virtual void setAttr (std::shared_ptr< ModelAPI_Attribute > theAttr)
 Defines the reference to the attribute. More...
virtual std::shared_ptr< ModelAPI_Attribute > attr ()
 Returns attribute referenced from this attribute. More...
virtual void setObject (ObjectPtr theFeature)
 Defines the reference to the object. More...
virtual ObjectPtr object ()
 Returns object referenced from this attribute. More...
virtual bool isInitialized ()
virtual std::string attributeType ()
void setInitialized ()
bool isArgument ()
bool isImmutable ()
virtual void reset ()
static std::string typeId ()
 Model_AttributeRefAttr (TDF_Label &theLabel)
 Objects are created for features automatically. More...
virtual void reinit ()
bool myIsInitialized
bool mySetInitializedBlocked
bool myIsArgument
bool myIsImmutable
Friends
class Model_Data
◆ Model_AttributeRefAttr()
Model_AttributeRefAttr::Model_AttributeRefAttr ( TDF_Label &  theLabel)
◆ isObject()
bool Model_AttributeRefAttr::isObject ( )
Implements ModelAPI_AttributeRefAttr.
◆ setAttr()
void Model_AttributeRefAttr::setAttr ( std::shared_ptr< ModelAPI_Attribute >  theAttr)
◆ attr()
std::shared_ptr< ModelAPI_Attribute > Model_AttributeRefAttr::attr ( )
◆ setObject() [1/2]
void Model_AttributeRefAttr::setObject ( ObjectPtr  theFeature)
◆ object()
ObjectPtr Model_AttributeRefAttr::object ( )
◆ isInitialized()
bool Model_AttributeRefAttr::isInitialized ( )
Reimplemented from ModelAPI_Attribute.
◆ reinit()
void Model_AttributeRefAttr::reinit ( )
◆ setObject() [2/2]
◆ typeId()
static std::string ModelAPI_AttributeRefAttr::typeId ( )
inlinestaticinherited
◆ attributeType()
std::string ModelAPI_AttributeRefAttr::attributeType ( )
◆ owner()
◆ setInitialized()
◆ blockSetInitialized()
theBlocka block value
the previous block value
◆ setIsArgument()
By default it is true.
◆ isArgument()
◆ setImmutable()
◆ isImmutable()
◆ id()
◆ reset()
void ModelAPI_Attribute::reset ( )
◆ setID()
◆ myIsInitialized
◆ mySetInitializedBlocked
◆ myIsArgument
◆ myIsImmutable
