ModelAPI_AttributeRefAttr Class Referenceabstract
Attribute that contains reference to an attribute of a feature or reference to a feature (switchable) More...
#include <ModelAPI_AttributeRefAttr.h>
Inheritance diagram for ModelAPI_AttributeRefAttr:
virtual bool isObject ()=0
 Returns true if this attribute references to a object (not to the attribute) More...
virtual void setAttr (AttributePtr theAttr)=0
 Defines the reference to the attribute. More...
virtual AttributePtr attr ()=0
 Returns attribute referenced from this attribute. More...
virtual void setObject (ObjectPtr theFeature)=0
 Defines the reference to the object. More...
virtual ObjectPtr object ()=0
 Returns object referenced from this attribute. More...
virtual std::string attributeType ()
virtual ~ModelAPI_AttributeRefAttr ()
 To virtually destroy the fields of successors. More...
virtual bool isInitialized ()
void setInitialized ()
bool isArgument ()
bool isImmutable ()
virtual void reset ()
static std::string typeId ()
 Objects are created for features automatically. More...
virtual void reinit ()
bool myIsInitialized
bool mySetInitializedBlocked
bool myIsArgument
bool myIsImmutable
◆ ~ModelAPI_AttributeRefAttr()
ModelAPI_AttributeRefAttr::~ModelAPI_AttributeRefAttr ( )
◆ ModelAPI_AttributeRefAttr()
ModelAPI_AttributeRefAttr::ModelAPI_AttributeRefAttr ( )
◆ isObject()
virtual bool ModelAPI_AttributeRefAttr::isObject ( )
pure virtual
Implemented in Model_AttributeRefAttr.
◆ setAttr()
virtual void ModelAPI_AttributeRefAttr::setAttr ( AttributePtr  theAttr)
pure virtual
◆ attr()
virtual AttributePtr ModelAPI_AttributeRefAttr::attr ( )
pure virtual
◆ setObject() [1/2]
virtual void ModelAPI_AttributeRefAttr::setObject ( ObjectPtr  theFeature)
pure virtual
◆ object()
virtual ObjectPtr ModelAPI_AttributeRefAttr::object ( )
pure virtual
◆ typeId()
static std::string ModelAPI_AttributeRefAttr::typeId ( )
inlinestatic
◆ attributeType()
std::string ModelAPI_AttributeRefAttr::attributeType ( )
◆ setObject() [2/2]
◆ owner()
◆ isInitialized()
◆ setInitialized()
◆ blockSetInitialized()
theBlocka block value
the previous block value
◆ setIsArgument()
By default it is true.
◆ isArgument()
◆ setImmutable()
◆ isImmutable()
◆ id()
◆ reset()
void ModelAPI_Attribute::reset ( )
◆ setID()
◆ reinit()
◆ myIsInitialized
◆ mySetInitializedBlocked
◆ myIsArgument
◆ myIsImmutable
